root/radiance/ray/src/rt/fprism.c
Revision: 2.7
Committed: Tue Mar 30 16:13:01 2004 UTC (21 years, 2 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9
Changes since 2.6: +299 -257 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 schorsch 2.7 static const char RCSid[] = "$Id: fprism.c,v 2.6 2003/08/04 22:37:53 greg Exp $";
3 greg 2.1 #endif
4     /* Ce programme calcule les directions et les energies des rayons lumineux
5     resultant du passage d'un rayon au travers d'un vitrage prismatique
6
7     1991, LESO - EPFL, R. Compagnon - F. Di Pasquale */
8
9     #include "standard.h"
10
11 schorsch 2.7 #include "calcomp.h"
12     #include "func.h"
13
14 greg 2.1 #ifdef NOSTRUCTASSIGN
15     static double err = "No structure assignment!"; /* generate compiler error */
16     #endif
17
18
19     static double
20 schorsch 2.7 Sqrt(
21     double x
22     )
23 greg 2.1 {
24     if (x < 0.)
25     return(0.);
26     return(sqrt(x));
27     }
28
29     /* definitions de macros utiles */
30
31     #define ALPHA 0
32     #define BETA 1
33     #define GAMMA 2
34     #define DELTA 3
35     #define AUCUNE 4
36     #define X(r) r.v[0]
37     #define Y(r) r.v[1]
38     #define Z(r) r.v[2]
39     #define XX(v) v[0]
40     #define YY(v) v[1]
41     #define ZZ(v) v[2]
42     #define alpha_beta(v_alpha,v_beta) tfm(matbt,v_alpha,v_beta)
43     #define beta_alpha(v_beta,v_alpha) tfm(matb,v_beta,v_alpha)
44     #define alpha_gamma(v_alpha,v_gamma) tfm(matct,v_alpha,v_gamma)
45     #define gamma_alpha(v_gamma,v_alpha) tfm(matc,v_gamma,v_alpha)
46     #define prob_alpha_gamma(r) (1.-prob_alpha_beta(r))
47     #define prob_beta_gamma(r) (1.-prob_beta_alpha(r))
48     #define prob_gamma_beta(r) (1.-prob_gamma_alpha(r))
49     #define prob_delta_gamma(r) (1.-prob_delta_beta(r))
50     #define prob_beta_delta(r) (prob_beta_alpha(r))
51     #define prob_gamma_delta(r) (prob_gamma_alpha(r))
52     #define prob_delta_beta(r) (prob_alpha_beta(r))
53
54
55     /* Definitions des types de donnees */
56
57     typedef struct { FVECT v; /* direction */
58     double ppar1,pper1,
59     ppar2,pper2; /* polarisations */
60     double e; /* energie */
61     double n; /* milieu dans lequel on se propage */
62     int orig,dest; /* origine et destination */
63     } TRAYON;
64
65     typedef struct { double a,b,c,d; /* longueurs caracteristiques */
66     double np; /* indice de refraction */
67     } TPRISM;
68
69
70     /* Definitions des variables globales */
71
72     static TPRISM prism; /* le prisme ! */
73     static MAT4 matb = MAT4IDENT; /* matrices de changement de bases */
74     static MAT4 matbt = MAT4IDENT;
75     static MAT4 matc = MAT4IDENT;
76     static MAT4 matct = MAT4IDENT;
77     static double seuil; /* seuil pour l'arret du trace */
78     static double sinus,cosinus; /* sin et cos */
79     static double rapport; /* rapport entre les indices des
80     milieux refracteur et incident */
81     static int tot_ref; /* flag pour les surfaces
82     reflechissantes */
