--- ray/src/rt/fprism.c 1995/02/14 08:54:17 2.3 +++ ray/src/rt/fprism.c 2013/08/07 05:10:09 2.9 @@ -1,9 +1,6 @@ -/* Copyright (c) 1993 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: fprism.c,v 2.9 2013/08/07 05:10:09 greg Exp $"; #endif - /* Ce programme calcule les directions et les energies des rayons lumineux resultant du passage d'un rayon au travers d'un vitrage prismatique @@ -11,14 +8,19 @@ static char SCCSid[] = "$SunId$ LBL"; #include "standard.h" +#include "ray.h" +#include "calcomp.h" +#include "func.h" + #ifdef NOSTRUCTASSIGN static double err = "No structure assignment!"; /* generate compiler error */ #endif static double -Sqrt(x) -double x; +Sqrt( + double x +) { if (x < 0.) return(0.); @@ -82,7 +84,6 @@ static int tot_ref; /* flag pour les surfaces static double fact_ref[4]={1.0,1.0,1.0,1.0}; /* facteurs de reflexion */ static double tolerance; /* degre de tol. pour les amalgames */ static double tolsource; /* degre de tol. pour les sources */ -static double Nx; static int bidon; #define BADVAL (-10) static long prismclock = -1; @@ -92,45 +93,63 @@ static int sens; /* indique le sens de prop. du ray. static int nbrayons; /* indice des rayons sortants */ static TRAYON *ray; /* tableau des rayons sortants */ static TRAYON *raytemp; /* variable temporaire */ -static TRAYON rtemp; /* variable temporaire */ -extern double argument(); -extern double varvalue(); -extern double funvalue(); -extern long eclock; +static void prepare_matrices(void); +static void tfm(MAT4 mat, FVECT v_old, FVECT v_new); +static double prob_alpha_beta(TRAYON r); +static double prob_beta_alpha(TRAYON r); +static double prob_gamma_alpha(TRAYON r); +static void v_par(FVECT v, FVECT v_out); +static void v_per(FVECT v, FVECT v_out); +static TRAYON transalphabeta(TRAYON r_initial); +static TRAYON transbetaalpha(TRAYON r_initial); +static TRAYON transalphagamma(TRAYON r_initial); +static TRAYON transgammaalpha(TRAYON r_initial); +static int compare(TRAYON r1, TRAYON r2, double marge); +static void sortie(TRAYON r); +static void trigo(TRAYON r); +static TRAYON reflexion(TRAYON r_incident); +static TRAYON transmission(TRAYON r_incident); +static void trace_rayon(TRAYON r_incident); +static void inverser(TRAYON *r1, TRAYON *r2); +static void setprism(void); +static double l_get_val(char *nm); + /* Definition des routines */ #define term(a,b) a/Sqrt(a*a+b*b) -static -prepare_matrices() +static void +prepare_matrices(void) { - /* preparation des matrices de changement de bases */ + /* preparation des matrices de changement de bases */ - matb[0][0] = matbt[0][0] = matb[1][1] = matbt[1][1] = term(prism.a,prism.d); - matb[1][0] = matbt[0][1] = term(-prism.d,prism.a); - matb[0][1] = matbt[1][0] = term(prism.d,prism.a); - matc[0][0] = matct[0][0] = matc[1][1] = matct[1][1] = term(prism.b,prism.d); - matc[1][0] = matct[0][1] = term(prism.d,prism.b); - matc[0][1] = matct[1][0] = term(-prism.d,prism.b); - return; + matb[0][0] = matbt[0][0] = matb[1][1] = matbt[1][1] = term(prism.a,prism.d); + matb[1][0] = matbt[0][1] = term(-prism.d,prism.a); + matb[0][1] = matbt[1][0] = term(prism.d,prism.a); + matc[0][0] = matct[0][0] = matc[1][1] = matct[1][1] = term(prism.b,prism.d); + matc[1][0] = matct[0][1] = term(prism.d,prism.b); + matc[0][1] = matct[1][0] = term(-prism.d,prism.b); + return; } #undef