root/radiance/ray/src/rt/func.c
Revision: 2.26
Committed: Sat Jun 9 07:16:47 2012 UTC (13 years, 1 month ago) by greg
Changes since 2.25: +84 -56 lines
2 static const char RCSid[] = "$Id: func.c,v 2.25 2012/06/07 18:56:06 greg Exp $";
5 * func.c - interface to calcomp functions.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "paths.h"
12 #include "otypes.h"
13 #include "func.h"
14
15
16 #define INITFILE "rayinit.cal"
17 #define CALSUF ".cal"
18 #define LCALSUF 4
19 char REFVNAME[] = "`FILE_REFCNT";
20
21 XF unitxf = { /* identity transform */
22 {{1.0, 0.0, 0.0, 0.0},
23 {0.0, 1.0, 0.0, 0.0},
24 {0.0, 0.0, 1.0, 0.0},
25 {0.0, 0.0, 0.0, 1.0}},
26 1.0
27 };
28
29 XF funcxf; /* current transformation */
30 static OBJREC *fobj = NULL; /* current function object */
31 static RAY *fray = NULL; /* current function ray */
32
33 static char rayinitcal[] = INITFILE;
34
35 static double l_erf(char *), l_erfc(char *), l_arg(char *);
36
37
38 void
39 initfunc() /* initialize function evaluation */
40 {
41 if (!rayinitcal[0]) /* already done? */
42 return;
43 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
44 esupport &= ~(E_OUTCHAN);
45 setcontext("");
46 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
47 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
48 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
49 scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
50 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
51 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
52 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
53 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
54 scompile("Lu=$26;Lv=$27;", NULL, 0);
55 funset("arg", 1, '=', l_arg);
56 funset("erf", 1, ':', l_erf);
57 funset("erfc", 1, ':', l_erfc);
58 setnoisefuncs();
59 setprismfuncs();
60 loadfunc(rayinitcal);
61 rayinitcal[0] = '\0';
62 }
63
64
65 MFUNC *
66 getfunc( /* get function for this modifier */
67 OBJREC *m,
68 int ff,
69 unsigned int ef,
70 int dofwd
71 )
72 {
73 char sbuf[MAXSTR];
74 char **arg;
75 MFUNC *f;
76 int ne, na;
77 int i;
78 /* check to see if done already */
79 if ((f = (MFUNC *)m->os) != NULL)
80 return(f);
81 fobj = NULL; fray = NULL;
82 if (rayinitcal[0]) /* initialize on first call */
83 initfunc();
84 if ((na = m->oargs.nsargs) <= ff)
85 goto toofew;
86 arg = m->oargs.sarg;
87 if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
88 goto memerr;
89 i = strlen(arg[ff]); /* set up context */
90 if (i == 1 && arg[ff][0] == '.') {
91 setcontext(f->ctx = ""); /* "." means no file */
92 } else {
93 strcpy(sbuf,arg[ff]); /* file name is context */
94 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
95 sbuf[i-LCALSUF] = '\0'; /* remove suffix */
96 setcontext(f->ctx = savestr(sbuf));
97 if (!vardefined(REFVNAME)) { /* file loaded? */
98 loadfunc(arg[ff]);
99 varset(REFVNAME, '=', 1.0);
100 } else /* reference_count++ */
101 varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
102 }
103 curfunc = NULL; /* parse expressions */
104 sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
105 for (i=0, ne=0; ef && i < na; i++, ef>>=1)
106 if (ef & 1) { /* flagged as an expression? */
107 if (ne >= MAXEXPR)
108 objerror(m, INTERNAL, "too many expressions");
109 initstr(arg[i], sbuf, 0);
110 f->ep[ne++] = getE1();
111 if (nextc != EOF)
112 syntax("unexpected character");
113 }
114 if (ef)
115 goto toofew;
116 if (i <= ff) /* find transform args */
117 i = ff+1;
118 while (i < na && arg[i][0] != '-')
119 i++;
120 if (i == na) { /* no transform */
121 f->fxp = f->bxp = &unitxf;
122 } else { /* get transform */
123 if ((f->bxp = (XF *)malloc(sizeof(XF))) == NULL)
124 goto memerr;
125 if (invxf(f->bxp, na-i, arg+i) != na-i)
126 objerror(m, USER, "bad transform");
127 if (f->bxp->sca < 0.0)
128 f->bxp->sca = -f->bxp->sca;
129 if (dofwd) { /* do both transforms */
130 if ((f->fxp = (XF *)malloc(sizeof(XF))) == NULL)
131 goto memerr;
132 xf(f->fxp, na-i, arg+i);
133 if (f->fxp->sca < 0.0)
134 f->fxp->sca = -f->fxp->sca;
135 }
136 }
137 m->os = (char *)f;
138 return(f);
139 toofew:
140 objerror(m, USER, "too few string arguments");
141 memerr:
142 error(SYSTEM, "out of memory in getfunc");
143 return NULL; /* pro forma return */
144 }
145
146
147 void
148 freefunc( /* free memory associated with modifier */
149 OBJREC *m
150 )
151 {
152 MFUNC *f;
153 int i;
154
155 if ((f = (MFUNC *)m->os) == NULL)