83     static double fact_ref[4]={1.0,1.0,1.0,1.0}; /* facteurs de reflexion */
84     static double tolerance; /* degre de tol. pour les amalgames */
85     static double tolsource; /* degre de tol. pour les sources */
86     static int bidon;
87     #define BADVAL (-10)
88     static long prismclock = -1;
89     static int nosource; /* indique que l'on ne trace pas
90     en direction d'une source */
91     static int sens; /* indique le sens de prop. du ray.*/
92     static int nbrayons; /* indice des rayons sortants */
93     static TRAYON *ray; /* tableau des rayons sortants */
94     static TRAYON *raytemp; /* variable temporaire */
95
96 schorsch 2.7
97     static void prepare_matrices(void);
98     static void tfm(MAT4 mat, FVECT v_old, FVECT v_new);
99     static double prob_alpha_beta(TRAYON r);
100     static double prob_beta_alpha(TRAYON r);
101     static double prob_gamma_alpha(TRAYON r);
102     static void v_par(FVECT v, FVECT v_out);
103     static void v_per(FVECT v, FVECT v_out);
104     static TRAYON transalphabeta(TRAYON r_initial);
105     static TRAYON transbetaalpha(TRAYON r_initial);
106     static TRAYON transalphagamma(TRAYON r_initial);
107     static TRAYON transgammaalpha(TRAYON r_initial);
108     static int compare(TRAYON r1, TRAYON r2, double marge);
109     static void sortie(TRAYON r);
110     static void trigo(TRAYON r);
111     static TRAYON reflexion(TRAYON r_incident);
112     static TRAYON transmission(TRAYON r_incident);
113     static void trace_rayon(TRAYON r_incident);
114     static void inverser(TRAYON *r1, TRAYON *r2);
115     static void setprism(void);
116     static double l_get_val(char *nm);
117 greg 2.1
118
119     /* Definition des routines */
120
121 greg 2.3 #define term(a,b) a/Sqrt(a*a+b*b)
122 schorsch 2.7 static void
123     prepare_matrices(void)
124 greg 2.1 {
125 schorsch 2.7 /* preparation des matrices de changement de bases */
126 greg 2.1
127 schorsch 2.7 matb[0][0] = matbt[0][0] = matb[1][1] = matbt[1][1] = term(prism.a,prism.d);
128     matb[1][0] = matbt[0][1] = term(-prism.d,prism.a);
129     matb[0][1] = matbt[1][0] = term(prism.d,prism.a);
130     matc[0][0] = matct[0][0] = matc[1][1] = matct[1][1] = term(prism.b,prism.d);
131     matc[1][0] = matct[0][1] = term(prism.d,prism.b);
132     matc[0][1] = matct[1][0] = term(-prism.d,prism.b);
133     return;
134 greg 2.1 }
135     #undef term
136
137
138 schorsch 2.7 static void
139     tfm(
140     MAT4 mat,
141     FVECT v_old,
142     FVECT v_new
143     )
144     {
145     /* passage d'un repere old au repere new par la matrice mat */
146     FVECT v_temp;
147
148     multv3(v_temp,v_old,mat);
149     normalize(v_temp);
150     VCOPY(v_new,v_temp);
151     return;
152 greg 2.1 }
153
154     #define A prism.a
155     #define B prism.b
156     #define C prism.c
157     #define D prism.d
158
159
160     static double
161 schorsch 2.7 prob_alpha_beta(
162     TRAYON r
163     )
164 greg 2.1 {
