root/Development/ray/src/rt/freeobjmem.c
Revision: 2.4
Committed: Sat Feb 22 02:07:28 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.3: +72 -13 lines
5 * Free memory associated with object(s)
6 *
7 * External symbols declared in ray.h
8 */
9
10 /* ====================================================================
11 * The Radiance Software License, Version 1.0
12 *
13 * Copyright (c) 1990 - 2002 The Regents of the University of California,
14 * through Lawrence Berkeley National Laboratory. All rights reserved.
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 *
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 *
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in
25 * the documentation and/or other materials provided with the
26 * distribution.
27 *
28 * 3. The end-user documentation included with the redistribution,
29 * if any, must include the following acknowledgment:
30 * "This product includes Radiance software
31 * (http://radsite.lbl.gov/)
32 * developed by the Lawrence Berkeley National Laboratory
33 * (http://www.lbl.gov/)."
34 * Alternately, this acknowledgment may appear in the software itself,
35 * if and wherever such third-party acknowledgments normally appear.
36 *
37 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
38 * and "The Regents of the University of California" must
39 * not be used to endorse or promote products derived from this
40 * software without prior written permission. For written
41 * permission, please contact [email protected].
42 *
43 * 5. Products derived from this software may not be called "Radiance",
44 * nor may "Radiance" appear in their name, without prior written
45 * permission of Lawrence Berkeley National Laboratory.
46 *
47 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
48 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
49 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
50 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
51 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
52 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
53 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
54 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
55 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
56 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
57 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
58 * SUCH DAMAGE.
59 * ====================================================================
60 *
61 * This software consists of voluntary contributions made by many
62 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
63 * information on Lawrence Berkeley National Laboratory, please see
64 * <http://www.lbl.gov/>.
65 */
66
67 #include "ray.h"
68 #include "otypes.h"
69 #include "face.h"
70 #include "cone.h"
71 #include "instance.h"
72 #include "data.h"
73 #include "font.h"
74
75
76 int
77 free_os(op) /* free unneeded memory for object */
78 register OBJREC *op;
79 {
80 if (op->os == NULL)
81 return(0);
82 if (hasfunc(op->otype)) {
83 freefunc(op);
84 return(1);
85 }
86 switch (op->otype) {
87 case OBJ_FACE: /* polygon */
88 freeface(op);
89 return(1);
90 case OBJ_CONE: /* cone */
91 case OBJ_RING: /* disk */
92 case OBJ_CYLINDER: /* cylinder */
93 case OBJ_CUP: /* inverted cone */
94 case OBJ_TUBE: /* inverted cylinder */
95 freecone(op);
96 return(1);
97 case OBJ_INSTANCE: /* octree instance */
98 freeinstance(op);
99 return(1);
100 case PAT_BTEXT: /* monochromatic text */
101 case PAT_CTEXT: /* colored text */
102 case MIX_TEXT: /* mixing text */
103 freetext(op);
104 return(1);
105 case MAT_CLIP: /* clipping surface */
106 case MAT_SPOT: /* spot light source */
107 free((void *)op->os);
108 op->os = NULL;
109 return(1);
110 }
111 #ifdef DEBUG
112 objerror(op, WARNING, "cannot free structure");
113 #endif
114 return(0);
115 }
116
117
118 int
119 free_objs(on, no) /* free some object structures */
120 register OBJECT on;
121 OBJECT no;
122 {
123 int nfreed;
124 register OBJREC *op;
125
126 for (nfreed = 0; no-- > 0; on++) {
127 op = objptr(on);
128 if (op->os != NULL)
129 nfreed += free_os(op);
130 }
131 return(nfreed);
132 }
133
134
135 void
136 free_objmem() /* free all object cache memory */
137 {
138 free_objs(0, nobjects);
139 freedata(NULL);
140 freefont(NULL);
141 }
