root/Development/ray/src/rt/func.c
Revision: 2.30
Committed: Wed May 20 13:16:20 2015 UTC (10 years, 7 months ago) by greg
Changes since 2.29: +2 -1 lines
Fixed include dependency
2 static const char RCSid[] = "$Id: func.c,v 2.29 2015/05/20 12:58:30 greg Exp $";
5 * func.c - interface to calcomp functions.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "paths.h"
12 #include "otypes.h"
13 #include "func.h"
14 #include <ctype.h>
15
16
17 #define INITFILE "rayinit.cal"
18 #define CALSUF ".cal"
19 #define LCALSUF 4
20 char REFVNAME[] = "`FILE_REFCNT";
21
22 XF unitxf = { /* identity transform */
23 {{1.0, 0.0, 0.0, 0.0},
24 {0.0, 1.0, 0.0, 0.0},
25 {0.0, 0.0, 1.0, 0.0},
26 {0.0, 0.0, 0.0, 1.0}},
27 1.0
28 };
29
30 XF funcxf; /* current transformation */
31 static OBJREC *fobj = NULL; /* current function object */
32 static RAY *fray = NULL; /* current function ray */
33
34 static char rayinitcal[] = INITFILE;
35
36 static double l_erf(char *), l_erfc(char *), l_arg(char *);
37
38
39 void
40 initfunc() /* initialize function evaluation */
41 {
42 if (!rayinitcal[0]) /* already done? */
43 return;
44 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
45 esupport &= ~(E_OUTCHAN);
46 setcontext("");
47 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
48 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
49 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
50 scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
51 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
52 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
53 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
54 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
55 scompile("Lu=$26;Lv=$27;", NULL, 0);
56 funset("arg", 1, '=', l_arg);
57 funset("erf", 1, ':', l_erf);
58 funset("erfc", 1, ':', l_erfc);
59 setnoisefuncs();
60 setprismfuncs();
61 loadfunc(rayinitcal);
62 rayinitcal[0] = '\0';
63 }
64
65
66 /* Set parameters for current evaluation */
67 void
68 set_eparams(char *prms)
69 {
70 static char *last_params = NULL;
71 char vname[RMAXWORD];
72 double value;
73 char *cpd;
74 /* check if already set */
75 if ((prms == NULL) | (prms == last_params))
76 return;
77 if (last_params != NULL && !strcmp(prms, last_params))
78 return;
79 last_params = prms; /* assign each variable */
80 while (*prms) {
81 if (isspace(*prms)) {
82 ++prms; continue;
83 }
84 if (!isalpha(*prms))
85 goto bad_params;
86 cpd = vname;
87 while (*prms && (*prms != '=') & !isspace(*prms)) {
88 if (!isid(*prms))
89 goto bad_params;
90 *cpd++ = *prms++;
91 }
92 if (cpd == vname)
93 goto bad_params;
94 *cpd = '\0';
95 while (isspace(*prms)) prms++;
96 if (*prms++ != '=')
97 goto bad_params;
98 value = atof(prms);
99 if ((prms = fskip(prms)) == NULL)
100 goto bad_params;
101 while (isspace(*prms)) prms++;
102 prms += (*prms == ',') | (*prms == ';');
103 varset(vname, '=', value);
104 }
105 return;
106 bad_params:
107 sprintf(errmsg, "bad parameter list '%s'", last_params);
108 error(USER, errmsg);
109 }
110
111
112 MFUNC *
113 getfunc( /* get function for this modifier */
114 OBJREC *m,
115 int ff,
116 unsigned int ef,
117 int dofwd
118 )
119 {
120 char sbuf[MAXSTR];
121 char **arg;
122 MFUNC *f;
123 int ne, na;
124 int i;
125 /* check to see if done already */
126 if ((f = (MFUNC *)m->os) != NULL)
127 return(f);
128 fobj = NULL; fray = NULL;
