root/radiance/ray/src/rt/func.c
Revision: 1.12
Committed: Sat Dec 15 15:03:26 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.11: +37 -35 lines
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * func.c - interface to calcomp functions.
9 *
10 * 4/7/86
11 */
12
13 #include "ray.h"
14
15 #include "otypes.h"
16
17
18 XF funcxf; /* current transformation */
19 static OBJREC *fobj = NULL; /* current function object */
20 static RAY *fray = NULL; /* current function ray */
21
22
23 setmap(m, r, bx) /* set channels for function call */
24 OBJREC *m;
25 register RAY *r;
26 XF *bx;
27 {
28 extern double l_noise3(), l_noise3a(), l_noise3b(), l_noise3c();
29 extern double l_hermite(), l_fnoise3(), l_arg();
30 extern long eclock;
31 static char *initfile = "rayinit.cal";
32 static long lastrno = -1;
33 /* check to see if already set */
34 if (m == fobj && r->rno == lastrno)
35 return;
36 /* initialize if first call */
37 if (initfile != NULL) {
38 loadfunc(initfile);
39 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
40 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
41 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
42 scompile("T=$10;Rdot=$11;", NULL, 0);
43 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
44 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
45 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
46 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
47 funset("arg", 1, l_arg);
48 funset("noise3", 3, l_noise3);
49 funset("noise3a", 3, l_noise3a);
50 funset("noise3b", 3, l_noise3b);
51 funset("noise3c", 3, l_noise3c);
52 funset("hermite", 5, l_hermite);
53 funset("fnoise3", 3, l_fnoise3);
54 initfile = NULL;
55 }
56 fobj = m;
57 fray = r;
58 lastrno = r->rno;
59 if (r->rox != NULL) {
60 funcxf.sca = r->rox->b.sca * bx->sca;
61 multmat4(funcxf.xfm, r->rox->b.xfm, bx->xfm);
62 } else
63 copystruct(&funcxf, bx);
64 eclock++; /* notify expression evaluator */
65 }
66
67
68 setfunc(m, r) /* simplified interface to setmap */
69 register OBJREC *m;
70 RAY *r;
71 {
72 register XF *mxf;
73
74 if ((mxf = (XF *)m->os) == NULL) {
75 register int n;
76 register char **sa;
77
78 for (n = m->oargs.nsargs, sa = m->oargs.sarg;
79 n > 0 && **sa != '-'; n--, sa++)
80 ;
81 mxf = (XF *)malloc(sizeof(XF));
82 if (mxf == NULL)
83 goto memerr;
84 if (invxf(mxf, n, sa) != n)
85 objerror(m, USER, "bad transform");
86 if (mxf->sca < 0.0)
87 mxf->sca = -mxf->sca;
88 m->os = (char *)mxf;
89 }
90 setmap(m, r, mxf);
91 return;
92 memerr:
93 error(SYSTEM, "out of memory in setfunc");
94 }
95
96
97 loadfunc(fname) /* load definition file */
98 char *fname;
99 {
100 extern char *libpath; /* library search path */
101 char *ffname;
102
103 if ((ffname = getpath(fname, libpath, R_OK)) == NULL) {
104 sprintf(errmsg, "cannot find function file \"%s\"", fname);
105 error(USER, errmsg);
106 }
107 fcompile(ffname);
108 }
109
110
111 double
112 l_arg() /* return nth real argument */
113 {
114 extern double argument();
115 register int n;
116
117 n = argument(1) + .5; /* round to integer */
118
119 if (n < 1)
120 return(fobj->oargs.nfargs);
121
122 if (n > fobj->oargs.nfargs) {
123 sprintf(errmsg, "missing real argument %d", n);
124 objerror(fobj, USER, errmsg);
125 }
126 return(fobj->oargs.farg[n-1]);
127 }
128
129
130 double
131 chanvalue(n) /* return channel n to calcomp */
132 register int n;
133 {
134 double sum;
135 register RAY *r;
136
137 if (--n < 0)
138 goto badchan;
139
140 if (n < 3) /* ray direction */
141
142 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
143 fray->rdir[1]*funcxf.xfm[1][n] +
144 fray->rdir[2]*funcxf.xfm[2][n] )
145 / funcxf.sca );
146
147 if (n < 6) /* surface normal */
148
149 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
150 fray->ron[1]*funcxf.xfm[1][n-3] +
151 fray->ron[2]*funcxf.xfm[2][n-3] )
152 / funcxf.sca );
153
154 if (n < 9) /* intersection */
155
156 return( fray->rop[0]*funcxf.xfm[0][n-6] +
157 fray->rop[1]*funcxf.xfm[1][n-6] +
158 fray->rop[2]*funcxf.xfm[2][n-6] +
159 funcxf.xfm[3][n-6] );
160
161 if (n == 9) { /* distance */
162
163 sum = fray->rot;
164 for (r = fray->parent; r != NULL; r = r->parent)
165 sum += r->rot;
166 return(sum * funcxf.sca);
167
168 }
169 if (n == 10) /* dot product */
170 return(fray->rod);
171
172 if (n == 11) /* scale */
173 return(funcxf.sca);
174
175 if (n < 15) /* origin */
176 return(funcxf.xfm[3][n-12]);
177
178 if (n < 18) /* i unit vector */
179 return(funcxf.xfm[0][n-15] / funcxf.sca);
180
181 if (n < 21) /* j unit vector */
182 return(funcxf.xfm[1][n-15] / funcxf.sca);
183
184 if (n < 24) /* k unit vector */
185 return(funcxf.xfm[2][n-21] / funcxf.sca);
186 badchan:
187 error(USER, "illegal channel number");
188 }
