root/radiance/ray/src/rt/func.c
Revision: 2.43
Committed: Tue Apr 22 17:12:25 2025 UTC (6 weeks, 2 days ago) by greg
Changes since 2.42: +1 -6 lines
2 static const char RCSid[] = "$Id: func.c,v 2.42 2024/10/29 00:36:54 greg Exp $";
5 * func.c - interface to calcomp functions.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "paths.h"
12 #include "otypes.h"
13 #include "func.h"
14 #include <ctype.h>
15
16
17 #define INITFILE "rayinit.cal"
18 #define CALSUF ".cal"
19 #define LCALSUF 4
20 char REFVNAME[] = "`FILE_REFCNT";
21
22 XF unitxf = { /* identity transform */
23 {{1.0, 0.0, 0.0, 0.0},
24 {0.0, 1.0, 0.0, 0.0},
25 {0.0, 0.0, 1.0, 0.0},
26 {0.0, 0.0, 0.0, 1.0}},
27 1.0
28 };
29
30 XF funcxf; /* current transformation */
31 static OBJREC *fobj = NULL; /* current function object */
32 static RAY *fray = NULL; /* current function ray */
33
34 static char rayinitcal[] = INITFILE;
35
36 static double l_erf(char *), l_erfc(char *), l_arg(char *);
37
38
39 void
40 initfunc(void) /* initialize function evaluation */
41 {
42 if (!rayinitcal[0]) /* already done? */
43 return;
44 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
45 esupport &= ~(E_OUTCHAN);
46 calcontext("");
47 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
48 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
49 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
50 scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
51 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
52 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
53 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
54 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
55 scompile("Lu=$26;Lv=$27;", NULL, 0);
56 funset("arg", 1, '=', l_arg);
57 funset("erf", 1, ':', l_erf);
58 funset("erfc", 1, ':', l_erfc);
59 setnoisefuncs();
60 setprismfuncs();
61 loadfunc(rayinitcal);
62 rayinitcal[0] = '\0';
63 }
64
65
66 /* Set parameters for current evaluation */
67 void
68 set_eparams(const char *prms)
69 {
70 static const char *last_params = NULL;
71 char vname[RMAXWORD];
72 double value;
73 char *cpd;
74 /* check if already set */
75 if (prms == NULL || !*prms)
76 return;
77 if (prms == last_params || (last_params != NULL &&
78 !strcmp(prms, last_params)))
79 return;
80 last_params = prms; /* XXX assumes static string */
81 /* assign each variable */
82 while (*prms) {
83 if (isspace(*prms)) {
84 ++prms; continue;
85 }
86 if (!isalpha(*prms))
87 goto bad_params;
88 cpd = vname;
89 while (*prms && (*prms != '=') & !isspace(*prms)) {
90 if (!isid(*prms) | (cpd-vname >= RMAXWORD-1))
91 goto bad_params;
92 *cpd++ = *prms++;
93 }
94 *cpd = '\0';
95 while (isspace(*prms)) prms++;
96 if (*prms++ != '=')
97 goto bad_params;
98 value = atof(prms);
99 if ((prms = fskip((char *)prms)) == NULL)
100 goto bad_params;
101 while (isspace(*prms)) prms++;
102 prms += (*prms == ',') | (*prms == ';') | (*prms == ':');
103 varset(vname, '=', value);
104 }
105 eclock++; /* notify expression evaluator */
106 return;
107 bad_params:
108 sprintf(errmsg, "bad parameter list '%s'", last_params);
109 error(USER, errmsg);
110 }
111
112
113 MFUNC *
114 getfunc( /* get function for this modifier */
115 OBJREC *m,
116 int ff,
117 unsigned int ef,
118 int dofwd
119 )
120 {
121 char sbuf[MAXSTR];
122 char **arg;
123 MFUNC *f;
124 int ne, na;
125 int i;
126 /* check to see if done already */
127 if ((f = (MFUNC *)m->os) != NULL)