term -static -tfm(mat,v_old,v_new) -MAT4 mat; -FVECT v_old,v_new; +static void +tfm( + MAT4 mat, + FVECT v_old, + FVECT v_new +) { - /* passage d'un repere old au repere new par la matrice mat */ - FVECT v_temp; + /* passage d'un repere old au repere new par la matrice mat */ + FVECT v_temp; - multv3(v_temp,v_old,mat); - normalize(v_temp); - VCOPY(v_new,v_temp); - return; + multv3(v_temp,v_old,mat); + normalize(v_temp); + VCOPY(v_new,v_temp); + return; } #define A prism.a @@ -140,58 +159,62 @@ FVECT v_old,v_new; static double -prob_alpha_beta(r) -TRAYON r; +prob_alpha_beta( + TRAYON r +) { - /* calcul de la probabilite de passage de alpha a beta */ - double prob,test; + /* calcul de la probabilite de passage de alpha a beta */ + double prob,test; - if ( X(r) != 0. ) + if ( X(r) != 0. ) { - test = Y(r)/X(r); - if ( test > B/D ) prob = 1.; - else if ( test >= -A/D ) prob = (A+test*D)/(A+B); - else prob = 0.; + test = Y(r)/X(r); + if ( test > B/D ) prob = 1.; + else if ( test >= -A/D ) prob = (A+test*D)/(A+B); + else prob = 0.; } - else prob = 0.; - return prob; + else prob = 0.; + return prob; } static double -prob_beta_alpha(r) -TRAYON r; +prob_beta_alpha( + TRAYON r +) { - /* calcul de la probabilite de passage de beta a aplha */ - double prob,test; + /* calcul de la probabilite de passage de beta a aplha */ + double prob,test; - if ( X(r) != 0. ) + if ( X(r) != 0. ) { - test = Y(r)/X(r); - if ( test > B/D ) prob = (A+B)/(A+test*D); - else if ( test >= -A/D ) prob = 1.; - else prob = 0.; + test = Y(r)/X(r); + if ( test > B/D ) prob = (A+B)/(A+test*D); + else if ( test >= -A/D ) prob = 1.; + else prob = 0.; } - else prob = 0.; - return prob; + else prob = 0.; + return prob; } -double prob_gamma_alpha(r) -TRAYON r; +static double +prob_gamma_alpha( + TRAYON r +) { - /* calcul de la probabilite de passage de gamma a alpha */ - double prob,test; + /* calcul de la probabilite de passage de gamma a alpha */ + double prob,test; - if ( X(r) != 0. ) + if ( X(r) != 0. ) { - test = Y(r)/X(r); - if ( test > B/D ) prob = 0.; - else if ( test >= -A/D ) prob = 1.; - else prob = (A+B)/(B-test*D); + test = Y(r)/X(r); + if ( test > B/D ) prob = 0.; + else if ( test >= -A/D ) prob = 1.; + else prob = (A+B)/(B-test*D); } - else prob = 0.; - return prob; + else prob = 0.; + return prob; } #undef A @@ -200,244 +223,256 @@ TRAYON r; #undef D -static -v_par(v,v_out) -FVECT v,v_out; +static void +v_par( + FVECT v, + FVECT v_out +) /* calcule le vecteur par au plan d'incidence lie a v */ { - FVECT v_temp; - double det; + FVECT v_temp; + double det; - det = Sqrt( (YY(v)*YY(v)+ZZ(v)*ZZ(v))*(YY(v)*YY(v)+ZZ(v)*ZZ(v))+ - (XX(v)*XX(v)*YY(v)*YY(v))+(XX(v)*XX(v)*ZZ(v)*ZZ(v)) ); - XX(v_temp) = (YY(v)*YY(v)+ZZ(v)*ZZ(v))/det; - YY(v_temp) = -( XX(v)*YY(v) )/det; - ZZ(v_temp) = -( XX(v)*ZZ(v) )/det; - VCOPY(v_out,v_temp); - return; + det = Sqrt( (YY(v)*YY(v)+ZZ(v)*ZZ(v))*(YY(v)*YY(v)+ZZ(v)*ZZ(v))+ + (XX(v)*XX(v)*YY(v)*YY(v))+(XX(v)*XX(v)*ZZ(v)*ZZ(v)) ); + XX(v_temp) = (YY(v)*YY(v)+ZZ(v)*ZZ(v))/det; + YY(v_temp) = -( XX(v)*YY(v) )/det; + ZZ(v_temp) = -( XX(v)*ZZ(v) )/det; + VCOPY(v_out,v_temp); + return; } -static -v_per(v,v_out) -FVECT v,v_out; +static void +v_per( + FVECT v, + FVECT v_out +) /* calcule le vecteur perp au plan d'incidence lie a v */ { - FVECT v_temp; - double det; + FVECT v_temp; + double det; - det = Sqrt( (ZZ(v)*ZZ(v)+YY(v)*YY(v)) ); - XX(v_temp) = 0.; - YY(v_temp) = -ZZ(v)/det; - ZZ(v_temp) = YY(v)/det; - VCOPY(v_out,v_temp); - return; + det = Sqrt( (ZZ(v)*ZZ(v)+YY(v)*YY(v)) ); + XX(v_temp) = 0.; + YY(v_temp) = -ZZ(v)/det; + ZZ(v_temp) = YY(v)/det; + VCOPY(v_out,v_temp); + return; } static TRAYON -transalphabeta(r_initial) +transalphabeta( + TRAYON r_initial +) /* transforme le rayon r_initial de la base associee a alpha dans la base associee a beta */ -TRAYON r_initial; { - TRAYON r_final; - FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2; + TRAYON r_final; + FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2; - r_final = r_initial; - alpha_beta(r_initial.v,r_final.v); - if ((Y(r_initial) != 0. || Z(r_initial) != 0.)&&(Y(r_final) !=0. || Z(r_final)!= 0.)) - { - v_par(r_initial.v,vpar_temp1); - alpha_beta(vpar_temp1,vpar_temp1); - v_per(r_initial.v,vper_temp1); - alpha_beta(vper_temp1,vper_temp1); - v_par(r_final.v,vpar_temp2); - v_per(r_final.v,vper_temp2); - r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+ - (r_initial.pper1*fdot(vper_temp1,vpar_temp2)); - r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+ - (r_initial.pper1*fdot(vper_temp1,vper_temp2)); - r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+ - (r_initial.pper2*fdot(vper_temp1,vpar_temp2)); - r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+ - (r_initial.pper2*fdot(vper_temp1,vper_temp2)); - } - return r_final; + r_final = r_initial; + alpha_beta(r_initial.v,r_final.v); + if ((Y(r_initial) != 0. || Z(r_initial) != 0.)&&(Y(r_final) !=0. || Z(r_final)!= 0.)) + { + v_par(r_initial.v,vpar_temp1); + alpha_beta(vpar_temp1,vpar_temp1); + v_per(r_initial.v,vper_temp1); + alpha_beta(vper_temp1,vper_temp1); + v_par(r_final.v,vpar_temp2); + v_per(r_final.v,vper_temp2); + r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+ + (r_initial.pper1*fdot(vper_temp1,vpar_temp2)); + r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+ + (r_initial.pper1*fdot(vper_temp1,vper_temp2)); + r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+ + (r_initial.pper2*fdot(vper_temp1,vpar_temp2)); + r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+ + (r_initial.pper2*fdot(vper_temp1,vper_temp2)); + } + return r_final; } static TRAYON -transbetaalpha(r_initial) -/* transforme le rayon r_initial de la base associee a beta dans - la base associee a alpha */ -TRAYON r_initial; +transbetaalpha( + TRAYON r_initial +) { - TRAYON r_final; - FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2; + /* transforme le rayon r_initial de la base associee a beta dans + la base associee a alpha */ + TRAYON r_final; + FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2; - r_final = r_initial; - beta_alpha(r_initial.v,r_final.v); - if ((Y(r_initial) != 0. || Z(r_initial) != 0. )&&(Y(r_final) != 0. || Z(r_final)!