root/radiance/ray/src/rt/func.c
Revision: 2.39
Committed: Wed Mar 30 16:00:56 2022 UTC (3 years, 4 months ago) by greg
Changes since 2.38: +7 -7 lines
fix: Renamed setcontext() to calcontext() to avoid obscure macOS naming conflict
2 static const char RCSid[] = "$Id: func.c,v 2.38 2020/04/02 18:00:34 greg Exp $";
5 * func.c - interface to calcomp functions.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "paths.h"
12 #include "otypes.h"
13 #include "func.h"
14 #include <ctype.h>
15
16
17 #define INITFILE "rayinit.cal"
18 #define CALSUF ".cal"
19 #define LCALSUF 4
20 char REFVNAME[] = "`FILE_REFCNT";
21
22 XF unitxf = { /* identity transform */
23 {{1.0, 0.0, 0.0, 0.0},
24 {0.0, 1.0, 0.0, 0.0},
25 {0.0, 0.0, 1.0, 0.0},
26 {0.0, 0.0, 0.0, 1.0}},
27 1.0
28 };
29
30 XF funcxf; /* current transformation */
31 static OBJREC *fobj = NULL; /* current function object */
32 static RAY *fray = NULL; /* current function ray */
33
34 static char rayinitcal[] = INITFILE;
35
36 static double l_erf(char *), l_erfc(char *), l_arg(char *);
37
38
39 void
40 initfunc(void) /* initialize function evaluation */
41 {
42 if (!rayinitcal[0]) /* already done? */
43 return;
44 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
45 esupport &= ~(E_OUTCHAN);
46 calcontext("");
47 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
48 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
49 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
50 scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
51 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
52 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
53 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
54 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
55 scompile("Lu=$26;Lv=$27;", NULL, 0);
56 funset("arg", 1, '=', l_arg);
57 funset("erf", 1, ':', l_erf);
58 funset("erfc", 1, ':', l_erfc);
59 setnoisefuncs();
60 setprismfuncs();
61 loadfunc(rayinitcal);
62 rayinitcal[0] = '\0';
63 }
64
65
66 /* Set parameters for current evaluation */
67 void
68 set_eparams(char *prms)
69 {
70 static char *last_params = NULL;
71 char vname[RMAXWORD];
72 double value;
73 char *cpd;
74 /* check if already set */
75 if (prms == NULL || !*prms)
76 return;
77 if (prms == last_params || (last_params != NULL &&
78 !strcmp(prms, last_params)))
79 return;
80 last_params = prms; /* XXX assumes static string */
81 /* assign each variable */
82 while (*prms) {
83 if (isspace(*prms)) {
84 ++prms; continue;
85 }
86 if (!isalpha(*prms))
87 goto bad_params;
88 cpd = vname;
89 while (*prms && (*prms != '=') & !isspace(*prms)) {
90 if (!isid(*prms) | (cpd-vname >= RMAXWORD-1))
91 goto bad_params;
92 *cpd++ = *prms++;
93 }
94 *cpd = '\0';
95 while (isspace(*prms)) prms++;
96 if (*prms++ != '=')
97 goto bad_params;
98 value = atof(prms);
99 if ((prms = fskip(prms)) == NULL)
100 goto bad_params;
101 while (isspace(*prms)) prms++;
102 prms += (*prms == ',') | (*prms == ';') | (*prms == ':');
103 varset(vname, '=', value);
104 }
105 eclock++; /* notify expression evaluator */
106 return;
107 bad_params:
108 sprintf(errmsg, "bad parameter list '%s'", last_params);
109 error(USER, errmsg);
110 }
111
112
113 MFUNC *
114 getfunc( /* get function for this modifier */
115 OBJREC *m,
116 int ff,
117 unsigned int ef,
118 int dofwd
119 )
120 {
121 char sbuf[MAXSTR];
122 char **arg;
123 MFUNC *f;
124 int ne, na;
125 int i;
126 /* check to see if done already */
