root/radiance/ray/src/rt/freeobjmem.c
Thu Apr 4 18:51:18 2024 UTC (13 months, 2 weeks ago) by greg
perf: Added missing data preload calls for multi-processing with spectra
Wed Nov 15 18:02:52 2023 UTC (18 months ago) by greg
Changes since 2.9: +3 -1 lines
Mon Dec 9 17:56:25 2013 UTC (11 years, 5 months ago) by greg
CVS Tags: rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.8: +7 -7 lines
Added check for references to identically-named but different modifiers
Fri Feb 18 00:40:25 2011 UTC (14 years, 3 months ago) by greg
Changes since 2.6: +15 -10 lines
Thu Jul 10 03:47:00 2003 UTC (21 years, 10 months ago) by greg
Tue Feb 25 02:47:22 2003 UTC (22 years, 3 months ago) by greg
Sat Feb 22 02:07:28 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.3: +72 -13 lines
Thu Feb 15 17:28:50 1996 UTC (29 years, 3 months ago) by greg
eliminated freepict() call, now part of freedata()
Wed Feb 10 12:51:40 1993 UTC (32 years, 3 months ago) by greg
Changes since 2.1: +3 -6 lines
Sun Nov 22 10:58:10 1992 UTC (32 years, 6 months ago) by greg
