--- ray/src/rt/func.c 2003/03/11 17:08:55 2.16 +++ ray/src/rt/func.c 2003/08/04 22:37:53 2.20 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: func.c,v 2.16 2003/03/11 17:08:55 greg Exp $"; +static const char RCSid[] = "$Id: func.c,v 2.20 2003/08/04 22:37:53 greg Exp $"; #endif /* * func.c - interface to calcomp functions. @@ -31,7 +31,7 @@ XF funcxf; /* current transformation */ static OBJREC *fobj = NULL; /* current function object */ static RAY *fray = NULL; /* current function ray */ -static double l_erf(), l_erfc(), l_arg(); +static double l_erf(char *), l_erfc(char *), l_arg(char *); MFUNC * @@ -63,7 +63,7 @@ int dofwd; scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0); scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0); scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0); - scompile("Lu=$25;Lv=$26;", NULL, 0); + scompile("Lu=$26;Lv=$27;", NULL, 0); funset("arg", 1, '=', l_arg); funset("erf", 1, ':', l_erf); funset("erfc", 1, ':', l_erfc); @@ -185,9 +185,9 @@ register RAY *r; funcxf.sca = r->rox->b.sca * f->b->sca; multmat4(funcxf.xfm, r->rox->b.xfm, f->b->xfm); } else - copystruct(&funcxf, &r->rox->b); + funcxf = r->rox->b; else - copystruct(&funcxf, f->b); + funcxf = *(f->b); lastrno = r->rno; eclock++; /* notify expression evaluator */ return(1); @@ -200,7 +200,7 @@ char *fname; { char *ffname; - if ((ffname = getpath(fname, getlibpath(), R_OK)) == NULL) { + if ((ffname = getpath(fname, getrlibpath(), R_OK)) == NULL) { sprintf(errmsg, "cannot find function file \"%s\"", fname); error(USER, errmsg); } @@ -209,7 +209,7 @@ char *fname; static double -l_arg() /* return nth real argument */ +l_arg(char *nm) /* return nth real argument */ { register int n; @@ -230,7 +230,7 @@ l_arg() /* return nth real argument */ static double -l_erf() /* error function */ +l_erf(char *nm) /* error function */ { extern double erf(); @@ -239,7 +239,7 @@ l_erf() /* error function */ static double -l_erfc() /* cumulative error function */ +l_erfc(char *nm) /* cumulative error function */ { extern double erfc(); @@ -257,21 +257,21 @@ register int n; if (--n < 0) goto badchan; - if (n < 3) /* ray direction */ + if (n <= 2) /* ray direction */ return( ( fray->rdir[0]*funcxf.xfm[0][n] + fray->rdir[1]*funcxf.xfm[1][n] + fray->rdir[2]*funcxf.xfm[2][n] ) / funcxf.sca ); - if (n < 6) /* surface normal */ + if (n <= 5) /* surface normal */ return( ( fray->ron[0]*funcxf.xfm[0][n-3] + fray->ron[1]*funcxf.xfm[1][n-3] + fray->ron[2]*funcxf.xfm[2][n-3] ) / funcxf.sca ); - if (n < 9) /* intersection */ + if (n <= 8) /* intersection */ return( fray->rop[0]*funcxf.xfm[0][n-6] + fray->rop[1]*funcxf.xfm[1][n-6] + @@ -289,23 +289,23 @@ register int n; if (n == 11) /* scale */ return(funcxf.sca); - if (n < 15) /* origin */ + if (n <= 14) /* origin */ return(funcxf.xfm[3][n-12]); - if (n < 18) /* i unit vector */ + if (n <= 17) /* i unit vector */ return(funcxf.xfm[0][n-15] / funcxf.sca); - if (n < 21) /* j unit vector */ - return(funcxf.xfm[1][n-15] / funcxf.sca); + if (n <= 20) /* j unit vector */ + return(funcxf.xfm[1][n-18] / funcxf.sca); - if (n < 24) /* k unit vector */ + if (n <= 23) /* k unit vector */ return(funcxf.xfm[2][n-21] / funcxf.sca); - if (n < 25) /* single ray (shadow) distance */ + if (n == 24) /* single ray (shadow) distance */ return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca); - if (n < 27) /* local (u,v) coordinates */ - return(fray->uv[n-26]); + if (n <= 26) /* local (u,v) coordinates */ + return(fray->uv[n-25]); badchan: error(USER, "illegal channel number"); return(0.0);
