--- ray/src/rt/func.c 1993/03/08 12:37:23 2.8 +++ ray/src/rt/func.c 2003/02/25 02:47:22 2.15 @@ -1,15 +1,12 @@ -/* Copyright (c) 1992 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: func.c,v 2.15 2003/02/25 02:47:22 greg Exp $"; #endif - /* * func.c - interface to calcomp functions. - * - * 4/7/86 */ +#include "copyright.h" + #include "ray.h" #include "otypes.h" @@ -18,9 +15,9 @@ static char SCCSid[] = "$SunId$ LBL"; #define INITFILE "rayinit.cal" -#define REFVNAME "`FILE_REFCNT" #define CALSUF ".cal" #define LCALSUF 4 +char REFVNAME[] = "`FILE_REFCNT"; XF unitxf = { /* identity transform */ {{1.0, 0.0, 0.0, 0.0}, @@ -41,10 +38,9 @@ MFUNC * getfunc(m, ff, ef, dofwd) /* get function for this modifier */ OBJREC *m; int ff; -unsigned ef; +unsigned int ef; int dofwd; { - extern EPNODE *curfunc; static char initfile[] = INITFILE; char sbuf[MAXSTR]; register char **arg; @@ -56,6 +52,8 @@ int dofwd; return(f); fobj = NULL; fray = NULL; if (initfile[0]) { /* initialize on first call */ + esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW; + esupport &= ~(E_OUTCHAN); setcontext(""); scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0); scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0); @@ -69,6 +67,7 @@ int dofwd; funset("erf", 1, ':', l_erf); funset("erfc", 1, ':', l_erfc); setnoisefuncs(); + setprismfuncs(); loadfunc(initfile); initfile[0] = '\0'; } @@ -81,7 +80,7 @@ int dofwd; if (i == 1 && arg[ff][0] == '.') setcontext(f->ctx = ""); /* "." means no file */ else { - strcpy(sbuf,arg[ff]); /* file name is context */ + strcpy(sbuf,arg[ff]); /* file name is context */ if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF)) sbuf[i-LCALSUF] = '\0'; /* remove suffix */ setcontext(f->ctx = savestr(sbuf)); @@ -134,6 +133,7 @@ memerr: } +void freefunc(m) /* free memory associated with modifier */ OBJREC *m; { @@ -154,23 +154,24 @@ OBJREC *m; freestr(f->ctx); } if (f->b != &unitxf) - free((char *)f->b); + free((void *)f->b); if (f->f != NULL && f->f != &unitxf) - free((char *)f->f); - free((char *)f); + free((void *)f->f); + free((void *)f); m->os = NULL; } +int setfunc(m, r) /* set channels for function call */ OBJREC *m; register RAY *r; { - static long lastrno = -1; + static unsigned long lastrno = ~0; register MFUNC *f; /* get function */ if ((f = (MFUNC *)m->os) == NULL) - error(m, CONSISTENCY, "setfunc called before getfunc"); + objerror(m, CONSISTENCY, "setfunc called before getfunc"); /* set evaluator context */ setcontext(f->ctx); /* check to see if matrix set */ @@ -192,13 +193,13 @@ register RAY *r; } +void loadfunc(fname) /* load definition file */ char *fname; { - extern char *libpath; /* library search path */ char *ffname; - if ((ffname = getpath(fname, libpath, R_OK)) == NULL) { + if ((ffname = getpath(fname, getlibpath(), R_OK)) == NULL) { sprintf(errmsg, "cannot find function file \"%s\"", fname); error(USER, errmsg); } @@ -209,7 +210,6 @@ char *fname; static double l_arg() /* return nth real argument */ { - extern double argument(); register int n; if (fobj == NULL) @@ -250,9 +250,6 @@ double chanvalue(n) /* return channel n to calcomp */ register int n; { - double sum; - register RAY *r; - if (fray == NULL) syntax("ray parameter used in constant expression"); @@ -280,14 +277,9 @@ register int n; fray->rop[2]*funcxf.xfm[2][n-6] + funcxf.xfm[3][n-6] ); - if (n == 9) { /* total distance */ - sum = fray->rot; - for (r = fray->parent; r != NULL; r = r->parent) - sum += r->rot; - return(sum * funcxf.sca); + if (n == 9) /* total distance */ + return(raydist(fray,PRIMARY) * funcxf.sca); - } - if (n == 10) /* dot product (range [-1,1]) */ return( fray->rod <= -1.0 ? -1.0 : fray->rod >= 1.0 ? 1.0 : @@ -308,13 +300,8 @@ register int n; if (n < 24) /* k unit vector */ return(funcxf.xfm[2][n-21] / funcxf.sca); - if (n == 24) { /* single ray (shadow) distance */ - sum = fray->rot; - for (r = fray->parent; r != NULL && r->crtype&SHADOW; - r = r->parent) - sum += r->rot; - return(sum * funcxf.sca); - } + if (n == 24) /* single ray (shadow) distance */ + return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca); badchan: error(USER, "illegal channel number"); }