165 schorsch 2.7 /* calcul de la probabilite de passage de alpha a beta */
166     double prob,test;
167 greg 2.1
168 schorsch 2.7 if ( X(r) != 0. )
169 greg 2.1 {
170 schorsch 2.7 test = Y(r)/X(r);
171     if ( test > B/D ) prob = 1.;
172     else if ( test >= -A/D ) prob = (A+test*D)/(A+B);
173     else prob = 0.;
174 greg 2.1 }
175 schorsch 2.7 else prob = 0.;
176     return prob;
177 greg 2.1 }
178
179
180     static double
181 schorsch 2.7 prob_beta_alpha(
182     TRAYON r
183     )
184 greg 2.1 {
185 schorsch 2.7 /* calcul de la probabilite de passage de beta a aplha */
186     double prob,test;
187 greg 2.1
188 schorsch 2.7 if ( X(r) != 0. )
189 greg 2.1 {
190 schorsch 2.7 test = Y(r)/X(r);
191     if ( test > B/D ) prob = (A+B)/(A+test*D);
192     else if ( test >= -A/D ) prob = 1.;
193     else prob = 0.;
194 greg 2.1 }
195 schorsch 2.7 else prob = 0.;
196     return prob;
197 greg 2.1 }
198
199
200 schorsch 2.7 static double
201     prob_gamma_alpha(
202     TRAYON r
203     )
204 greg 2.1 {
205 schorsch 2.7 /* calcul de la probabilite de passage de gamma a alpha */
206     double prob,test;
207 greg 2.1
208 schorsch 2.7 if ( X(r) != 0. )
209 greg 2.1 {
210 schorsch 2.7 test = Y(r)/X(r);
211     if ( test > B/D ) prob = 0.;
212     else if ( test >= -A/D ) prob = 1.;
213     else prob = (A+B)/(B-test*D);
214 greg 2.1 }
215 schorsch 2.7 else prob = 0.;
216     return prob;
217 greg 2.1 }
218
219     #undef A
220     #undef B
221     #undef C
222     #undef D
223
224
225 schorsch 2.7 static void
226     v_par(
227     FVECT v,
228     FVECT v_out
229     )
230 greg 2.1 /* calcule le vecteur par au plan d'incidence lie a v */
231     {
232 schorsch 2.7 FVECT v_temp;
233     double det;
234 greg 2.1
235 schorsch 2.7 det = Sqrt( (YY(v)*YY(v)+ZZ(v)*ZZ(v))*(YY(v)*YY(v)+ZZ(v)*ZZ(v))+
236     (XX(v)*XX(v)*YY(v)*YY(v))+(XX(v)*XX(v)*ZZ(v)*ZZ(v)) );
237     XX(v_temp) = (YY(v)*YY(v)+ZZ(v)*ZZ(v))/det;
238     YY(v_temp) = -( XX(v)*YY(v) )/det;
239     ZZ(v_temp) = -( XX(v)*ZZ(v) )/det;
240     VCOPY(v_out,v_temp);
241     return;
242 greg 2.1 }
243
244
245 schorsch 2.7 static void
246     v_per(
247     FVECT v,
248     FVECT v_out
249     )
250 greg 2.1 /* calcule le vecteur perp au plan d'incidence lie a v */
251     {
252 schorsch 2.7 FVECT v_temp;
253     double det;
254 greg 2.1
255 schorsch 2.7 det = Sqrt( (ZZ(v)*ZZ(v)+YY(v)*YY(v)) );
256     XX(v_temp) = 0.;
257     YY(v_temp) = -ZZ(v)/det;
258     ZZ(v_temp) = YY(v)/det;
259     VCOPY(v_out,v_temp);
260     return;
261 greg 2.1 }
262
263
264     static TRAYON
265 schorsch 2.7 transalphabeta(
266     TRAYON r_initial
267     )
268 greg 2.1 /* transforme le rayon r_initial de la base associee a alpha dans
269     la base associee a beta */
270     {
271 schorsch 2.7 TRAYON r_final;
272     FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2;
273 greg 2.1
274 schorsch 2.7 r_final = r_initial;
275     alpha_beta(r_initial.v,r_final.v);
276     if ((Y(r_initial) != 0. || Z(r_initial) != 0.)&&(Y(r_final) !=0. || Z(r_final)!= 0.))
