1 |
/* Copyright (c) 1992 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Free memory associated with object(s) |
9 |
10 |
11 |
#include "standard.h" |
12 |
#include "object.h" |
13 |
#include "otypes.h" |
14 |
15 |
16 |
int |
17 |
free_os(op) /* free unneeded memory for object */ |
18 |
register OBJREC *op; |
19 |
20 |
if (op->os == NULL) |
21 |
return(0); |
22 |
if (hasfunc(op->otype)) { |
23 |
freefunc(op); |
24 |
return(1); |
25 |
26 |
switch (op->otype) { |
27 |
case OBJ_FACE: /* polygon */ |
28 |
freeface(op); |
29 |
return(1); |
30 |
case OBJ_CONE: /* cone */ |
31 |
case OBJ_RING: /* disk */ |
32 |
case OBJ_CYLINDER: /* cylinder */ |
33 |
case OBJ_CUP: /* inverted cone */ |
34 |
case OBJ_TUBE: /* inverted cylinder */ |
35 |
freecone(op); |
36 |
return(1); |
37 |
case OBJ_INSTANCE: /* octree instance */ |
38 |
freeinstance(op); |
39 |
return(1); |
40 |
case PAT_BTEXT: /* monochromatic text */ |
41 |
case PAT_CTEXT: /* colored text */ |
42 |
case MIX_TEXT: /* mixing text */ |
43 |
freetext(op); |
44 |
return(1); |
45 |
case MAT_CLIP: /* clipping surface */ |
46 |
free(op->os); |
47 |
op->os = NULL; |
48 |
return(1); |
49 |
case MAT_SPOT: /* spot light source */ |
50 |
return(0); |
51 |
default: |
52 |
#ifdef DEBUG |
53 |
objerror(op, WARNING, "cannot free structure"); |
54 |
#endif |
55 |
return(0); |
56 |
57 |
58 |
59 |
60 |
int |
61 |
free_objs(on, no) /* free some object structures */ |
62 |
register OBJECT on; |
63 |
OBJECT no; |
64 |
65 |
int nfreed; |
66 |
67 |
68 |
for (nfreed = 0; no-- > 0; on++) { |
69 |
op = objptr(on); |
70 |
if (op->os != NULL) |
71 |
nfreed += free_os(op); |
72 |
73 |
return(nfreed); |
74 |
75 |
76 |
77 |
free_objmem() /* free all object cache memory */ |
78 |
79 |
free_objs(0, nobjects); |
80 |
freedata(NULL); |
81 |
freefont(NULL); |
82 |
