root/radiance/ray/src/rt/func.c
Revision: 2.22
Committed: Tue Mar 30 16:13:01 2004 UTC (21 years, 3 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8, rad3R9
Changes since 2.21: +28 -27 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 2.22 static const char RCSid[] = "$Id: func.c,v 2.21 2004/02/12 18:55:50 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * func.c - interface to calcomp functions.
6 greg 2.14 */
7
8 greg 2.15 #include "copyright.h"
9 greg 1.1
10 schorsch 2.22 #include <math.h>
11
12 greg 1.1 #include "ray.h"
13 greg 2.21 #include "paths.h"
14 greg 1.1 #include "otypes.h"
15 greg 2.2 #include "func.h"
16 greg 1.1
17 greg 2.2
18 greg 1.21 #define INITFILE "rayinit.cal"
19 greg 2.2 #define CALSUF ".cal"
20     #define LCALSUF 4
21 greg 2.10 char REFVNAME[] = "`FILE_REFCNT";
22 greg 1.21
23 greg 1.13 XF unitxf = { /* identity transform */
24 greg 2.8 {{1.0, 0.0, 0.0, 0.0},
25     {0.0, 1.0, 0.0, 0.0},
26     {0.0, 0.0, 1.0, 0.0},
27     {0.0, 0.0, 0.0, 1.0}},
28 greg 1.13 1.0
29     };
30
31 greg 1.12 XF funcxf; /* current transformation */
32     static OBJREC *fobj = NULL; /* current function object */
33     static RAY *fray = NULL; /* current function ray */
34 greg 1.1
35 greg 2.20 static double l_erf(char *), l_erfc(char *), l_arg(char *);
36 greg 1.1
37 greg 2.2
38 schorsch 2.22 extern MFUNC *
39     getfunc( /* get function for this modifier */
40     OBJREC *m,
41     int ff,
42     unsigned int ef,
43     int dofwd
44     )
45 greg 2.2 {
46     static char initfile[] = INITFILE;
47     char sbuf[MAXSTR];
48     register char **arg;
49     register MFUNC *f;
50     int ne, na;
51     register int i;
52     /* check to see if done already */
53     if ((f = (MFUNC *)m->os) != NULL)
54     return(f);
55 greg 2.7 fobj = NULL; fray = NULL;
56 greg 2.2 if (initfile[0]) { /* initialize on first call */
57 greg 2.14 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
58     esupport &= ~(E_OUTCHAN);
59 greg 2.2 setcontext("");
60     scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
61     scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
62     scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
63 greg 2.6 scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
64 greg 2.2 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
65     scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
66     scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
67     scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
68 greg 2.17 scompile("Lu=$26;Lv=$27;", NULL, 0);
69 greg 2.2 funset("arg", 1, '=', l_arg);
70     funset("erf", 1, ':', l_erf);
71     funset("erfc", 1, ':', l_erfc);
72     setnoisefuncs();
73 greg 2.11 setprismfuncs();
74 greg 2.2 loadfunc(initfile);
75     initfile[0] = '\0';
76     }
77     if ((na = m->oargs.nsargs) <= ff)
78     goto toofew;
79     arg = m->oargs.sarg;
80     if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
81     goto memerr;
82     i = strlen(arg[ff]); /* set up context */
83     if (i == 1 && arg[ff][0] == '.')