= 0.)) - { - v_par(r_initial.v,vpar_temp1); - beta_alpha(vpar_temp1,vpar_temp1); - v_per(r_initial.v,vper_temp1); - beta_alpha(vper_temp1,vper_temp1); - v_par(r_final.v,vpar_temp2); - v_per(r_final.v,vper_temp2); - r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+ - (r_initial.pper1*fdot(vper_temp1,vpar_temp2)); - r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+ - (r_initial.pper1*fdot(vper_temp1,vper_temp2)); - r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+ - (r_initial.pper2*fdot(vper_temp1,vpar_temp2)); - r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+ - (r_initial.pper2*fdot(vper_temp1,vper_temp2)); + r_final = r_initial; + beta_alpha(r_initial.v,r_final.v); + if ((Y(r_initial) != 0. || Z(r_initial) != 0. )&&(Y(r_final) != 0. || Z(r_final)!= 0.)) + { + v_par(r_initial.v,vpar_temp1); + beta_alpha(vpar_temp1,vpar_temp1); + v_per(r_initial.v,vper_temp1); + beta_alpha(vper_temp1,vper_temp1); + v_par(r_final.v,vpar_temp2); + v_per(r_final.v,vper_temp2); + r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+ + (r_initial.pper1*fdot(vper_temp1,vpar_temp2)); + r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+ + (r_initial.pper1*fdot(vper_temp1,vper_temp2)); + r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+ + (r_initial.pper2*fdot(vper_temp1,vpar_temp2)); + r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+ + (r_initial.pper2*fdot(vper_temp1,vper_temp2)); - } - return r_final; + } + return r_final; } static TRAYON -transalphagamma(r_initial) +transalphagamma( + TRAYON r_initial +) /* transforme le rayon r_initial de la base associee a alpha dans la base associee a gamma */ -TRAYON r_initial; { - TRAYON r_final; - FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2; + TRAYON r_final; + FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2; - r_final = r_initial; - alpha_gamma(r_initial.v,r_final.v); - if (( Y(r_initial) != 0. || Z(r_initial) != 0. )&&(Y(r_final)!= 0. || Z(r_final) !=0.)) - { - v_par(r_initial.v,vpar_temp1); - alpha_gamma(vpar_temp1,vpar_temp1); - v_per(r_initial.v,vper_temp1); - alpha_gamma(vper_temp1,vper_temp1); - v_par(r_final.v,vpar_temp2); - v_per(r_final.v,vper_temp2); - r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+ - (r_initial.pper1*fdot(vper_temp1,vpar_temp2)); - r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+ - (r_initial.pper1*fdot(vper_temp1,vper_temp2)); - r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+ - (r_initial.pper2*fdot(vper_temp1,vpar_temp2)); - r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+ - (r_initial.pper2*fdot(vper_temp1,vper_temp2)); + r_final = r_initial; + alpha_gamma(r_initial.v,r_final.v); + if (( Y(r_initial) != 0. || Z(r_initial) != 0. )&&(Y(r_final)!= 0. || Z(r_final) !