root/radiance/ray/src/rt/func.c
Revision: 2.11
Committed: Wed Sep 29 10:39:40 1993 UTC (31 years, 9 months ago) by greg
Changes since 2.10: +1 -0 lines
added fprism
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * func.c - interface to calcomp functions.
9 *
10 * 4/7/86
11 */
12
13 #include "ray.h"
14
15 #include "otypes.h"
16
17 #include "func.h"
18
19
20 #define INITFILE "rayinit.cal"
21 #define CALSUF ".cal"
22 #define LCALSUF 4
23 char REFVNAME[] = "`FILE_REFCNT";
24
25 XF unitxf = { /* identity transform */
26 {{1.0, 0.0, 0.0, 0.0},
27 {0.0, 1.0, 0.0, 0.0},
28 {0.0, 0.0, 1.0, 0.0},
29 {0.0, 0.0, 0.0, 1.0}},
30 1.0
31 };
32
33 XF funcxf; /* current transformation */
34 static OBJREC *fobj = NULL; /* current function object */
35 static RAY *fray = NULL; /* current function ray */
36
37 static double l_erf(), l_erfc(), l_arg();
38
39
40 MFUNC *
41 getfunc(m, ff, ef, dofwd) /* get function for this modifier */
42 OBJREC *m;
43 int ff;
44 unsigned ef;
45 int dofwd;
46 {
47 extern EPNODE *curfunc;
48 static char initfile[] = INITFILE;
49 char sbuf[MAXSTR];
50 register char **arg;
51 register MFUNC *f;
52 int ne, na;
53 register int i;
54 /* check to see if done already */
55 if ((f = (MFUNC *)m->os) != NULL)
56 return(f);
57 fobj = NULL; fray = NULL;
58 if (initfile[0]) { /* initialize on first call */
59 setcontext("");
60 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
61 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
62 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
63 scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
64 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
65 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
66 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
67 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
68 funset("arg", 1, '=', l_arg);
69 funset("erf", 1, ':', l_erf);
70 funset("erfc", 1, ':', l_erfc);
71 setnoisefuncs();
72 setprismfuncs();
73 loadfunc(initfile);
74 initfile[0] = '\0';
75 }
76 if ((na = m->oargs.nsargs) <= ff)
77 goto toofew;
78 arg = m->oargs.sarg;
79 if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
80 goto memerr;
81 i = strlen(arg[ff]); /* set up context */
82 if (i == 1 && arg[ff][0] == '.')
83 setcontext(f->ctx = ""); /* "." means no file */
84 else {
85 strcpy(sbuf,arg[ff]); /* file name is context */
86 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
87 sbuf[i-LCALSUF] = '\0'; /* remove suffix */
88 setcontext(f->ctx = savestr(sbuf));
89 if (!vardefined(REFVNAME)) { /* file loaded? */
90 loadfunc(arg[ff]);
91 varset(REFVNAME, '=', 1.0);
92 } else /* reference_count++ */
93 varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
94 }
95 curfunc = NULL; /* parse expressions */
96 sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
97 for (i=0, ne=0; ef && i < na; i++, ef>>=1)
98 if (ef & 1) { /* flagged as an expression? */
99 if (ne >= MAXEXPR)
100 objerror(m, INTERNAL, "too many expressions");
101 initstr(arg[i], sbuf, 0);
102 f->ep[ne++] = getE1();
103 if (nextc != EOF)
104 syntax("unexpected character");
105 }
106 if (ef)
107 goto toofew;
108 if (i <= ff) /* find transform args */
109 i = ff+1;
110 while (i < na && arg[i][0] != '-')
111 i++;
112 if (i == na) /* no transform */
113 f->f = f->b = &unitxf;
114 else { /* get transform */
115 if ((f->b = (XF *)malloc(sizeof(XF))) == NULL)
116 goto memerr;
117 if (invxf(f->b, na-i, arg+i) != na-i)
118 objerror(m, USER, "bad transform");
119 if (f->b->sca < 0.0)
120 f->b->sca = -f->b->sca;
121 if (dofwd) { /* do both transforms */
122 if ((f->f = (XF *)malloc(sizeof(XF))) == NULL)
123 goto memerr;
124 xf(f->f, na-i, arg+i);
125 if (f->f->sca < 0.0)
126 f->f->sca = -f->f->sca;
127 }
128 }
129 m->os = (char *)f;
130 return(f);
131 toofew:
132 objerror(m, USER, "too few string arguments");
133 memerr:
134 error(SYSTEM, "out of memory in getfunc");
135 }
136
137
138 freefunc(m) /* free memory associated with modifier */
139 OBJREC *m;
140 {
141 register MFUNC *f;
142 register int i;
143
144 if ((f = (MFUNC *)m->os) == NULL)
145 return;
146 for (i = 0; f->ep[i] != NULL; i++)