84     setcontext(f->ctx = ""); /* "." means no file */
85     else {
86 greg 2.14 strcpy(sbuf,arg[ff]); /* file name is context */
87 greg 2.2 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
88     sbuf[i-LCALSUF] = '\0'; /* remove suffix */
89     setcontext(f->ctx = savestr(sbuf));
90     if (!vardefined(REFVNAME)) { /* file loaded? */
91 greg 2.5 loadfunc(arg[ff]);
92 greg 2.2 varset(REFVNAME, '=', 1.0);
93     } else /* reference_count++ */
94     varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
95     }
96     curfunc = NULL; /* parse expressions */
97     sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
98     for (i=0, ne=0; ef && i < na; i++, ef>>=1)
99     if (ef & 1) { /* flagged as an expression? */
100     if (ne >= MAXEXPR)
101     objerror(m, INTERNAL, "too many expressions");
102     initstr(arg[i], sbuf, 0);
103     f->ep[ne++] = getE1();
104     if (nextc != EOF)
105     syntax("unexpected character");
106     }
107     if (ef)
108     goto toofew;
109     if (i <= ff) /* find transform args */
110     i = ff+1;
111     while (i < na && arg[i][0] != '-')
112     i++;
113     if (i == na) /* no transform */
114     f->f = f->b = &unitxf;
115     else { /* get transform */
116     if ((f->b = (XF *)malloc(sizeof(XF))) == NULL)
117 greg 2.3 goto memerr;
118 greg 2.2 if (invxf(f->b, na-i, arg+i) != na-i)
119     objerror(m, USER, "bad transform");
120     if (f->b->sca < 0.0)
121     f->b->sca = -f->b->sca;
122     if (dofwd) { /* do both transforms */
123     if ((f->f = (XF *)malloc(sizeof(XF))) == NULL)
124 greg 2.3 goto memerr;
125 greg 2.2 xf(f->f, na-i, arg+i);
126     if (f->f->sca < 0.0)
127     f->f->sca = -f->f->sca;
128     }
129     }
130     m->os = (char *)f;
131     return(f);
132     toofew:
133 greg 2.4 objerror(m, USER, "too few string arguments");
134 greg 2.2 memerr:
135     error(SYSTEM, "out of memory in getfunc");
136 schorsch 2.22 return NULL; /* pro forma return */
137 greg 2.2 }
138
139
140 schorsch 2.22 extern void
141     freefunc( /* free memory associated with modifier */
142     OBJREC *m
143     )
144 greg 2.2 {
145     register MFUNC *f;
146     register int i;
147
148     if ((f = (MFUNC *)m->os) == NULL)
149     return;
150     for (i = 0; f->ep[i] != NULL; i++)
151     epfree(f->ep[i]);
152     if (f->ctx[0]) { /* done with definitions */
153     setcontext(f->ctx);
154     i = varvalue(REFVNAME)-.5; /* reference_count-- */
155     if (i > 0)
156     varset(REFVNAME, '=', (double)i);
157     else
158     dcleanup(2); /* remove definitions */
159     freestr(f->ctx);
160     }
161     if (f->b != &unitxf)
162 greg 2.14 free((void *)f->b);
163 greg 2.2 if (f->f != NULL && f->f != &unitxf)
164 greg 2.14 free((void *)f->f);
165     free((void *)f);
166 greg 2.2 m->os = NULL;
167     }
168
169
170 schorsch 2.22 extern int
171     setfunc( /* set channels for function call */
172     OBJREC *m,
173     register RAY *r
174     )
175 greg 1.1 {
176 greg 2.9 static unsigned long lastrno = ~0;
177 greg 2.2 register MFUNC *f;
178     /* get function */
179     if ((f = (MFUNC *)m->os) == NULL)
180 greg 2.14 objerror(m, CONSISTENCY, "setfunc called before getfunc");
181 greg 2.2 /* set evaluator context */
182     setcontext(f->ctx);
183     /* check to see if matrix set */
184 greg 1.16 if (m == fobj && r->rno == lastrno)
185 greg 1.17 return(0);
186 greg 1.1 fobj = m;
187     fray = r;
188 greg 1.13 if (r->rox != NULL)
189 greg 2.2 if (f->b != &unitxf) {
190     funcxf.sca = r->rox->b.sca * f->b->sca;
191     multmat4(funcxf.xfm, r->rox->b.xfm, f->b->xfm);
192 greg 1.13 } else
193 schorsch 2.19 funcxf = r->rox->b;
