root/Development/ray/src/rt/func.c
Revision: 2.46
Committed: Sat Dec 6 04:13:14 2025 UTC (4 weeks ago) by greg
perf: Removed unnecessary call to doptimize(1) after every file load
2 static const char RCSid[] = "$Id: func.c,v 2.45 2025/11/13 18:57:20 greg Exp $";
5 * func.c - interface to calcomp functions.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "paths.h"
12 #include "otypes.h"
13 #include "func.h"
14 #include <ctype.h>
15
16
17 #define INITFILE "rayinit.cal"
18 #define CALSUF ".cal"
19 #define LCALSUF 4
20 char REFVNAME[] = "`FILE_REFCNT";
21
22 XF unitxf = { /* identity transform */
23 {{1.0, 0.0, 0.0, 0.0},
24 {0.0, 1.0, 0.0, 0.0},
25 {0.0, 0.0, 1.0, 0.0},
26 {0.0, 0.0, 0.0, 1.0}},
27 1.0
28 };
29
30 XF funcxf; /* current transformation */
31 static OBJREC *fobj = NULL; /* current function object */
32 static RAY *fray = NULL; /* current function ray */
33
34 static char rayinitcal[] = INITFILE;
35
36 static double l_erf(char *), l_erfc(char *), l_arg(char *);
37
38
39 void
40 initfunc(void) /* initialize function evaluation */
41 {
42 if (!rayinitcal[0]) /* already done? */
43 return;
44 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
45 esupport &= ~(E_OUTCHAN);
46 calcontext("");
47 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
48 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
49 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
50 scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
51 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
52 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
53 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
54 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
55 scompile("Lu=$26;Lv=$27;", NULL, 0);
56 funset("arg", 1, '=', l_arg);
57 funset("erf", 1, ':', l_erf);
58 funset("erfc", 1, ':', l_erfc);
59 setnoisefuncs();
60 setprismfuncs();
61 loadfunc(rayinitcal);
62 rayinitcal[0] = '\0';
63 doptimize(1); /* optimize definitions */
64 }
65
66
67 /* Set parameters for current evaluation */
68 void
69 set_eparams(const char *prms)
70 {
71 static const char *last_params = NULL;
72 char vname[RMAXWORD];
73 double value;
74 char *cpd;
75 /* check if already set */
76 if (prms == NULL || !*prms)
77 return;
78 if (prms == last_params || (last_params != NULL &&
79 !strcmp(prms, last_params)))
80 return;
81 last_params = prms; /* XXX assumes static string */
82 /* assign each variable */
83 while (*prms) {
84 if (isspace(*prms)) {
85 ++prms; continue;
86 }
87 if (!isalpha(*prms))
88 goto bad_params;
89 cpd = vname;
90 while (*prms && (*prms != '=') & !isspace(*prms)) {
91 if (!isid(*prms) | (cpd-vname >= RMAXWORD-1))
92 goto bad_params;
93 *cpd++ = *prms++;
94 }
95 *cpd = '\0';
96 while (isspace(*prms)) prms++;
97 if (*prms++ != '=')
98 goto bad_params;
99 value = atof(prms);
100 if ((prms = fskip((char *)prms)) == NULL)
101 goto bad_params;
102 while (isspace(*prms)) prms++;
103 prms += (*prms == ',') | (*prms == ';') | (*prms == ':');
104 varset(vname, '=', value);
105 }
106 eclock++; /* notify expression evaluator */
107 return;
108 bad_params:
109 sprintf(errmsg, "bad parameter list '%s'", last_params);
110 error(USER, errmsg);
111 }
112
113
114 MFUNC *
115 getfunc( /* get function for this modifier */
116 OBJREC *m,
117 int ff,
118 unsigned int ef,
119 int dofwd
120 )
121 {
122 char sbuf[MAXSTR];
123 char **arg;