127 if ((f = (MFUNC *)m->os) != NULL)
128 return(f);
129 fobj = NULL; fray = NULL;
130 if (rayinitcal[0]) /* initialize on first call */
131 initfunc();
132 if ((na = m->oargs.nsargs) <= ff)
133 goto toofew;
134 arg = m->oargs.sarg;
135 if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
136 goto memerr;
137 i = strlen(arg[ff]); /* set up context */
138 if (i == 1 && arg[ff][0] == '.') {
139 calcontext(f->ctx = ""); /* "." means no file */
140 } else {
141 strcpy(sbuf,arg[ff]); /* file name is context */
142 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
143 sbuf[i-LCALSUF] = '\0'; /* remove suffix */
144 calcontext(f->ctx = savestr(sbuf));
145 if (!vardefined(REFVNAME)) { /* file loaded? */
146 loadfunc(arg[ff]);
147 varset(REFVNAME, '=', 1.0);
148 } else /* reference_count++ */
149 varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
150 }
151 curfunc = NULL; /* parse expressions */
152 sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
153 for (i=0, ne=0; ef && i < na; i++, ef>>=1)
154 if (ef & 1) { /* flagged as an expression? */
155 if (ne >= MAXEXPR)
156 objerror(m, INTERNAL, "too many expressions");
157 initstr(arg[i], sbuf, 0);
158 f->ep[ne++] = getE1();
159 if (nextc != EOF)
160 syntax("unexpected character");
161 }
162 if (ef)
163 goto toofew;
164 if (i <= ff) /* find transform args */
165 i = ff+1;
166 while (i < na && arg[i][0] != '-')
167 i++;
168 if (i == na) { /* no transform */
169 f->fxp = f->bxp = &unitxf;
170 } else { /* get transform */
171 if ((f->bxp = (XF *)malloc(sizeof(XF))) == NULL)
172 goto memerr;
173 if (invxf(f->bxp, na-i, arg+i) != na-i)
174 objerror(m, USER, "bad transform");
175 if (f->bxp->sca < 0.0)
176 f->bxp->sca = -f->bxp->sca;
177 if (dofwd) { /* do both transforms */
178 if ((f->fxp = (XF *)malloc(sizeof(XF))) == NULL)
179 goto memerr;
180 xf(f->fxp, na-i, arg+i);
181 if (f->fxp->sca < 0.0)
182 f->fxp->sca = -f->fxp->sca;
183 }
184 }
185 m->os = (char *)f;
186 return(f);
187 toofew:
188 objerror(m, USER, "too few string arguments");
189 memerr:
190 error(SYSTEM, "out of memory in getfunc");
191 return NULL; /* pro forma return */
192 }
193
194
195 void
196 freefunc( /* free memory associated with modifier */
197 OBJREC *m
198 )
199 {
200 MFUNC *f;
201 int i;
202
203 if ((f = (MFUNC *)m->os) == NULL)
204 return;
205 for (i = 0; f->ep[i] != NULL; i++)
206 epfree(f->ep[i]);
207 if (f->ctx[0]) { /* done with definitions */
208 calcontext(f->ctx);
209 i = varvalue(REFVNAME)-.5; /* reference_count-- */
210 if (i > 0)
211 varset(REFVNAME, '=', (double)i);
212 else
213 dcleanup(2); /* remove definitions */
214 freestr(f->ctx);
215 }
216 if (f->bxp != &unitxf)
217 free((void *)f->bxp);
218 if ((f->fxp != NULL) & (f->fxp != &unitxf))
219 free((void *)f->fxp);
220 free((void *)f);
221 m->os = NULL;
222 }
223
224
225 int
226 setfunc( /* set channels for function call */
227 OBJREC *m,
228 RAY *r
229 )
230 {
231 static RNUMBER lastrno = ~0;
232 MFUNC *f;
233 /* get function if any */
234 if ((f = (MFUNC *)m->os) == NULL)
235 objerror(m, CONSISTENCY, "setfunc called before getfunc");
236
237 calcontext(f->ctx); /* set evaluator context */
238 /* check to see if matrix set */
239 if ((m == fobj) & (r->rno == lastrno))
240 return(0);
241 fobj = m;
242 fray = r;
243 if (r->rox != NULL) {
244 if (f->bxp != &unitxf) {
245 funcxf.sca = r->rox->b.sca * f->bxp->sca;
246 multmat4(funcxf.xfm, r->rox->b.xfm, f->bxp->xfm);
247 } else
248 funcxf = r->rox->b;