194 greg 1.13 else
195 schorsch 2.19 funcxf = *(f->b);
196 greg 1.16 lastrno = r->rno;
197 greg 1.1 eclock++; /* notify expression evaluator */
198 greg 1.17 return(1);
199 greg 1.1 }
200
201
202 schorsch 2.22 extern void
203     loadfunc( /* load definition file */
204     char *fname
205     )
206 greg 1.1 {
207     char *ffname;
208
209 greg 2.18 if ((ffname = getpath(fname, getrlibpath(), R_OK)) == NULL) {
210 greg 1.1 sprintf(errmsg, "cannot find function file \"%s\"", fname);
211     error(USER, errmsg);
212     }
213     fcompile(ffname);
214     }
215
216
217 greg 2.2 static double
218 greg 2.20 l_arg(char *nm) /* return nth real argument */
219 greg 1.1 {
220     register int n;
221
222 greg 2.7 if (fobj == NULL)
223     syntax("arg(n) used in constant expression");
224
225 greg 1.1 n = argument(1) + .5; /* round to integer */
226
227     if (n < 1)
228     return(fobj->oargs.nfargs);
229
230     if (n > fobj->oargs.nfargs) {
231     sprintf(errmsg, "missing real argument %d", n);
232     objerror(fobj, USER, errmsg);
233     }
234     return(fobj->oargs.farg[n-1]);
235 greg 1.19 }
236
237
238 greg 2.2 static double
239 greg 2.20 l_erf(char *nm) /* error function */
240 greg 1.19 {
241     return(erf(argument(1)));
242     }
243
244
245 greg 2.2 static double
246 greg 2.20 l_erfc(char *nm) /* cumulative error function */
247 greg 1.19 {
248     return(erfc(argument(1)));
249 greg 1.1 }
250
251
252 schorsch 2.22 extern double
253     chanvalue( /* return channel n to calcomp */
254     register int n
255     )
256 greg 1.1 {
257 greg 2.7 if (fray == NULL)
258     syntax("ray parameter used in constant expression");
259 greg 1.1
260 greg 1.10 if (--n < 0)
261     goto badchan;
262 greg 1.1
263 greg 2.17 if (n <= 2) /* ray direction */
264 greg 1.1
265 greg 1.12 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
266     fray->rdir[1]*funcxf.xfm[1][n] +
267     fray->rdir[2]*funcxf.xfm[2][n] )
268     / funcxf.sca );
269 greg 1.1
270 greg 2.17 if (n <= 5) /* surface normal */
271 greg 1.8
272 greg 1.12 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
273     fray->ron[1]*funcxf.xfm[1][n-3] +
274     fray->ron[2]*funcxf.xfm[2][n-3] )
275     / funcxf.sca );
276 greg 1.8
277 greg 2.17 if (n <= 8) /* intersection */
278 greg 1.8
279 greg 1.12 return( fray->rop[0]*funcxf.xfm[0][n-6] +
280     fray->rop[1]*funcxf.xfm[1][n-6] +
281     fray->rop[2]*funcxf.xfm[2][n-6] +
282     funcxf.xfm[3][n-6] );
283 greg 1.8
284 greg 2.13 if (n == 9) /* total distance */
285     return(raydist(fray,PRIMARY) * funcxf.sca);
286 greg 1.10
287 greg 1.18 if (n == 10) /* dot product (range [-1,1]) */
288     return( fray->rod <= -1.0 ? -1.0 :
289     fray->rod >= 1.0 ? 1.0 :
290     fray->rod );
291 greg 1.10
292 greg 1.8 if (n == 11) /* scale */
293 greg 1.12 return(funcxf.sca);
294 greg 1.8
295 greg 2.17 if (n <= 14) /* origin */
296 greg 1.12 return(funcxf.xfm[3][n-12]);
297 greg 1.8
298 greg 2.17 if (n <= 17) /* i unit vector */
299 greg 1.12 return(funcxf.xfm[0][n-15] / funcxf.sca);
300 greg 1.8
301 greg 2.17 if (n <= 20) /* j unit vector */
302     return(funcxf.xfm[1][n-18] / funcxf.sca);
303 greg 1.8
304 greg 2.17 if (n <= 23) /* k unit vector */
305 greg 1.12 return(funcxf.xfm[2][n-21] / funcxf.sca);
306 greg 2.6
307 greg 2.17 if (n == 24) /* single ray (shadow) distance */
308 greg 2.13 return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca);
309 greg 2.16
310 greg 2.17 if (n <= 26) /* local (u,v) coordinates */
311     return(fray->uv[n-25]);
312 greg 1.10 badchan:
313     error(USER, "illegal channel number");
314 greg 2.16 return(0.0);
315 greg 1.1 }