277     {
278     v_par(r_initial.v,vpar_temp1);
279     alpha_beta(vpar_temp1,vpar_temp1);
280     v_per(r_initial.v,vper_temp1);
281     alpha_beta(vper_temp1,vper_temp1);
282     v_par(r_final.v,vpar_temp2);
283     v_per(r_final.v,vper_temp2);
284     r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+
285     (r_initial.pper1*fdot(vper_temp1,vpar_temp2));
286     r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+
287     (r_initial.pper1*fdot(vper_temp1,vper_temp2));
288     r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+
289     (r_initial.pper2*fdot(vper_temp1,vpar_temp2));
290     r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+
291     (r_initial.pper2*fdot(vper_temp1,vper_temp2));
292     }
293     return r_final;
294 greg 2.1 }
295
296
297     static TRAYON
298 schorsch 2.7 transbetaalpha(
299     TRAYON r_initial
300     )
301     {
302     /* transforme le rayon r_initial de la base associee a beta dans
303     la base associee a alpha */
304     TRAYON r_final;
305     FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2;
306
307     r_final = r_initial;
308     beta_alpha(r_initial.v,r_final.v);
309     if ((Y(r_initial) != 0. || Z(r_initial) != 0. )&&(Y(r_final) != 0. || Z(r_final)!= 0.))
310     {
311     v_par(r_initial.v,vpar_temp1);
312     beta_alpha(vpar_temp1,vpar_temp1);
313     v_per(r_initial.v,vper_temp1);
314     beta_alpha(vper_temp1,vper_temp1);
315     v_par(r_final.v,vpar_temp2);
316     v_per(r_final.v,vper_temp2);
317     r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+
318     (r_initial.pper1*fdot(vper_temp1,vpar_temp2));
319     r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+
320     (r_initial.pper1*fdot(vper_temp1,vper_temp2));
321     r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+
322     (r_initial.pper2*fdot(vper_temp1,vpar_temp2));
323     r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+
324     (r_initial.pper2*fdot(vper_temp1,vper_temp2));
325 greg 2.1
326 schorsch 2.7 }
327     return r_final;
328 greg 2.1 }
329
330
331     static TRAYON
332 schorsch 2.7 transalphagamma(
333     TRAYON r_initial
334     )
335 greg 2.1 /* transforme le rayon r_initial de la base associee a alpha dans
336     la base associee a gamma */
337     {
338 schorsch 2.7 TRAYON r_final;
339     FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2;
340 greg 2.1
341 schorsch 2.7 r_final = r_initial;
342     alpha_gamma(r_initial.v,r_final.v);
343     if (( Y(r_initial) != 0. || Z(r_initial) != 0. )&&(Y(r_final)!= 0. || Z(r_final) !=0.))
344     {
345     v_par(r_initial.v,vpar_temp1);
346     alpha_gamma(vpar_temp1,vpar_temp1);
347     v_per(r_initial.v,vper_temp1);
348     alpha_gamma(vper_temp1,vper_temp1);
349     v_par(r_final.v,vpar_temp2);
350     v_per(r_final.v,vper_temp2);
351     r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+
352     (r_initial.pper1*fdot(vper_temp1,vpar_temp2));
353     r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+
354     (r_initial.pper1*fdot(vper_temp1,vper_temp2));
355     r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+
356     (r_initial.pper2*fdot(vper_temp1,vpar_temp2));
357     r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+
358     (r_initial.pper2*fdot(vper_temp1,vper_temp2));
359 greg 2.1
360 schorsch 2.7 }
361     return r_final;
362 greg 2.1 }
363
364
365     static TRAYON
366 schorsch 2.7 transgammaalpha(
367     TRAYON r_initial
368     )
369 greg 2.1 /* transforme le rayon r_initial de la base associee a gamma dans
370     la base associee a alpha */
371     {
372 schorsch 2.7 TRAYON r_final;
373     FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2;
374 greg 2.1
375 schorsch 2.7 r_final = r_initial;
376     gamma_alpha(r_initial.v,r_final.v);
377     if (( Y(r_initial) != 0. || Z(r_initial) != 0. )&&(Y(r_final) !=0. || Z(r_final) != 0.))