=0.)) + { + v_par(r_initial.v,vpar_temp1); + alpha_gamma(vpar_temp1,vpar_temp1); + v_per(r_initial.v,vper_temp1); + alpha_gamma(vper_temp1,vper_temp1); + v_par(r_final.v,vpar_temp2); + v_per(r_final.v,vper_temp2); + r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+ + (r_initial.pper1*fdot(vper_temp1,vpar_temp2)); + r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+ + (r_initial.pper1*fdot(vper_temp1,vper_temp2)); + r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+ + (r_initial.pper2*fdot(vper_temp1,vpar_temp2)); + r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+ + (r_initial.pper2*fdot(vper_temp1,vper_temp2)); - } - return r_final; + } + return r_final; } static TRAYON -transgammaalpha(r_initial) +transgammaalpha( + TRAYON r_initial +) /* transforme le rayon r_initial de la base associee a gamma dans la base associee a alpha */ -TRAYON r_initial; { - TRAYON r_final; - FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2; + TRAYON r_final; + FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2; - r_final = r_initial; - gamma_alpha(r_initial.v,r_final.v); - if (( Y(r_initial) != 0. || Z(r_initial) != 0. )&&(Y(r_final) !=0. || Z(r_final) != 0.)) - { - v_par(r_initial.v,vpar_temp1); - gamma_alpha(vpar_temp1,vpar_temp1); - v_per(r_initial.v,vper_temp1); - gamma_alpha(vper_temp1,vper_temp1); - v_par(r_final.v,vpar_temp2); - v_per(r_final.v,vper_temp2); - r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+ - (r_initial.pper1*fdot(vper_temp1,vpar_temp2)); - r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+ - (r_initial.pper1*fdot(vper_temp1,vper_temp2)); - r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+ - (r_initial.pper2*fdot(vper_temp1,vpar_temp2)); - r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+ - (r_initial.pper2*fdot(vper_temp1,vper_temp2)); - } - return r_final; + r_final = r_initial; + gamma_alpha(r_initial.v,r_final.v); + if (( Y(r_initial) != 0. || Z(r_initial) != 0. )&&(Y(r_final) !=0. || Z(r_final) != 0.)) + { + v_par(r_initial.v,vpar_temp1); + gamma_alpha(vpar_temp1,vpar_temp1); + v_per(r_initial.v,vper_temp1); + gamma_alpha(vper_temp1,vper_temp1); + v_par(r_final.v,vpar_temp2); + v_per(r_final.v,vper_temp2); + r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+ + (r_initial.pper1*fdot(vper_temp1,vpar_temp2)); + r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+ + (r_initial.pper1*fdot(vper_temp1,vper_temp2)); + r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+ + (r_initial.pper2*fdot(vper_temp1,vpar_temp2)); + r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+ + (r_initial.pper2*fdot(vper_temp1,vper_temp2)); + } + return r_final; } static int -compare(r1,r2,marge) -TRAYON r1, r2; -double marge; - +compare( + TRAYON r1, + TRAYON r2, + double marge +) { - double arctg1, arctg2; + double arctg1, arctg2; - arctg1 = atan2(Y(r1),X(r1)); - arctg2 = atan2(Y(r2),X(r2)); - if ((arctg1 - marge <= arctg2) && (arctg1 + marge >= arctg2)) return 1; - else return 0; + arctg1 = atan2(Y(r1),X(r1)); + arctg2 = atan2(Y(r2),X(r2)); + if ((arctg1 - marge <= arctg2) && (arctg1 + marge >= arctg2)) return 1; + else return 0; } -static -sortie(r) -TRAYON r; +static void +sortie( + TRAYON r +) { - int i = 0; - int egalite = 0; + int i = 0; + int egalite = 0; -if(r.e > seuil) -{ - while (i < nbrayons && egalite == 0) - { - raytemp = &ray[i]; - egalite = compare(r,*raytemp,tolerance); - if (egalite) raytemp->e = raytemp->e + r.e; - else i = i + 1; - } - if (egalite == 0) - { - if (nbrayons == 0) ray = (TRAYON *)calloc(1,sizeof(TRAYON)); - else ray = (TRAYON *)realloc(ray, (nbrayons+1)*(sizeof(TRAYON))); - if (ray == NULL) - error(SYSTEM, "out of memory in sortie\n"); - raytemp = &ray[nbrayons]; - raytemp->v[0] = X(r); - raytemp->v[1] = Y(r); - raytemp->v[2] = Z(r); - raytemp->e = r.e; - nbrayons++; - } - } -return; + if(r.e > seuil) + { + while (i < nbrayons && egalite == 0) + { + raytemp = &ray[i]; + egalite = compare(r,*raytemp,tolerance); + if (egalite) raytemp->e = raytemp->e + r.e; + else i = i + 1; + } + if (egalite == 0) + { + if (nbrayons == 0) ray = (TRAYON *)calloc(1,sizeof(TRAYON)); + else ray = (TRAYON *)realloc((void *)ray, (nbrayons+1)*(sizeof(TRAYON))); + if (ray == NULL) + error(SYSTEM, "out of memory in sortie\n"); + raytemp = &ray[nbrayons]; + raytemp->v[0] = X(r); + raytemp->v[1] = Y(r); + raytemp->v[2] = Z(r); + raytemp->e = r.e; + nbrayons++; + } + } + return; } -static -trigo(r) -TRAYON r; +static void +trigo( + TRAYON r +) /* calcule les grandeurs trigonometriques relatives au rayon incident et le rapport entre les indices du milieu refracteur et incident */ { - double det; - - det = Sqrt(X(r)*X(r)+Y(r)*Y(r)+Z(r)*Z(r)); - sinus = Sqrt(Y(r)*Y(r)+Z(r)*Z(r))/det; - cosinus = Sqrt(X(r)*X(r))/det; - if (r.n == 1.) rapport = prism.np * prism.np; - else rapport = 1./(prism.np * prism.np); - return; + double det; + + det = Sqrt(X(r)*X(r)+Y(r)*Y(r)+Z(r)*Z(r)); + sinus = Sqrt(Y(r)*Y(r)+Z(r)*Z(r))/det; + cosinus = Sqrt(X(r)*X(r))/det; + if (r.n == 1.) rapport = prism.np * prism.np; + else rapport = 1./(prism.np * prism.np); + return; } static TRAYON -reflexion(r_incident) -TRAYON r_incident; +reflexion( + TRAYON r_incident +) { /* calcul du rayon reflechi par une face */ TRAYON r_reflechi; @@ -478,8 +513,9 @@ TRAYON r_incident; static TRAYON -transmission(r_incident) -TRAYON r_incident; +transmission( + TRAYON r_incident +) { /* calcul du rayon refracte par une face */ TRAYON r_transmis; @@ -527,9 +563,10 @@ TRAYON r_incident; if ( r_suite.e > seuil ) trace_rayon(r_suite) -static -trace_rayon(r_incident) -TRAYON r_incident; +static void +trace_rayon( + TRAYON r_incident +) { /* trace le rayon donne */ TRAYON r_reflechi,r_transmis,r_suite; @@ -619,25 +656,26 @@ TRAYON r_incident; #undef ensuite -static -inverser(r1,r2) -TRAYON *r1,*r2; - +static void +inverser( + TRAYON *r1, + TRAYON *r2 +) { - TRAYON temp; - temp = *r1; - *r1 = *r2; - *r2 = temp; + TRAYON temp; + temp = *r1; + *r1 = *r2; + *r2 = temp; } -static -setprism() +static void +setprism(void) { double d; TRAYON r_initial,rsource; - int i,j,k; + int i,j; prismclock = eclock; r_initial.ppar1 = r_initial.pper2 = 1.; @@ -731,13 +769,14 @@ if ( X(r_initial) != 0.) static double -l_get_val() - +l_get_val( + char *nm +) { int val, dir, i, trouve, curseur; int nb; double valeur; - TRAYON *rayt, raynull; + TRAYON *rayt=NULL, raynull; if (prismclock < 0 || prismclock < eclock) setprism(); if (bidon == BADVAL) { @@ -784,7 +823,8 @@ l_get_val() } -setprismfuncs() +extern void +setprismfuncs(void) /* declared in func.h */ { funset("fprism_val", 3, '=', l_get_val); }
