root/radiance/ray/src/rt/func.c
Revision: 2.24
Committed: Tue Feb 22 16:45:12 2011 UTC (14 years, 5 months ago) by greg
Changes since 2.23: +1 -3 lines
Fixed a few compile errors due to code reorg
2 static const char RCSid[] = "$Id: func.c,v 2.23 2009/12/12 00:03:42 greg Exp $";
5 * func.c - interface to calcomp functions.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "paths.h"
12 #include "otypes.h"
13 #include "func.h"
14
15
16 #define INITFILE "rayinit.cal"
17 #define CALSUF ".cal"
18 #define LCALSUF 4
19 char REFVNAME[] = "`FILE_REFCNT";
20
21 XF unitxf = { /* identity transform */
22 {{1.0, 0.0, 0.0, 0.0},
23 {0.0, 1.0, 0.0, 0.0},
24 {0.0, 0.0, 1.0, 0.0},
25 {0.0, 0.0, 0.0, 1.0}},
26 1.0
27 };
28
29 XF funcxf; /* current transformation */
30 static OBJREC *fobj = NULL; /* current function object */
31 static RAY *fray = NULL; /* current function ray */
32
33 static double l_erf(char *), l_erfc(char *), l_arg(char *);
34
35
36 extern MFUNC *
37 getfunc( /* get function for this modifier */
38 OBJREC *m,
39 int ff,
40 unsigned int ef,
41 int dofwd
42 )
43 {
44 static char initfile[] = INITFILE;
45 char sbuf[MAXSTR];
46 register char **arg;
47 register MFUNC *f;
48 int ne, na;
49 register int i;
50 /* check to see if done already */
51 if ((f = (MFUNC *)m->os) != NULL)
52 return(f);
53 fobj = NULL; fray = NULL;
54 if (initfile[0]) { /* initialize on first call */
55 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
56 esupport &= ~(E_OUTCHAN);
57 setcontext("");
58 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
59 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
60 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
61 scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
62 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
63 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
64 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
65 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
66 scompile("Lu=$26;Lv=$27;", NULL, 0);
67 funset("arg", 1, '=', l_arg);
68 funset("erf", 1, ':', l_erf);
69 funset("erfc", 1, ':', l_erfc);
70 setnoisefuncs();
71 setprismfuncs();
72 loadfunc(initfile);
73 initfile[0] = '\0';
74 }
75 if ((na = m->oargs.nsargs) <= ff)
76 goto toofew;
77 arg = m->oargs.sarg;
78 if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
79 goto memerr;
80 i = strlen(arg[ff]); /* set up context */
81 if (i == 1 && arg[ff][0] == '.')
82 setcontext(f->ctx = ""); /* "." means no file */
83 else {
84 strcpy(sbuf,arg[ff]); /* file name is context */
85 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
86 sbuf[i-LCALSUF] = '\0'; /* remove suffix */
87 setcontext(f->ctx = savestr(sbuf));
88 if (!vardefined(REFVNAME)) { /* file loaded? */
89 loadfunc(arg[ff]);
90 varset(REFVNAME, '=', 1.0);
91 } else /* reference_count++ */
92 varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
93 }
94 curfunc = NULL; /* parse expressions */
95 sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
96 for (i=0, ne=0; ef && i < na; i++, ef>>=1)
97 if (ef & 1) { /* flagged as an expression? */
98 if (ne >= MAXEXPR)
99 objerror(m, INTERNAL, "too many expressions");
100 initstr(arg[i], sbuf, 0);
101 f->ep[ne++] = getE1();
102 if (nextc != EOF)
103 syntax("unexpected character");
104 }
105 if (ef)
106 goto toofew;
107 if (i <= ff) /* find transform args */
108 i = ff+1;
109 while (i < na && arg[i][0] != '-')
110 i++;
111 if (i == na) /* no transform */
112 f->f = f->b = &unitxf;
113 else { /* get transform */
114 if ((f->b = (XF *)malloc(sizeof(XF))) == NULL)
115 goto memerr;
116 if (invxf(f->b, na-i, arg+i) != na-i)
117 objerror(m, USER, "bad transform");
118 if (f->b->sca < 0.0)
119 f->b->sca = -f->b->sca;
120 if (dofwd) { /* do both transforms */
121 if ((f->f = (XF *)malloc(sizeof(XF))) == NULL)
122 goto memerr;
123 xf(f->f, na-i, arg+i);
124 if (f->f->sca < 0.0)
125 f->f->sca = -f->f->sca;
126 }
127 }
128 m->os = (char *)f;
129 return(f);
130 toofew:
131 objerror(m, USER, "too few string arguments");
132 memerr:
133 error(SYSTEM, "out of memory in getfunc");
134 return NULL; /* pro forma return */
135 }
136
137
138 extern void