129 if (rayinitcal[0]) /* initialize on first call */
130 initfunc();
131 if ((na = m->oargs.nsargs) <= ff)
132 goto toofew;
133 arg = m->oargs.sarg;
134 if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
135 goto memerr;
136 i = strlen(arg[ff]); /* set up context */
137 if (i == 1 && arg[ff][0] == '.') {
138 setcontext(f->ctx = ""); /* "." means no file */
139 } else {
140 strcpy(sbuf,arg[ff]); /* file name is context */
141 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
142 sbuf[i-LCALSUF] = '\0'; /* remove suffix */
143 setcontext(f->ctx = savestr(sbuf));
144 if (!vardefined(REFVNAME)) { /* file loaded? */
145 loadfunc(arg[ff]);
146 varset(REFVNAME, '=', 1.0);
147 } else /* reference_count++ */
148 varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
149 }
150 curfunc = NULL; /* parse expressions */
151 sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
152 for (i=0, ne=0; ef && i < na; i++, ef>>=1)
153 if (ef & 1) { /* flagged as an expression? */
154 if (ne >= MAXEXPR)
155 objerror(m, INTERNAL, "too many expressions");
156 initstr(arg[i], sbuf, 0);
157 f->ep[ne++] = getE1();
158 if (nextc != EOF)
159 syntax("unexpected character");
160 }
161 if (ef)
162 goto toofew;
163 if (i <= ff) /* find transform args */
164 i = ff+1;
165 while (i < na && arg[i][0] != '-')
166 i++;
167 if (i == na) { /* no transform */
168 f->fxp = f->bxp = &unitxf;
169 } else { /* get transform */
170 if ((f->bxp = (XF *)malloc(sizeof(XF))) == NULL)
171 goto memerr;
172 if (invxf(f->bxp, na-i, arg+i) != na-i)
173 objerror(m, USER, "bad transform");
174 if (f->bxp->sca < 0.0)
175 f->bxp->sca = -f->bxp->sca;
176 if (dofwd) { /* do both transforms */
177 if ((f->fxp = (XF *)malloc(sizeof(XF))) == NULL)
178 goto memerr;
179 xf(f->fxp, na-i, arg+i);
180 if (f->fxp->sca < 0.0)
181 f->fxp->sca = -f->fxp->sca;
182 }
183 }
184 m->os = (char *)f;
185 return(f);
186 toofew:
187 objerror(m, USER, "too few string arguments");
188 memerr:
189 error(SYSTEM, "out of memory in getfunc");
190 return NULL; /* pro forma return */
191 }
192
193
194 void
195 freefunc( /* free memory associated with modifier */
196 OBJREC *m
197 )
198 {
199 MFUNC *f;
200 int i;
201
202 if ((f = (MFUNC *)m->os) == NULL)
203 return;
204 for (i = 0; f->ep[i] != NULL; i++)
205 epfree(f->ep[i]);
206 if (f->ctx[0]) { /* done with definitions */
207 setcontext(f->ctx);
208 i = varvalue(REFVNAME)-.5; /* reference_count-- */
209 if (i > 0)
210 varset(REFVNAME, '=', (double)i);
211 else
212 dcleanup(2); /* remove definitions */
213 freestr(f->ctx);
214 }
215 if (f->bxp != &unitxf)
216 free((void *)f->bxp);
217 if ((f->fxp != NULL) & (f->fxp != &unitxf))
218 free((void *)f->fxp);
219 free((void *)f);
220 m->os = NULL;
221 }
222
223
224 int
225 setfunc( /* set channels for function call */
226 OBJREC *m,
227 RAY *r
228 )
229 {
230 static RNUMBER lastrno = ~0;
231 MFUNC *f;
232 /* get function if any */
233 if ((f = (MFUNC *)m->os) == NULL)
234 objerror(m, CONSISTENCY, "setfunc called before getfunc");
235
236 setcontext(f->ctx); /* set evaluator context */
237 /* check to see if matrix set */
238 if ((m == fobj) & (r->rno == lastrno))
239 return(0);
240 fobj = m;
241 fray = r;
242 if (r->rox != NULL) {
243 if (f->bxp != &unitxf) {
244 funcxf.sca = r->rox->b.sca * f->bxp->sca;
245 multmat4(funcxf.xfm, r->rox->b.xfm, f->bxp->xfm);
246 } else
247 funcxf = r->rox->b;
248 } else
