root/radiance/ray/src/rt/func.c
Sat Dec 12 00:03:42 2009 UTC (15 years, 4 months ago) by greg
Diff to previous 2.22
Changes since 2.21: +28 -27 lines
Diff to previous 2.21
Thu Feb 12 18:55:50 2004 UTC (21 years, 2 months ago) by greg
Changes since 2.20: +3 -1 lines
Diff to previous 2.20
Mon Aug 4 22:37:53 2003 UTC (21 years, 9 months ago) by greg
Diff to previous 2.19
Mon Jul 21 22:30:19 2003 UTC (21 years, 9 months ago) by schorsch
Diff to previous 2.18
Tue May 13 17:58:33 2003 UTC (21 years, 11 months ago) by greg
Diff to previous 2.17
Wed Apr 23 01:31:50 2003 UTC (22 years ago) by greg
Changes since 2.16: +12 -12 lines
Diff to previous 2.16
Fixed bug in mesh (u,v) local coordinate indexing and old bug in I[xyz] value
Tue Mar 11 17:08:55 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.15: +6 -1 lines
Diff to previous 2.15
Tue Feb 25 02:47:22 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.14: +1 -56 lines
Diff to previous 2.14
Sat Feb 22 02:07:28 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.13: +68 -14 lines
Diff to previous 2.13
Thu Nov 2 17:38:05 1995 UTC (29 years, 6 months ago) by greg
Changes since 2.12: +5 -18 lines
Diff to previous 2.12
added raydist() function
Thu Apr 14 04:50:29 1994 UTC (31 years ago) by greg
Wed Sep 29 10:39:40 1993 UTC (31 years, 7 months ago) by greg
Changes since 2.10: +1 -0 lines
added fprism
Tue Aug 3 12:04:58 1993 UTC (31 years, 9 months ago) by greg
minor optimization in use of REFVNAME (macro -> char constant)
Tue May 25 10:30:16 1993 UTC (31 years, 11 months ago) by greg
Mon Mar 8 12:37:23 1993 UTC (32 years, 2 months ago) by greg
Sat Sep 26 08:10:41 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.6: +7 -0 lines
fixed bug to catch illegal calls to chanvalue() and l_arg()
Tue Mar 3 13:58:12 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.5: +11 -3 lines
added Ts variable for single ray (or shadow ray) distance
Wed Feb 5 09:23:38 1992 UTC (33 years, 3 months ago) by greg
minor improvements to getfunc()
Sat Jan 4 19:53:25 1992 UTC (33 years, 4 months ago) by greg
minor improvement in error message
Tue Dec 24 17:43:43 1991 UTC (33 years, 4 months ago) by greg
minor cosmetic surgery
Mon Nov 25 09:51:00 1991 UTC (33 years, 5 months ago) by greg
Changes since 2.1: +146 -79 lines
Tue Nov 12 17:08:46 1991 UTC (33 years, 5 months ago) by greg
Changes since 1.23: +0 -0 lines
Diff to previous 1.23
Fri Aug 9 08:26:02 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.22: +1 -1 lines
Diff to previous 1.22
changed location of context mark for locals (again!)
Thu Aug 8 15:41:14 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.21: +9 -5 lines
Diff to previous 1.21
added special case for "." meaning no function file
Thu Aug 8 13:08:01 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.20: +34 -19 lines
Diff to previous 1.20
added contexts to function files
Wed Jul 17 10:09:24 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.19
changed position of initfile loading to catch conflicts
Wed Jun 19 15:08:39 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.18: +21 -1 lines
Diff to previous 1.18
Tue Jun 18 08:59:52 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.17: +4 -2 lines
Diff to previous 1.17
put in test to guarantee range of dot product as [-1,1]
Mon Jun 17 08:51:33 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.16: +3 -3 lines
Diff to previous 1.16
added return value to setfunc() and setmap():
returns 1 if setting was made, 0 if function already set
Mon Jun 17 08:28:26 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.15: +5 -0 lines
Diff to previous 1.15
reinstated repeat call test in setmap()
Fri May 24 13:52:10 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.14: +2 -8 lines
Diff to previous 1.14
changed initialization for noise functions
Tue Apr 23 15:46:22 1991 UTC (34 years ago) by greg
Changes since 1.13: +7 -7 lines
Diff to previous 1.13
changed funset() parameters
Sat Jan 12 18:01:19 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.12: +27 -17 lines
Diff to previous 1.12
fixed incorrect test for repeat call
added identity transform special case
Sat Dec 15 15:03:26 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.11: +37 -35 lines
Diff to previous 1.11
Wed Dec 12 21:57:50 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.10: +0 -1 lines
Diff to previous 1.10
deleted unused #undef statement
Sat Aug 4 11:47:46 1990 UTC (34 years, 9 months ago) by greg
Changes since 1.9: +15 -15 lines
Diff to previous 1.9
changed ordering in chanvalue()
Thu Jul 19 11:17:12 1990 UTC (34 years, 9 months ago) by greg
Changes since 1.8: +8 -8 lines
Diff to previous 1.8
added line numbers to error reporting in cal functions
Sat Apr 7 16:12:56 1990 UTC (35 years, 1 month ago) by greg
Changes since 1.7: +47 -26 lines
Diff to previous 1.7
added direct access to coordinate transformation
Thu Oct 5 07:23:22 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.6: +0 -2 lines
Diff to previous 1.6
Eliminated need to initialize matrix for call to xf() and invxf()
Thu Jul 27 22:25:13 1989 UTC (35 years, 9 months ago) by greg
Diff to previous 1.5
Changed getpath to check permissions
Wed Apr 19 21:36:11 1989 UTC (36 years ago) by greg
Changes since 1.4: +5 -6 lines
Diff to previous 1.4
minor change to loop
Tue Apr 11 13:30:29 1989 UTC (36 years, 1 month ago) by greg
Diff to previous 1.3
Tue Mar 14 10:41:21 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.2: +4 -4 lines
changed order of parameters to setmap() for consistency with xfm()
Tue Feb 21 14:56:17 1989 UTC (36 years, 2 months ago) by greg
portability fixes
Thu Feb 2 10:41:23 1989 UTC (36 years, 3 months ago) by greg