124 MFUNC *f;
125 int ne, na;
126 int i;
127 /* check to see if done already */
128 if ((f = (MFUNC *)m->os) != NULL)
129 return(f);
130 fobj = NULL; fray = NULL;
131 if ((na = m->oargs.nsargs) <= ff)
132 goto toofew;
133 arg = m->oargs.sarg;
134 if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
135 goto memerr;
136 i = strlen(arg[ff]); /* set up context */
137 if (i == 1 && arg[ff][0] == '.') {
138 calcontext(f->ctx = ""); /* "." means no file */
139 } else {
140 strcpy(sbuf,arg[ff]); /* file name is context */
141 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
142 sbuf[i-LCALSUF] = '\0'; /* remove suffix */
143 calcontext(f->ctx = savestr(sbuf));
144 if (!vardefined(REFVNAME)) { /* file loaded? */
145 loadfunc(arg[ff]);
146 varset(REFVNAME, '=', 1.0);
147 } else /* reference_count++ */
148 varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
149 }
150 ecurfunc = NULL; /* parse expressions */
151 sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
152 for (i=0, ne=0; ef && i < na; i++, ef>>=1)
153 if (ef & 1) { /* flagged as an expression? */
154 if (ne >= MAXEXPR)
155 objerror(m, INTERNAL, "too many expressions");
156 initstr(arg[i], sbuf, 0);
157 f->ep[ne++] = getE1();
158 if (nextc != EOF)
159 esyntax("unexpected character");
160 }
161 if (ef)
162 goto toofew;
163 if (i <= ff) /* find transform args */
164 i = ff+1;
165 while (i < na && !isxfopt(arg[i]))
166 i++;
167 if (i == na) { /* no transform */
168 f->fxp = f->bxp = &unitxf;
169 } else { /* get transform */
170 if ((f->bxp = (XF *)malloc(sizeof(XF))) == NULL)
171 goto memerr;
172 if (invxf(f->bxp, na-i, arg+i) != na-i)
173 objerror(m, USER, "bad transform");
174 if (f->bxp->sca < 0.0)
175 f->bxp->sca = -f->bxp->sca;
176 if (dofwd) { /* do both transforms */
177 if ((f->fxp = (XF *)malloc(sizeof(XF))) == NULL)
178 goto memerr;
179 xf(f->fxp, na-i, arg+i);
180 if (f->fxp->sca < 0.0)
181 f->fxp->sca = -f->fxp->sca;
182 }
183 }
184 m->os = (char *)f;
185 return(f);
186 toofew:
187 objerror(m, USER, "too few string arguments");
188 memerr:
189 error(SYSTEM, "out of memory in getfunc");
190 return NULL; /* pro forma return */
191 }
192
193
194 void
195 freefunc( /* free memory associated with modifier */
196 OBJREC *m
197 )
198 {
199 MFUNC *f;
200 int i;
201
202 if ((f = (MFUNC *)m->os) == NULL)
203 return;
204 for (i = 0; f->ep[i] != NULL; i++)
205 epfree(f->ep[i],1);
206 if (f->ctx[0]) { /* done with definitions */
207 calcontext(f->ctx);
208 i = varvalue(REFVNAME)-.5; /* reference_count-- */
209 if (i > 0)
210 varset(REFVNAME, '=', (double)i);
211 else
212 dcleanup(2); /* remove definitions */
213 freestr(f->ctx);
214 }
215 if (f->bxp != &unitxf)
216 free((void *)f->bxp);
217 if ((f->fxp != NULL) & (f->fxp != &unitxf))
218 free((void *)f->fxp);
219 free((void *)f);
220 m->os = NULL;
221 }
222
223
224 int
225 setfunc( /* set channels for function call */
226 OBJREC *m,
227 RAY *r
228 )
229 {
230 static RNUMBER lastrno = ~0;
231 MFUNC *f;
232 /* get function if any */
233 if ((f = (MFUNC *)m->os) == NULL)
234 objerror(m, CONSISTENCY, "setfunc called before getfunc");
235
236 calcontext(f->ctx); /* set evaluator context */
237 /* check to see if matrix set */
238 if ((m == fobj) & (r->rno == lastrno))
239 return(0);
240 fobj = m;
241 fray = r;
242 if (r->rox != NULL) {
243 if (f->bxp != &unitxf) {
244 funcxf.sca = r->rox->b.sca * f->bxp->sca;