249 funcxf = *f->bxp;
250 lastrno = r->rno;
251 eclock++; /* notify expression evaluator */
252 return(1);
253 }
254
255
256 int
257 worldfunc( /* special function context sans object */
258 char *ctx,
259 RAY *r
260 )
261 {
262 static RNUMBER lastrno = ~0;
263
264 if (rayinitcal[0]) /* initialize on first call */
265 initfunc();
266 /* set evaluator context */
267 setcontext(ctx);
268 /* check if ray already set */
269 if ((fobj == NULL) & (r->rno == lastrno))
270 return(0);
271 fobj = NULL;
272 fray = r;
273 funcxf = unitxf;
274 lastrno = r->rno;
275 eclock++; /* notify expression evaluator */
276 return(1);
277 }
278
279
280 void
281 loadfunc( /* load definition file */
282 char *fname
283 )
284 {
285 char *ffname;
286
287 if ((ffname = getpath(fname, getrlibpath(), R_OK)) == NULL) {
288 sprintf(errmsg, "cannot find function file \"%s\"", fname);
289 error(USER, errmsg);
290 }
291 fcompile(ffname);
292 }
293
294
295 static double
296 l_arg(char *nm) /* return nth real argument */
297 {
298 int n;
299
300 if (fobj == NULL)
301 error(USER, "arg(n) called without a context");
302
303 n = argument(1) + .5; /* round to integer */
304
305 if (n < 1)
306 return(fobj->oargs.nfargs);
307
308 if (n > fobj->oargs.nfargs) {
309 sprintf(errmsg, "missing real argument %d", n);
310 objerror(fobj, USER, errmsg);
311 }
312 return(fobj->oargs.farg[n-1]);
313 }
314
315
316 static double
317 l_erf(char *nm) /* error function */
318 {
319 return(erf(argument(1)));
320 }
321
322
323 static double
324 l_erfc(char *nm) /* cumulative error function */
325 {
326 return(erfc(argument(1)));
327 }
328
329
330 double
331 chanvalue( /* return channel n to calcomp */
332 int n
333 )
334 {
335 if (fray == NULL)
336 syntax("ray parameter used in constant expression");
337
338 if (--n < 0)
339 goto badchan;
340
341 if (n <= 2) /* ray direction */
342
343 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
344 fray->rdir[1]*funcxf.xfm[1][n] +
345 fray->rdir[2]*funcxf.xfm[2][n] )
346 / funcxf.sca );
347
348 if (n <= 5) /* surface normal */
349
350 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
351 fray->ron[1]*funcxf.xfm[1][n-3] +
352 fray->ron[2]*funcxf.xfm[2][n-3] )
353 / funcxf.sca );
354
355 if (n <= 8) { /* intersection point */
356 if (fray->rot >= FHUGE)
357 return(0.0); /* XXX should be runtime error? */
358
359 return( fray->rop[0]*funcxf.xfm[0][n-6] +
360 fray->rop[1]*funcxf.xfm[1][n-6] +
361 fray->rop[2]*funcxf.xfm[2][n-6] +
362 funcxf.xfm[3][n-6] );
363 }
364
365 if (n == 9) /* total distance */
366 return(raydist(fray,PRIMARY) * funcxf.sca);
367
368 if (n == 10) /* dot product (range [-1,1]) */
369 return( fray->rod <= -1.0 ? -1.0 :
370 fray->rod >= 1.0 ? 1.0 :
371 fray->rod );
372
373 if (n == 11) /* scale */
374 return(funcxf.sca);
375
376 if (n <= 14) /* origin */
377 return(funcxf.xfm[3][n-12]);
378
379 if (n <= 17) /* i unit vector */
380 return(funcxf.xfm[0][n-15] / funcxf.sca);
381
382 if (n <= 20) /* j unit vector */
383 return(funcxf.xfm[1][n-18] / funcxf.sca);
384
385 if (n <= 23) /* k unit vector */
386 return(funcxf.xfm[2][n-21] / funcxf.sca);
387
388 if (n == 24) /* single ray (shadow) distance */
389 return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca);
390
391 if (n <= 26) /* local (u,v) coordinates */
392 return(fray->uv[n-25]);
393 badchan:
394 error(USER, "illegal channel number");
395 return(0.0);
396 }
