root/radiance/ray/src/rt/func.c
Revision: 1.1
Committed: Thu Feb 2 10:41:23 1989 UTC (36 years, 5 months ago) by greg
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * func.c - interface to calcomp functions.
9 *
10 * 4/7/86
11 */
12
13 #include "ray.h"
14
15 #include "otypes.h"
16
17
18 typedef struct {
19 double sca; /* scalefactor */
20 double xfm[4][4]; /* transform matrix */
21 } XF;
22
23 static OBJREC *fobj; /* current function object */
24 static RAY *fray; /* current function ray */
25 static XF fxf; /* current transformation */
26
27
28 setmap(m, r, sca, xfm) /* set channels for function call */
29 OBJREC *m;
30 register RAY *r;
31 double sca;
32 double xfm[4][4];
33 {
34 extern double l_noise3(), l_noise3a(), l_noise3b(), l_noise3c();
35 extern double l_hermite(), l_fnoise3(), l_arg();
36 extern long eclock;
37 static char *initfile = "rayinit.cal";
38
39 if (initfile != NULL) {
40 loadfunc(initfile);
41 scompile(NULL, "Dx=$1;Dy=$2;Dz=$3;");
42 scompile(NULL, "Nx=$4;Ny=$5;Nz=$6;");
43 scompile(NULL, "Px=$7;Py=$8;Pz=$9;");
44 scompile(NULL, "T=$10;Rdot=$11;");
45 funset("arg", 1, l_arg);
46 funset("noise3", 3, l_noise3);
47 funset("noise3a", 3, l_noise3a);
48 funset("noise3b", 3, l_noise3b);
49 funset("noise3c", 3, l_noise3c);
50 funset("hermite", 5, l_hermite);
51 funset("fnoise3", 3, l_fnoise3);
52 initfile = NULL;
53 }
54 fobj = m;
55 fray = r;
56 fxf.sca = r->ros * sca;
57 multmat4(fxf.xfm, r->rox, xfm);
58 eclock++; /* notify expression evaluator */
59 }
60
61
62 setfunc(m, r) /* simplified interface to setmap */
63 register OBJREC *m;
64 RAY *r;
65 {
66 #define mxf ((XF *)m->os)
67
68 if (mxf == NULL) {
69 register int n = m->oargs.nsargs;
70 register char **sa = m->oargs.sarg;
71
72 while (n > 0 && **sa != '-') {
73 n--;
74 sa++;
75 }
76 mxf = (XF *)malloc(sizeof(XF));
77 if (mxf == NULL)
78 goto memerr;
79 mxf->sca = 1.0;
80 setident4(mxf->xfm);
81 if (invxf(mxf->xfm, &mxf->sca, n, sa) != n)
82 objerror(m, USER, "bad transform");
83 if (mxf->sca < 0.0)
84 mxf->sca = -mxf->sca;
85 }
86 setmap(m, r, mxf->sca, mxf->xfm);
87 return;
88 memerr:
89 error(SYSTEM, "out of memory in setfunc");
90 #undef mxf
91 }
92
93
94 loadfunc(fname) /* load definition file */
95 char *fname;
96 {
97 extern char *libpath; /* library search path */
98 char *ffname;
99
100 if ((ffname = getpath(fname, libpath)) == NULL) {
101 sprintf(errmsg, "cannot find function file \"%s\"", fname);
102 error(USER, errmsg);
103 }
104 fcompile(ffname);
105 }
106
107
108 double
109 l_arg() /* return nth real argument */
110 {
111 extern double argument();
112 register int n;
113
114 n = argument(1) + .5; /* round to integer */
115
116 if (n < 1)
117 return(fobj->oargs.nfargs);
118
119 if (n > fobj->oargs.nfargs) {
120 sprintf(errmsg, "missing real argument %d", n);
121 objerror(fobj, USER, errmsg);
122 }
123 return(fobj->oargs.farg[n-1]);
124 }
125
126
127 double
128 chanvalue(n) /* return channel n to calcomp */
129 register int n;
130 {
131 double res;
132 register RAY *r;
133
134 n--; /* for convenience */
135
136 if (n < 0 || n > 10)
137 error(USER, "illegal channel number");
138
139 if (n == 9) { /* distance */
140
141 res = fray->rot;
142 for (r = fray->parent; r != NULL; r = r->parent)
143 res += r->rot;
144 res *= fxf.sca;
145
146 } else if (n == 10) { /* dot product */
147
148 res = fray->rod;
149
150 } else if (n < 3) { /* ray direction */
151 res = ( fray->rdir[0]*fxf.xfm[0][n] +
152 fray->rdir[1]*fxf.xfm[1][n] +
153 fray->rdir[2]*fxf.xfm[2][n] )
154 / fxf.sca ;
155 } else if (n < 6) { /* surface normal */
156 res = ( fray->ron[0]*fxf.xfm[0][n-3] +
157 fray->ron[1]*fxf.xfm[1][n-3] +
158 fray->ron[2]*fxf.xfm[2][n-3] )
159 / fxf.sca ;
160 } else { /* intersection */
161 res = fray->rop[0]*fxf.xfm[0][n-6] +
162 fray->rop[1]*fxf.xfm[1][n-6] +
163 fray->rop[2]*fxf.xfm[2][n-6] +
164 fxf.xfm[3][n-6] ;
165 }
166
167 return(res);
168 }