147 epfree(f->ep[i]);
148 if (f->ctx[0]) { /* done with definitions */
149 setcontext(f->ctx);
150 i = varvalue(REFVNAME)-.5; /* reference_count-- */
151 if (i > 0)
152 varset(REFVNAME, '=', (double)i);
153 else
154 dcleanup(2); /* remove definitions */
155 freestr(f->ctx);
156 }
157 if (f->b != &unitxf)
158 free((char *)f->b);
159 if (f->f != NULL && f->f != &unitxf)
160 free((char *)f->f);
161 free((char *)f);
162 m->os = NULL;
163 }
164
165
166 setfunc(m, r) /* set channels for function call */
167 OBJREC *m;
168 register RAY *r;
169 {
170 static unsigned long lastrno = ~0;
171 register MFUNC *f;
172 /* get function */
173 if ((f = (MFUNC *)m->os) == NULL)
174 error(m, CONSISTENCY, "setfunc called before getfunc");
175 /* set evaluator context */
176 setcontext(f->ctx);
177 /* check to see if matrix set */
178 if (m == fobj && r->rno == lastrno)
179 return(0);
180 fobj = m;
181 fray = r;
182 if (r->rox != NULL)
183 if (f->b != &unitxf) {
184 funcxf.sca = r->rox->b.sca * f->b->sca;
185 multmat4(funcxf.xfm, r->rox->b.xfm, f->b->xfm);
186 } else
187 copystruct(&funcxf, &r->rox->b);
188 else
189 copystruct(&funcxf, f->b);
190 lastrno = r->rno;
191 eclock++; /* notify expression evaluator */
192 return(1);
193 }
194
195
196 loadfunc(fname) /* load definition file */
197 char *fname;
198 {
199 extern char *libpath; /* library search path */
200 char *ffname;
201
202 if ((ffname = getpath(fname, libpath, R_OK)) == NULL) {
203 sprintf(errmsg, "cannot find function file \"%s\"", fname);
204 error(USER, errmsg);
205 }
206 fcompile(ffname);
207 }
208
209
210 static double
211 l_arg() /* return nth real argument */
212 {
213 extern double argument();
214 register int n;
215
216 if (fobj == NULL)
217 syntax("arg(n) used in constant expression");
218
219 n = argument(1) + .5; /* round to integer */
220
221 if (n < 1)
222 return(fobj->oargs.nfargs);
223
224 if (n > fobj->oargs.nfargs) {
225 sprintf(errmsg, "missing real argument %d", n);
226 objerror(fobj, USER, errmsg);
227 }
228 return(fobj->oargs.farg[n-1]);
229 }
230
231
232 static double
233 l_erf() /* error function */
234 {
235 extern double erf();
236
237 return(erf(argument(1)));
238 }
239
240
241 static double
242 l_erfc() /* cumulative error function */
243 {
244 extern double erfc();
245
246 return(erfc(argument(1)));
247 }
248
249
250 double
251 chanvalue(n) /* return channel n to calcomp */
252 register int n;
253 {
254 double sum;
255 register RAY *r;
256
257 if (fray == NULL)
258 syntax("ray parameter used in constant expression");
259
260 if (--n < 0)
261 goto badchan;
262
263 if (n < 3) /* ray direction */
264
265 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
266 fray->rdir[1]*funcxf.xfm[1][n] +
267 fray->rdir[2]*funcxf.xfm[2][n] )
268 / funcxf.sca );
269
270 if (n < 6) /* surface normal */
271
272 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
273 fray->ron[1]*funcxf.xfm[1][n-3] +
274 fray->ron[2]*funcxf.xfm[2][n-3] )
275 / funcxf.sca );
276
277 if (n < 9) /* intersection */
278
279 return( fray->rop[0]*funcxf.xfm[0][n-6] +
280 fray->rop[1]*funcxf.xfm[1][n-6] +
281 fray->rop[2]*funcxf.xfm[2][n-6] +
282 funcxf.xfm[3][n-6] );
283
284 if (n == 9) { /* total distance */
285 sum = fray->rot;
286 for (r = fray->parent; r != NULL; r = r->parent)
287 sum += r->rot;
288 return(sum * funcxf.sca);
289
290 }
291
292 if (n == 10) /* dot product (range [-1,1]) */
293 return( fray->rod <= -1.0 ? -1.0 :
294 fray->rod >= 1.0 ? 1.0 :
295 fray->rod );
296
297 if (n == 11) /* scale */
298 return(funcxf.sca);
299
300 if (n < 15) /* origin */
301 return(funcxf.xfm[3][n-12]);
302
303 if (n < 18) /* i unit vector */
304 return(funcxf.xfm[0][n-15] / funcxf.sca);
305
306 if (n < 21) /* j unit vector */
307 return(funcxf.xfm[1][n-15] / funcxf.sca);
308
309 if (n < 24) /* k unit vector */
310 return(funcxf.xfm[2][n-21] / funcxf.sca);
311
312 if (n == 24) { /* single ray (shadow) distance */
313 sum = fray->rot;
314 for (r = fray->parent; r != NULL && r->crtype&SHADOW;
315 r = r->parent)
316 sum += r->rot;
317 return(sum * funcxf.sca);
318 }
319 badchan:
320 error(USER, "illegal channel number");
321 }
