root/radiance/ray/src/rt/func.c
Revision: 1.21
Committed: Thu Aug 8 13:08:01 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.20: +34 -19 lines
added contexts to function files
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * func.c - interface to calcomp functions.
9 *
10 * 4/7/86
11 */
12
13 #include "ray.h"
14
15 #include "otypes.h"
16
17
18 #define INITFILE "rayinit.cal"
19 #define DEFVNAME "FILE_LOADED`"
20
21 XF unitxf = { /* identity transform */
22 1.0, 0.0, 0.0, 0.0,
23 0.0, 1.0, 0.0, 0.0,
24 0.0, 0.0, 1.0, 0.0,
25 0.0, 0.0, 0.0, 1.0,
26 1.0
27 };
28
29 XF funcxf; /* current transformation */
30 static OBJREC *fobj = NULL; /* current function object */
31 static RAY *fray = NULL; /* current function ray */
32
33
34 setmap(m, r, bx) /* set channels for function call */
35 OBJREC *m;
36 register RAY *r;
37 XF *bx;
38 {
39 extern long eclock;
40 static long lastrno = -1;
41 /* check to see if already set */
42 if (m == fobj && r->rno == lastrno)
43 return(0);
44 fobj = m;
45 fray = r;
46 if (r->rox != NULL)
47 if (bx != &unitxf) {
48 funcxf.sca = r->rox->b.sca * bx->sca;
49 multmat4(funcxf.xfm, r->rox->b.xfm, bx->xfm);
50 } else
51 copystruct(&funcxf, &r->rox->b);
52 else
53 copystruct(&funcxf, bx);
54 lastrno = r->rno;
55 eclock++; /* notify expression evaluator */
56 return(1);
57 }
58
59
60 setfunc(m, r) /* simplified interface to setmap */
61 register OBJREC *m;
62 RAY *r;
63 {
64 register XF *mxf;
65
66 if ((mxf = (XF *)m->os) == NULL) {
67 register int n;
68 register char **sa;
69
70 for (n = m->oargs.nsargs, sa = m->oargs.sarg;
71 n > 0 && **sa != '-'; n--, sa++)
72 ;
73 if (n == 0)
74 mxf = &unitxf;
75 else {
76 mxf = (XF *)malloc(sizeof(XF));
77 if (mxf == NULL)
78 goto memerr;
79 if (invxf(mxf, n, sa) != n)
80 objerror(m, USER, "bad transform");
81 if (mxf->sca < 0.0)
82 mxf->sca = -mxf->sca;
83 }
84 m->os = (char *)mxf;
85 }
86 return(setmap(m, r, mxf));
87 memerr:
88 error(SYSTEM, "out of memory in setfunc");
89 }
90
91
92 loadfunc(fname) /* load definition file */
93 char *fname;
94 {
95 extern char *libpath; /* library search path */
96 char *ffname;
97
98 if ((ffname = getpath(fname, libpath, R_OK)) == NULL) {
99 sprintf(errmsg, "cannot find function file \"%s\"", fname);
100 error(USER, errmsg);
101 }
102 fcompile(ffname);
103 }
104
105
106 double
107 l_arg() /* return nth real argument */
108 {
109 extern double argument();
110 register int n;
111
112 n = argument(1) + .5; /* round to integer */
113
114 if (n < 1)
115 return(fobj->oargs.nfargs);
116
117 if (n > fobj->oargs.nfargs) {
118 sprintf(errmsg, "missing real argument %d", n);
119 objerror(fobj, USER, errmsg);
120 }
121 return(fobj->oargs.farg[n-1]);
122 }
123
124
125 double
126 l_erf() /* error function */
127 {
128 extern double erf();
129
130 return(erf(argument(1)));
131 }
132
133
134 double
135 l_erfc() /* cumulative error function */
136 {
137 extern double erfc();
138
139 return(erfc(argument(1)));
140 }
141
142
143 funcfile(fname) /* set context, load file if necessary */
144 char *fname;
145 {
146 extern char *setcontext();
147 static char initfile[] = INITFILE;
148
149 if (initfile[0]) { /* initialize on first call */
150 setcontext("");
151 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
152 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
153 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
154 scompile("T=$10;Rdot=$11;", NULL, 0);
155 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
156 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
157 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
158 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
159 funset("arg", 1, '=', l_arg);
160 funset("erf", 1, ':', l_erf);
161 funset("erfc", 1, ':', l_erfc);
162 setnoisefuncs();
163 loadfunc(initfile);
164 initfile[0] = '\0';
165 }
166 setcontext(fname);
167 if (!vardefined(DEFVNAME)) {
168 loadfunc(fname);
169 varset(DEFVNAME, ':', 1.0);
170 }
171 }
172
173
174 double
175 chanvalue(n) /* return channel n to calcomp */
176 register int n;
177 {
178 double sum;
179 register RAY *r;
180
181 if (--n < 0)
182 goto badchan;
183
184 if (n < 3) /* ray direction */
185
186 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
187 fray->rdir[1]*funcxf.xfm[1][n] +
188 fray->rdir[2]*funcxf.xfm[2][n] )
189 / funcxf.sca );
190
191 if (n < 6) /* surface normal */
192
193 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
194 fray->ron[1]*funcxf.xfm[1][n-3] +
195 fray->ron[2]*funcxf.xfm[2][n-3] )
196 / funcxf.sca );
197
198 if (n < 9) /* intersection */
199
200 return( fray->rop[0]*funcxf.xfm[0][n-6] +
201 fray->rop[1]*funcxf.xfm[1][n-6] +
202 fray->rop[2]*funcxf.xfm[2][n-6] +
203 funcxf.xfm[3][n-6] );
204
205 if (n == 9) { /* distance */
206
207 sum = fray->rot;
208 for (r = fray->parent; r != NULL; r = r->parent)
209 sum += r->rot;
210 return(sum * funcxf.sca);
211
212 }
213 if (n == 10) /* dot product (range [-1,1]) */
214 return( fray->rod <= -1.0 ? -1.0 :
215 fray->rod >= 1.0 ? 1.0 :
216 fray->rod );
217
218 if (n == 11) /* scale */
219 return(funcxf.sca);
220
221 if (n < 15) /* origin */
222 return(funcxf.xfm[3][n-12]);
223
224 if (n < 18) /* i unit vector */
225 return(funcxf.xfm[0][n-15] / funcxf.sca);
226
227 if (n < 21) /* j unit vector */
228 return(funcxf.xfm[1][n-15] / funcxf.sca);
229
230 if (n < 24) /* k unit vector */
231 return(funcxf.xfm[2][n-21] / funcxf.sca);
232 badchan:
233 error(USER, "illegal channel number");
234 }