139 freefunc( /* free memory associated with modifier */
140 OBJREC *m
141 )
142 {
143 register MFUNC *f;
144 register int i;
145
146 if ((f = (MFUNC *)m->os) == NULL)
147 return;
148 for (i = 0; f->ep[i] != NULL; i++)
149 epfree(f->ep[i]);
150 if (f->ctx[0]) { /* done with definitions */
151 setcontext(f->ctx);
152 i = varvalue(REFVNAME)-.5; /* reference_count-- */
153 if (i > 0)
154 varset(REFVNAME, '=', (double)i);
155 else
156 dcleanup(2); /* remove definitions */
157 freestr(f->ctx);
158 }
159 if (f->b != &unitxf)
160 free((void *)f->b);
161 if (f->f != NULL && f->f != &unitxf)
162 free((void *)f->f);
163 free((void *)f);
164 m->os = NULL;
165 }
166
167
168 extern int
169 setfunc( /* set channels for function call */
170 OBJREC *m,
171 register RAY *r
172 )
173 {
174 static RNUMBER lastrno = ~0;
175 register MFUNC *f;
176 /* get function */
177 if ((f = (MFUNC *)m->os) == NULL)
178 objerror(m, CONSISTENCY, "setfunc called before getfunc");
179 /* set evaluator context */
180 setcontext(f->ctx);
181 /* check to see if matrix set */
182 if (m == fobj && r->rno == lastrno)
183 return(0);
184 fobj = m;
185 fray = r;
186 if (r->rox != NULL)
187 if (f->b != &unitxf) {
188 funcxf.sca = r->rox->b.sca * f->b->sca;
189 multmat4(funcxf.xfm, r->rox->b.xfm, f->b->xfm);
190 } else
191 funcxf = r->rox->b;
192 else
193 funcxf = *(f->b);
194 lastrno = r->rno;
195 eclock++; /* notify expression evaluator */
196 return(1);
197 }
198
199
200 extern void
201 loadfunc( /* load definition file */
202 char *fname
203 )
204 {
205 char *ffname;
206
207 if ((ffname = getpath(fname, getrlibpath(), R_OK)) == NULL) {
208 sprintf(errmsg, "cannot find function file \"%s\"", fname);
209 error(USER, errmsg);
210 }
211 fcompile(ffname);
212 }
213
214
215 static double
216 l_arg(char *nm) /* return nth real argument */
217 {
218 register int n;
219
220 if (fobj == NULL)
221 syntax("arg(n) used in constant expression");
222
223 n = argument(1) + .5; /* round to integer */
224
225 if (n < 1)
226 return(fobj->oargs.nfargs);
227
228 if (n > fobj->oargs.nfargs) {
229 sprintf(errmsg, "missing real argument %d", n);
230 objerror(fobj, USER, errmsg);
231 }
232 return(fobj->oargs.farg[n-1]);
233 }
234
235
236 static double
237 l_erf(char *nm) /* error function */
238 {
239 return(erf(argument(1)));
240 }
241
242
243 static double
244 l_erfc(char *nm) /* cumulative error function */
245 {
246 return(erfc(argument(1)));
247 }
248
249
250 extern double
251 chanvalue( /* return channel n to calcomp */
252 register int n
253 )
254 {
255 if (fray == NULL)
256 syntax("ray parameter used in constant expression");
257
258 if (--n < 0)
259 goto badchan;
260
261 if (n <= 2) /* ray direction */
262
263 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
264 fray->rdir[1]*funcxf.xfm[1][n] +
265 fray->rdir[2]*funcxf.xfm[2][n] )
266 / funcxf.sca );
267
268 if (n <= 5) /* surface normal */
269
270 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
271 fray->ron[1]*funcxf.xfm[1][n-3] +
272 fray->ron[2]*funcxf.xfm[2][n-3] )
273 / funcxf.sca );
274
275 if (n <= 8) /* intersection */
276
277 return( fray->rop[0]*funcxf.xfm[0][n-6] +
278 fray->rop[1]*funcxf.xfm[1][n-6] +
279 fray->rop[2]*funcxf.xfm[2][n-6] +
280 funcxf.xfm[3][n-6] );
281
282 if (n == 9) /* total distance */
283 return(raydist(fray,PRIMARY) * funcxf.sca);
284
285 if (n == 10) /* dot product (range [-1,1]) */
286 return( fray->rod <= -1.0 ? -1.0 :
287 fray->rod >= 1.0 ? 1.0 :
288 fray->rod );
289
290 if (n == 11) /* scale */
291 return(funcxf.sca);
292
293 if (n <= 14) /* origin */
294 return(funcxf.xfm[3][n-12]);
295
296 if (n <= 17) /* i unit vector */
297 return(funcxf.xfm[0][n-15] / funcxf.sca);
298
299 if (n <= 20) /* j unit vector */
300 return(funcxf.xfm[1][n-18] / funcxf.sca);
301
302 if (n <= 23) /* k unit vector */
303 return(funcxf.xfm[2][n-21] / funcxf.sca);
304
305 if (n == 24) /* single ray (shadow) distance */
306 return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca);
307
308 if (n <= 26) /* local (u,v) coordinates */
309 return(fray->uv[n-25]);
310 badchan:
311 error(USER, "illegal channel number");
312 return(0.0);
313 }