156 return;
157 for (i = 0; f->ep[i] != NULL; i++)
158 epfree(f->ep[i]);
159 if (f->ctx[0]) { /* done with definitions */
160 setcontext(f->ctx);
161 i = varvalue(REFVNAME)-.5; /* reference_count-- */
162 if (i > 0)
163 varset(REFVNAME, '=', (double)i);
164 else
165 dcleanup(2); /* remove definitions */
166 freestr(f->ctx);
167 }
168 if (f->bxp != &unitxf)
169 free((void *)f->bxp);
170 if ((f->fxp != NULL) & (f->fxp != &unitxf))
171 free((void *)f->fxp);
172 free((void *)f);
173 m->os = NULL;
174 }
175
176
177 int
178 setfunc( /* set channels for function call */
179 OBJREC *m,
180 RAY *r
181 )
182 {
183 static RNUMBER lastrno = ~0;
184 MFUNC *f;
185 /* get function if any */
186 if ((f = (MFUNC *)m->os) == NULL)
187 objerror(m, CONSISTENCY, "setfunc called before getfunc");
188
189 setcontext(f->ctx); /* set evaluator context */
190 /* check to see if matrix set */
191 if ((m == fobj) & (r->rno == lastrno))
192 return(0);
193 fobj = m;
194 fray = r;
195 if (r->rox != NULL) {
196 if (f->bxp != &unitxf) {
197 funcxf.sca = r->rox->b.sca * f->bxp->sca;
198 multmat4(funcxf.xfm, r->rox->b.xfm, f->bxp->xfm);
199 } else
200 funcxf = r->rox->b;
201 } else
202 funcxf = *f->bxp;
203 lastrno = r->rno;
204 eclock++; /* notify expression evaluator */
205 return(1);
206 }
207
208
209 int
210 worldfunc( /* special function context sans object */
211 char *ctx,
212 RAY *r
213 )
214 {
215 static RNUMBER lastrno = ~0;
216 /* set evaluator context */
217 setcontext(ctx);
218 /* check if ray already set */
219 if ((fobj == NULL) & (r->rno == lastrno))
220 return(0);
221 fobj = NULL;
222 fray = r;
223 funcxf = unitxf;
224 lastrno = r->rno;
225 eclock++; /* notify expression evaluator */
226 return(1);
227 }
228
229
230 void
231 loadfunc( /* load definition file */
232 char *fname
233 )
234 {
235 char *ffname;
236
237 if ((ffname = getpath(fname, getrlibpath(), R_OK)) == NULL) {
238 sprintf(errmsg, "cannot find function file \"%s\"", fname);
239 error(USER, errmsg);
240 }
241 fcompile(ffname);
242 }
243
244
245 static double
246 l_arg(char *nm) /* return nth real argument */
247 {
248 int n;
249
250 if (fobj == NULL)
251 error(USER, "arg(n) called without a context");
252
253 n = argument(1) + .5; /* round to integer */
254
255 if (n < 1)
256 return(fobj->oargs.nfargs);
257
258 if (n > fobj->oargs.nfargs) {
259 sprintf(errmsg, "missing real argument %d", n);
260 objerror(fobj, USER, errmsg);
261 }
262 return(fobj->oargs.farg[n-1]);
263 }
264
265
266 static double
267 l_erf(char *nm) /* error function */
268 {
269 return(erf(argument(1)));
270 }
271
272
273 static double
274 l_erfc(char *nm) /* cumulative error function */
275 {
276 return(erfc(argument(1)));
277 }
278
279
280 double
281 chanvalue( /* return channel n to calcomp */
282 int n
283 )
284 {
285 if (fray == NULL)
286 syntax("ray parameter used in constant expression");
287
288 if (--n < 0)
289 goto badchan;
290
291 if (n <= 2) /* ray direction */
292
293 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
294 fray->rdir[1]*funcxf.xfm[1][n] +
295 fray->rdir[2]*funcxf.xfm[2][n] )
296 / funcxf.sca );
297
298 if (n <= 5) /* surface normal */
299
300 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
301 fray->ron[1]*funcxf.xfm[1][n-3] +
302 fray->ron[2]*funcxf.xfm[2][n-3] )
303 / funcxf.sca );
304
305 if (n <= 8) /* intersection */
306
307 return( fray->rop[0]*funcxf.xfm[0][n-6] +
308 fray->rop[1]*funcxf.xfm[1][n-6] +
309 fray->rop[2]*funcxf.xfm[2][n-6] +
310 funcxf.xfm[3][n-6] );
311
312 if (n == 9) /* total distance */
313 return(raydist(fray,PRIMARY) * funcxf.sca);
314
315 if (n == 10) /* dot product (range [-1,1]) */
316 return( fray->rod <= -1.0 ? -1.0 :
317 fray->rod >= 1.0 ? 1.0 :
318 fray->rod );
319
320 if (n == 11) /* scale */
321 return(funcxf.sca);
322
323 if (n <= 14) /* origin */
324 return(funcxf.xfm[3][n-12]);
325
326 if (n <= 17) /* i unit vector */
327 return(funcxf.xfm[0][n-15] / funcxf.sca);
328
329 if (n <= 20) /* j unit vector */
330 return(funcxf.xfm[1][n-18] / funcxf.sca);
331
332 if (n <= 23) /* k unit vector */
333 return(funcxf.xfm[2][n-21] / funcxf.sca);
334
335 if (n == 24) /* single ray (shadow) distance */
336 return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca);
337
338 if (n <= 26) /* local (u,v) coordinates */
339 return(fray->uv[n-25]);
340 badchan:
341 error(USER, "illegal channel number");
342 return(0.0);
343 }