128 return(f);
129 fobj = NULL; fray = NULL;
130 if ((na = m->oargs.nsargs) <= ff)
131 goto toofew;
132 arg = m->oargs.sarg;
133 if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
134 goto memerr;
135 i = strlen(arg[ff]); /* set up context */
136 if (i == 1 && arg[ff][0] == '.') {
137 calcontext(f->ctx = ""); /* "." means no file */
138 } else {
139 strcpy(sbuf,arg[ff]); /* file name is context */
140 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
141 sbuf[i-LCALSUF] = '\0'; /* remove suffix */
142 calcontext(f->ctx = savestr(sbuf));
143 if (!vardefined(REFVNAME)) { /* file loaded? */
144 loadfunc(arg[ff]);
145 varset(REFVNAME, '=', 1.0);
146 } else /* reference_count++ */
147 varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
148 }
149 ecurfunc = NULL; /* parse expressions */
150 sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
151 for (i=0, ne=0; ef && i < na; i++, ef>>=1)
152 if (ef & 1) { /* flagged as an expression? */
153 if (ne >= MAXEXPR)
154 objerror(m, INTERNAL, "too many expressions");
155 initstr(arg[i], sbuf, 0);
156 f->ep[ne++] = getE1();
157 if (nextc != EOF)
158 esyntax("unexpected character");
159 }
160 if (ef)
161 goto toofew;
162 if (i <= ff) /* find transform args */
163 i = ff+1;
164 while (i < na && arg[i][0] != '-')
165 i++;
166 if (i == na) { /* no transform */
167 f->fxp = f->bxp = &unitxf;
168 } else { /* get transform */
169 if ((f->bxp = (XF *)malloc(sizeof(XF))) == NULL)
170 goto memerr;
171 if (invxf(f->bxp, na-i, arg+i) != na-i)
172 objerror(m, USER, "bad transform");
173 if (f->bxp->sca < 0.0)
174 f->bxp->sca = -f->bxp->sca;
175 if (dofwd) { /* do both transforms */
176 if ((f->fxp = (XF *)malloc(sizeof(XF))) == NULL)
177 goto memerr;
178 xf(f->fxp, na-i, arg+i);
179 if (f->fxp->sca < 0.0)
180 f->fxp->sca = -f->fxp->sca;
181 }
182 }
183 m->os = (char *)f;
184 return(f);
185 toofew:
186 objerror(m, USER, "too few string arguments");
187 memerr:
188 error(SYSTEM, "out of memory in getfunc");
189 return NULL; /* pro forma return */
190 }
191
192
193 void
194 freefunc( /* free memory associated with modifier */
195 OBJREC *m
196 )
197 {
198 MFUNC *f;
199 int i;
200
201 if ((f = (MFUNC *)m->os) == NULL)
202 return;
203 for (i = 0; f->ep[i] != NULL; i++)
204 epfree(f->ep[i],1);
205 if (f->ctx[0]) { /* done with definitions */
206 calcontext(f->ctx);
207 i = varvalue(REFVNAME)-.5; /* reference_count-- */
208 if (i > 0)
209 varset(REFVNAME, '=', (double)i);
210 else
211 dcleanup(2); /* remove definitions */
212 freestr(f->ctx);
213 }
214 if (f->bxp != &unitxf)
215 free((void *)f->bxp);
216 if ((f->fxp != NULL) & (f->fxp != &unitxf))
217 free((void *)f->fxp);
218 free((void *)f);
219 m->os = NULL;
220 }
221
222
223 int
224 setfunc( /* set channels for function call */
225 OBJREC *m,
226 RAY *r
227 )
228 {
229 static RNUMBER lastrno = ~0;
230 MFUNC *f;
231 /* get function if any */
232 if ((f = (MFUNC *)m->os) == NULL)
233 objerror(m, CONSISTENCY, "setfunc called before getfunc");
234
235 calcontext(f->ctx); /* set evaluator context */
236 /* check to see if matrix set */
237 if ((m == fobj) & (r->rno == lastrno))
238 return(0);
239 fobj = m;
240 fray = r;
241 if (r->rox != NULL) {
242 if (f->bxp != &unitxf) {
243 funcxf.sca = r->rox->b.sca * f->bxp->sca;
244 multmat4(funcxf.xfm, r->rox->b.xfm, f->bxp->xfm);
245 } else
246 funcxf = r->rox->b;
247 } else
248 funcxf = *f->bxp;
