root/radiance/ray/src/rt/func.c
Revision: 2.15
Committed: Tue Feb 25 02:47:22 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.14: +1 -56 lines
5 * func.c - interface to calcomp functions.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11
12 #include "otypes.h"
13
14 #include "func.h"
15
16
17 #define INITFILE "rayinit.cal"
18 #define CALSUF ".cal"
19 #define LCALSUF 4
20 char REFVNAME[] = "`FILE_REFCNT";
21
22 XF unitxf = { /* identity transform */
23 {{1.0, 0.0, 0.0, 0.0},
24 {0.0, 1.0, 0.0, 0.0},
25 {0.0, 0.0, 1.0, 0.0},
26 {0.0, 0.0, 0.0, 1.0}},
27 1.0
28 };
29
30 XF funcxf; /* current transformation */
31 static OBJREC *fobj = NULL; /* current function object */
32 static RAY *fray = NULL; /* current function ray */
33
34 static double l_erf(), l_erfc(), l_arg();
35
36
37 MFUNC *
38 getfunc(m, ff, ef, dofwd) /* get function for this modifier */
39 OBJREC *m;
40 int ff;
41 unsigned int ef;
42 int dofwd;
43 {
44 static char initfile[] = INITFILE;
45 char sbuf[MAXSTR];
46 register char **arg;
47 register MFUNC *f;
48 int ne, na;
49 register int i;
50 /* check to see if done already */
51 if ((f = (MFUNC *)m->os) != NULL)
52 return(f);
53 fobj = NULL; fray = NULL;
54 if (initfile[0]) { /* initialize on first call */
55 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
56 esupport &= ~(E_OUTCHAN);
57 setcontext("");
58 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
59 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
60 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
61 scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
62 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
63 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
64 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
65 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
66 funset("arg", 1, '=', l_arg);
67 funset("erf", 1, ':', l_erf);
68 funset("erfc", 1, ':', l_erfc);
69 setnoisefuncs();
70 setprismfuncs();
71 loadfunc(initfile);
72 initfile[0] = '\0';
73 }
74 if ((na = m->oargs.nsargs) <= ff)
75 goto toofew;
76 arg = m->oargs.sarg;
77 if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
78 goto memerr;
79 i = strlen(arg[ff]); /* set up context */
80 if (i == 1 && arg[ff][0] == '.')
81 setcontext(f->ctx = ""); /* "." means no file */
82 else {
83 strcpy(sbuf,arg[ff]); /* file name is context */
84 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
85 sbuf[i-LCALSUF] = '\0'; /* remove suffix */
86 setcontext(f->ctx = savestr(sbuf));
87 if (!vardefined(REFVNAME)) { /* file loaded? */
88 loadfunc(arg[ff]);
89 varset(REFVNAME, '=', 1.0);
90 } else /* reference_count++ */
91 varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
92 }
93 curfunc = NULL; /* parse expressions */
94 sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
95 for (i=0, ne=0; ef && i < na; i++, ef>>=1)
96 if (ef & 1) { /* flagged as an expression? */
97 if (ne >= MAXEXPR)
98 objerror(m, INTERNAL, "too many expressions");
99 initstr(arg[i], sbuf, 0);
100 f->ep[ne++] = getE1();
101 if (nextc != EOF)
102 syntax("unexpected character");
103 }
104 if (ef)
105 goto toofew;
106 if (i <= ff) /* find transform args */
107 i = ff+1;
108 while (i < na && arg[i][0] != '-')
109 i++;
110 if (i == na) /* no transform */
111 f->f = f->b = &unitxf;
112 else { /* get transform */
113 if ((f->b = (XF *)malloc(sizeof(XF))) == NULL)
114 goto memerr;
115 if (invxf(f->b, na-i, arg+i) != na-i)
116 objerror(m, USER, "bad transform");
117 if (f->b->sca < 0.0)
118 f->b->sca = -f->b->sca;
119 if (dofwd) { /* do both transforms */
120 if ((f->f = (XF *)malloc(sizeof(XF))) == NULL)
121 goto memerr;
122 xf(f->f, na-i, arg+i);
123 if (f->f->sca < 0.0)
124 f->f->sca = -f->f->sca;
125 }
126 }
127 m->os = (char *)f;
128 return(f);
129 toofew:
130 objerror(m, USER, "too few string arguments");
131 memerr:
132 error(SYSTEM, "out of memory in getfunc");
133 }
134
135
136 void
137 freefunc(m) /* free memory associated with modifier */
138 OBJREC *m;
139 {