249 } else
250 funcxf = *f->bxp;
251 lastrno = r->rno;
252 eclock++; /* notify expression evaluator */
253 return(1);
254 }
255
256
257 int
258 worldfunc( /* special function context sans object */
259 char *ctx,
260 RAY *r
261 )
262 {
263 static RNUMBER lastrno = ~0;
264
265 if (rayinitcal[0]) /* initialize on first call */
266 initfunc();
267 /* set evaluator context */
268 calcontext(ctx);
269 /* check if ray already set */
270 if ((fobj == NULL) & (r->rno == lastrno))
271 return(0);
272 fobj = NULL;
273 fray = r;
274 funcxf = unitxf;
275 lastrno = r->rno;
276 eclock++; /* notify expression evaluator */
277 return(1);
278 }
279
280
281 void
282 loadfunc( /* load definition file */
283 char *fname
284 )
285 {
286 char *ffname;
287
288 if ((ffname = getpath(fname, getrlibpath(), R_OK)) == NULL) {
289 sprintf(errmsg, "cannot find function file \"%s\"", fname);
290 error(SYSTEM, errmsg);
291 }
292 fcompile(ffname);
293 }
294
295
296 static double
297 l_arg(char *nm) /* return nth real argument */
298 {
299 int n;
300
301 if (fobj == NULL)
302 error(USER,
303 "bad call to arg(n) - illegal constant in .cal file?");
304
305 n = argument(1) + .5; /* round to integer */
306
307 if (n < 1)
308 return(fobj->oargs.nfargs);
309
310 if (n > fobj->oargs.nfargs) {
311 sprintf(errmsg, "missing real argument %d", n);
312 objerror(fobj, USER, errmsg);
313 }
314 return(fobj->oargs.farg[n-1]);
315 }
316
317
318 static double
319 l_erf(char *nm) /* error function */
320 {
321 return(erf(argument(1)));
322 }
323
324
325 static double
326 l_erfc(char *nm) /* cumulative error function */
327 {
328 return(erfc(argument(1)));
329 }
330
331
332 double
333 chanvalue( /* return channel n to calcomp */
334 int n
335 )
336 {
337 if (fray == NULL)
338 syntax("ray parameter used in constant expression");
339
340 if (--n < 0)
341 goto badchan;
342
343 if (n <= 2) /* ray direction */
344
345 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
346 fray->rdir[1]*funcxf.xfm[1][n] +
347 fray->rdir[2]*funcxf.xfm[2][n] )
348 / funcxf.sca );
349
350 if (n <= 5) /* surface normal */
351
352 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
353 fray->ron[1]*funcxf.xfm[1][n-3] +
354 fray->ron[2]*funcxf.xfm[2][n-3] )
355 / funcxf.sca );
356
357 if (n <= 8) { /* intersection point */
358 if (fray->rot >= FHUGE*.99)
359 return(0.0); /* XXX should be runtime error? */
360
361 return( fray->rop[0]*funcxf.xfm[0][n-6] +
362 fray->rop[1]*funcxf.xfm[1][n-6] +
363 fray->rop[2]*funcxf.xfm[2][n-6] +
364 funcxf.xfm[3][n-6] );
365 }
366
367 if (n == 9) /* total distance */
368 return(raydist(fray,PRIMARY) * funcxf.sca);
369
370 if (n == 10) /* dot product (range [-1,1]) */
371 return( fray->rod <= -1.0 ? -1.0 :
372 fray->rod >= 1.0 ? 1.0 :
373 fray->rod );
374
375 if (n == 11) /* scale */
376 return(funcxf.sca);
377
378 if (n <= 14) /* origin */
379 return(funcxf.xfm[3][n-12]);
380
381 if (n <= 17) /* i unit vector */
382 return(funcxf.xfm[0][n-15] / funcxf.sca);
383
384 if (n <= 20) /* j unit vector */
385 return(funcxf.xfm[1][n-18] / funcxf.sca);
386
387 if (n <= 23) /* k unit vector */
388 return(funcxf.xfm[2][n-21] / funcxf.sca);
389
390 if (n == 24) /* single ray (shadow) distance */
391 return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca);
392
393 if (n <= 26) /* local (u,v) coordinates */
394 return(fray->uv[n-25]);
395 badchan:
396 error(USER, "illegal channel number");
397 return(0.0);
398 }
