| 1 |
/* Copyright (c) 1992 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Free memory associated with object(s)
| 9 |
| 10 |
| 11 |
#include "standard.h"
| 12 |
#include "object.h"
| 13 |
#include "otypes.h"
| 14 |
| 15 |
| 16 |
int
| 17 |
free_os(op) /* free unneeded memory for object */
| 18 |
register OBJREC *op;
| 19 |
| 20 |
if (op->os == NULL)
| 21 |
return(0);
| 22 |
if (hasfunc(op->otype)) {
| 23 |
freefunc(op);
| 24 |
return(1);
| 25 |
| 26 |
switch (op->otype) {
| 27 |
case OBJ_FACE: /* polygon */
| 28 |
freeface(op);
| 29 |
return(1);
| 30 |
case OBJ_CONE: /* cone */
| 31 |
case OBJ_RING: /* disk */
| 32 |
case OBJ_CYLINDER: /* cylinder */
| 33 |
case OBJ_CUP: /* inverted cone */
| 34 |
case OBJ_TUBE: /* inverted cylinder */
| 35 |
freecone(op);
| 36 |
return(1);
| 37 |
case OBJ_INSTANCE: /* octree instance */
| 38 |
freeinstance(op);
| 39 |
return(1);
| 40 |
case PAT_BTEXT: /* monochromatic text */
| 41 |
case PAT_CTEXT: /* colored text */
| 42 |
case MIX_TEXT: /* mixing text */
| 43 |
freetext(op);
| 44 |
return(1);
| 45 |
case MAT_CLIP: /* clipping surface */
| 46 |
free(op->os);
| 47 |
op->os = NULL;
| 48 |
return(1);
| 49 |
case MAT_SPOT: /* spot light source */
| 50 |
return(0);
| 51 |
default:
| 52 |
#ifdef DEBUG
| 53 |
objerror(op, WARNING, "cannot free structure");
| 54 |
#endif
| 55 |
return(0);
| 56 |
| 57 |
| 58 |
| 59 |
| 60 |
int
| 61 |
free_objs(on, no, rn) /* free no object structures starting w/ on */
| 62 |
register OBJECT on;
| 63 |
OBJECT no;
| 64 |
long rn;
| 65 |
| 66 |
int nfreed;
| 67 |
| 68 |
| 69 |
for (nfreed = 0; no-- > 0; on++) {
| 70 |
op = objptr(on);
| 71 |
if (op->os != NULL && op->lastrno < rn)
| 72 |
nfreed += free_os(op);
| 73 |
| 74 |
return(nfreed);
| 75 |
| 76 |
| 77 |
| 78 |
free_objmem() /* free all object cache memory */
| 79 |
| 80 |
extern long raynum;
| 81 |
| 82 |
free_objs(0, nobjects, raynum);
| 83 |
freedata(NULL);
| 84 |
freepict(NULL);
| 85 |
freefont(NULL);
| 86 |