249 lastrno = r->rno;
250 eclock++; /* notify expression evaluator */
251 return(1);
252 }
253
254
255 int
256 worldfunc( /* special function context sans object */
257 const char *ctx,
258 RAY *r
259 )
260 {
261 static RNUMBER lastrno = ~0;
262 /* set evaluator context */
263 calcontext((char *)ctx);
264 /* check if ray already set */
265 if ((fobj == NULL) & (r->rno == lastrno))
266 return(0);
267 fobj = NULL;
268 fray = r;
269 funcxf = unitxf;
270 lastrno = r->rno;
271 eclock++; /* notify expression evaluator */
272 return(1);
273 }
274
275
276 void
277 loadfunc( /* load definition file */
278 char *fname
279 )
280 {
281 char *ffname;
282
283 if ((ffname = getpath(fname, getrlibpath(), R_OK)) == NULL) {
284 sprintf(errmsg, "cannot find function file \"%s\"", fname);
285 error(SYSTEM, errmsg);
286 }
287 fcompile(ffname);
288 doptimize(1); /* optimize definitions */
289 }
290
291
292 static double
293 l_arg(char *nm) /* return nth real argument */
294 {
295 int n;
296
297 if (fobj == NULL)
298 error(USER,
299 "bad call to arg(n) - illegal constant in .cal file?");
300
301 n = argument(1) + .5; /* round to integer */
302
303 if (n < 1)
304 return(fobj->oargs.nfargs);
305
306 if (n > fobj->oargs.nfargs) {
307 sprintf(errmsg, "missing real argument %d", n);
308 objerror(fobj, USER, errmsg);
309 }
310 return(fobj->oargs.farg[n-1]);
311 }
312
313
314 static double
315 l_erf(char *nm) /* error function */
316 {
317 return(erf(argument(1)));
318 }
319
320
321 static double
322 l_erfc(char *nm) /* cumulative error function */
323 {
324 return(erfc(argument(1)));
325 }
326
327
328 double
329 chanvalue( /* return channel n to calcomp */
330 int n
331 )
332 {
333 if (fray == NULL)
334 esyntax("ray parameter used in constant expression");
335
336 if (--n < 0)
337 goto badchan;
338
339 if (n <= 2) /* ray direction */
340
341 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
342 fray->rdir[1]*funcxf.xfm[1][n] +
343 fray->rdir[2]*funcxf.xfm[2][n] )
344 / funcxf.sca );
345
346 if (n <= 5) /* surface normal */
347
348 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
349 fray->ron[1]*funcxf.xfm[1][n-3] +
350 fray->ron[2]*funcxf.xfm[2][n-3] )
351 / funcxf.sca );
352
353 if (n <= 8) { /* intersection point */
354 if (fray->rot >= FHUGE*.99)
355 return(0.0); /* XXX should be runtime error? */
356
357 return( fray->rop[0]*funcxf.xfm[0][n-6] +
358 fray->rop[1]*funcxf.xfm[1][n-6] +
359 fray->rop[2]*funcxf.xfm[2][n-6] +
360 funcxf.xfm[3][n-6] );
361 }
362
363 if (n == 9) /* total distance */
364 return(raydist(fray,PRIMARY) * funcxf.sca);
365
366 if (n == 10) /* dot product (range [-1,1]) */
367 return( fray->rod <= -1.0 ? -1.0 :
368 fray->rod >= 1.0 ? 1.0 :
369 fray->rod );
370
371 if (n == 11) /* scale */
372 return(funcxf.sca);
373
374 if (n <= 14) /* origin */
375 return(funcxf.xfm[3][n-12]);
376
377 if (n <= 17) /* i unit vector */
378 return(funcxf.xfm[0][n-15] / funcxf.sca);
379
380 if (n <= 20) /* j unit vector */
381 return(funcxf.xfm[1][n-18] / funcxf.sca);
382
383 if (n <= 23) /* k unit vector */
384 return(funcxf.xfm[2][n-21] / funcxf.sca);
385
386 if (n == 24) /* single ray (shadow) distance */
387 return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca);
388
389 if (n <= 26) /* local (u,v) coordinates */
390 return(fray->uv[n-25]);
391 badchan:
392 error(USER, "illegal channel number");
393 return(0.0);
394 }