245 multmat4(funcxf.xfm, r->rox->b.xfm, f->bxp->xfm);
246 } else
247 funcxf = r->rox->b;
248 } else
249 funcxf = *f->bxp;
250 lastrno = r->rno;
251 eclock++; /* notify expression evaluator */
252 return(1);
253 }
254
255
256 int
257 worldfunc( /* special function context sans object */
258 const char *ctx,
259 RAY *r
260 )
261 {
262 static RNUMBER lastrno = ~0;
263 /* set evaluator context */
264 calcontext((char *)ctx);
265 /* check if ray already set */
266 if ((fobj == NULL) & (r->rno == lastrno))
267 return(0);
268 fobj = NULL;
269 fray = r;
270 funcxf = unitxf;
271 lastrno = r->rno;
272 eclock++; /* notify expression evaluator */
273 return(1);
274 }
275
276
277 void
278 loadfunc( /* load definition file */
279 char *fname
280 )
281 {
282 char *ffname;
283
284 if ((ffname = getpath(fname, getrlibpath(), R_OK)) == NULL) {
285 sprintf(errmsg, "cannot find function file \"%s\"", fname);
286 error(SYSTEM, errmsg);
287 }
288 fcompile(ffname);
289 }
290
291
292 static double
293 l_arg(char *nm) /* return nth real argument */
294 {
295 int n;
296
297 if (fobj == NULL)
298 error(USER,
299 "bad call to arg(n) - illegal constant in .cal file?");
300
301 n = argument(1) + .5; /* round to integer */
302
303 if (n < 1)
304 return(fobj->oargs.nfargs);
305
306 if (n > fobj->oargs.nfargs) {
307 sprintf(errmsg, "missing real argument %d", n);
308 objerror(fobj, USER, errmsg);
309 }
310 return(fobj->oargs.farg[n-1]);
311 }
312
313
314 static double
315 l_erf(char *nm) /* error function */
316 {
317 return(erf(argument(1)));
318 }
319
320
321 static double
322 l_erfc(char *nm) /* cumulative error function */
323 {
324 return(erfc(argument(1)));
325 }
326
327
328 double
329 chanvalue( /* return channel n to calcomp */
330 int n
331 )
332 {
333 if (fray == NULL)
334 esyntax("ray parameter used in constant expression");
335
336 if (--n < 0)
337 goto badchan;
338
339 if (n < 3) /* ray direction */
340
341 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
342 fray->rdir[1]*funcxf.xfm[1][n] +
343 fray->rdir[2]*funcxf.xfm[2][n] )
344 / funcxf.sca );
345
346 if (n < 6) /* surface normal */
347
348 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
349 fray->ron[1]*funcxf.xfm[1][n-3] +
350 fray->ron[2]*funcxf.xfm[2][n-3] )
351 / funcxf.sca );
352
353 if (n < 9) /* intersection point */
354
355 return( fray->rop[0]*funcxf.xfm[0][n-6] +
356 fray->rop[1]*funcxf.xfm[1][n-6] +
357 fray->rop[2]*funcxf.xfm[2][n-6] +
358 funcxf.xfm[3][n-6] );
359
360 if (n == 9) /* total distance */
361 return(raydist(fray,PRIMARY) * funcxf.sca);
362
363 if (n == 10) /* dot product (range [-1,1]) */
364 return( fray->rod <= -1.0 ? -1.0 :
365 fray->rod >= 1.0 ? 1.0 :
366 fray->rod );
367
368 if (n == 11) /* scale */
369 return(funcxf.sca);
370
371 if (n < 15) /* origin */
372 return(funcxf.xfm[3][n-12]);
373
374 if (n < 18) /* i unit vector */
375 return(funcxf.xfm[0][n-15] / funcxf.sca);
376
377 if (n < 21) /* j unit vector */
378 return(funcxf.xfm[1][n-18] / funcxf.sca);
379
380 if (n < 24) /* k unit vector */
381 return(funcxf.xfm[2][n-21] / funcxf.sca);
382
383 if (n == 24) /* single ray (shadow) distance */
384 return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca);
385
386 if (n < 27) /* local (u,v) coordinates */
387 return(fray->uv[n-25]);
388 badchan:
389 error(USER, "illegal channel number");
390 return(0.0);
391 }