140 register MFUNC *f;
141 register int i;
142
143 if ((f = (MFUNC *)m->os) == NULL)
144 return;
145 for (i = 0; f->ep[i] != NULL; i++)
146 epfree(f->ep[i]);
147 if (f->ctx[0]) { /* done with definitions */
148 setcontext(f->ctx);
149 i = varvalue(REFVNAME)-.5; /* reference_count-- */
150 if (i > 0)
151 varset(REFVNAME, '=', (double)i);
152 else
153 dcleanup(2); /* remove definitions */
154 freestr(f->ctx);
155 }
156 if (f->b != &unitxf)
157 free((void *)f->b);
158 if (f->f != NULL && f->f != &unitxf)
159 free((void *)f->f);
160 free((void *)f);
161 m->os = NULL;
162 }
163
164
165 int
166 setfunc(m, r) /* set channels for function call */
167 OBJREC *m;
168 register RAY *r;
169 {
170 static unsigned long lastrno = ~0;
171 register MFUNC *f;
172 /* get function */
173 if ((f = (MFUNC *)m->os) == NULL)
174 objerror(m, CONSISTENCY, "setfunc called before getfunc");
175 /* set evaluator context */
176 setcontext(f->ctx);
177 /* check to see if matrix set */
178 if (m == fobj && r->rno == lastrno)
179 return(0);
180 fobj = m;
181 fray = r;
182 if (r->rox != NULL)
183 if (f->b != &unitxf) {
184 funcxf.sca = r->rox->b.sca * f->b->sca;
185 multmat4(funcxf.xfm, r->rox->b.xfm, f->b->xfm);
186 } else
187 copystruct(&funcxf, &r->rox->b);
188 else
189 copystruct(&funcxf, f->b);
190 lastrno = r->rno;
191 eclock++; /* notify expression evaluator */
192 return(1);
193 }
194
195
196 void
197 loadfunc(fname) /* load definition file */
198 char *fname;
199 {
200 char *ffname;
201
202 if ((ffname = getpath(fname, getlibpath(), R_OK)) == NULL) {
203 sprintf(errmsg, "cannot find function file \"%s\"", fname);
204 error(USER, errmsg);
205 }
206 fcompile(ffname);
207 }
208
209
210 static double
211 l_arg() /* return nth real argument */
212 {
213 register int n;
214
215 if (fobj == NULL)
216 syntax("arg(n) used in constant expression");
217
218 n = argument(1) + .5; /* round to integer */
219
220 if (n < 1)
221 return(fobj->oargs.nfargs);
222
223 if (n > fobj->oargs.nfargs) {
224 sprintf(errmsg, "missing real argument %d", n);
225 objerror(fobj, USER, errmsg);
226 }
227 return(fobj->oargs.farg[n-1]);
228 }
229
230
231 static double
232 l_erf() /* error function */
233 {
234 extern double erf();
235
236 return(erf(argument(1)));
237 }
238
239
240 static double
241 l_erfc() /* cumulative error function */
242 {
243 extern double erfc();
244
245 return(erfc(argument(1)));
246 }
247
248
249 double
250 chanvalue(n) /* return channel n to calcomp */
251 register int n;
252 {
253 if (fray == NULL)
254 syntax("ray parameter used in constant expression");
255
256 if (--n < 0)
257 goto badchan;
258
259 if (n < 3) /* ray direction */
260
261 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
262 fray->rdir[1]*funcxf.xfm[1][n] +
263 fray->rdir[2]*funcxf.xfm[2][n] )
264 / funcxf.sca );
265
266 if (n < 6) /* surface normal */
267
268 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
269 fray->ron[1]*funcxf.xfm[1][n-3] +
270 fray->ron[2]*funcxf.xfm[2][n-3] )
271 / funcxf.sca );
272
273 if (n < 9) /* intersection */
274
275 return( fray->rop[0]*funcxf.xfm[0][n-6] +
276 fray->rop[1]*funcxf.xfm[1][n-6] +
277 fray->rop[2]*funcxf.xfm[2][n-6] +
278 funcxf.xfm[3][n-6] );
279
280 if (n == 9) /* total distance */
281 return(raydist(fray,PRIMARY) * funcxf.sca);
282
283 if (n == 10) /* dot product (range [-1,1]) */
284 return( fray->rod <= -1.0 ? -1.0 :
285 fray->rod >= 1.0 ? 1.0 :
286 fray->rod );
287
288 if (n == 11) /* scale */
289 return(funcxf.sca);
290
291 if (n < 15) /* origin */
292 return(funcxf.xfm[3][n-12]);
293
294 if (n < 18) /* i unit vector */
295 return(funcxf.xfm[0][n-15] / funcxf.sca);
296
297 if (n < 21) /* j unit vector */
298 return(funcxf.xfm[1][n-15] / funcxf.sca);
299
300 if (n < 24) /* k unit vector */
301 return(funcxf.xfm[2][n-21] / funcxf.sca);
302
303 if (n == 24) /* single ray (shadow) distance */
304 return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca);
305 badchan:
306 error(USER, "illegal channel number");
307 }