378     {
379     v_par(r_initial.v,vpar_temp1);
380     gamma_alpha(vpar_temp1,vpar_temp1);
381     v_per(r_initial.v,vper_temp1);
382     gamma_alpha(vper_temp1,vper_temp1);
383     v_par(r_final.v,vpar_temp2);
384     v_per(r_final.v,vper_temp2);
385     r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+
386     (r_initial.pper1*fdot(vper_temp1,vpar_temp2));
387     r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+
388     (r_initial.pper1*fdot(vper_temp1,vper_temp2));
389     r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+
390     (r_initial.pper2*fdot(vper_temp1,vpar_temp2));
391     r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+
392     (r_initial.pper2*fdot(vper_temp1,vper_temp2));
393     }
394     return r_final;
395 greg 2.1 }
396
397
398
399 greg 2.2 static int
400 schorsch 2.7 compare(
401     TRAYON r1,
402     TRAYON r2,
403     double marge
404     )
405 greg 2.2 {
406 schorsch 2.7 double arctg1, arctg2;
407 greg 2.2
408 schorsch 2.7 arctg1 = atan2(Y(r1),X(r1));
409     arctg2 = atan2(Y(r2),X(r2));
410     if ((arctg1 - marge <= arctg2) && (arctg1 + marge >= arctg2)) return 1;
411     else return 0;
412 greg 2.2 }
413
414
415
416
417 schorsch 2.7 static void
418     sortie(
419     TRAYON r
420     )
421 greg 2.1 {
422 schorsch 2.7 int i = 0;
423     int egalite = 0;
424 greg 2.1
425
426 schorsch 2.7 if(r.e > seuil)
427     {
428     while (i < nbrayons && egalite == 0)
429     {
430     raytemp = &ray[i];
431     egalite = compare(r,*raytemp,tolerance);
432     if (egalite) raytemp->e = raytemp->e + r.e;
433     else i = i + 1;
434     }
435     if (egalite == 0)
436     {
437     if (nbrayons == 0) ray = (TRAYON *)calloc(1,sizeof(TRAYON));
438     else ray = (TRAYON *)realloc((void *)ray, (nbrayons+1)*(sizeof(TRAYON)));
439     if (ray == NULL)
440     error(SYSTEM, "out of memory in sortie\n");
441     raytemp = &ray[nbrayons];
442     raytemp->v[0] = X(r);
443     raytemp->v[1] = Y(r);
444     raytemp->v[2] = Z(r);
445     raytemp->e = r.e;
446     nbrayons++;
447     }
448     }
449     return;
450 greg 2.1 }
451
452
453 schorsch 2.7 static void
454     trigo(
455     TRAYON r
456     )
457 greg 2.1 /* calcule les grandeurs trigonometriques relatives au rayon incident
458     et le rapport entre les indices du milieu refracteur et incident */
459     {
460 schorsch 2.7 double det;
461
462     det = Sqrt(X(r)*X(r)+Y(r)*Y(r)+Z(r)*Z(r));
463     sinus = Sqrt(Y(r)*Y(r)+Z(r)*Z(r))/det;
464     cosinus = Sqrt(X(r)*X(r))/det;
465     if (r.n == 1.) rapport = prism.np * prism.np;
466     else rapport = 1./(prism.np * prism.np);
467     return;
468 greg 2.1 }
469
470
471     static TRAYON
472 schorsch 2.7 reflexion(
473     TRAYON r_incident
474     )
475 greg 2.1 {
476     /* calcul du rayon reflechi par une face */
477     TRAYON r_reflechi;
478
479     r_reflechi = r_incident;
480     trigo(r_incident);
481     X(r_reflechi) = -X(r_incident);
482     Y(r_reflechi) = Y(r_incident);
483     Z(r_reflechi) = Z(r_incident);
484 greg 2.3 if(sinus > Sqrt(rapport) || r_incident.dest == tot_ref)
485 greg 2.1 {
486     r_reflechi.ppar1 = r_incident.ppar1;
487     r_reflechi.pper1 = r_incident.pper1;
488     r_reflechi.ppar2 = r_incident.ppar2;
489     r_reflechi.pper2 = r_incident.pper2;
490     r_reflechi.e = r_incident.e * fact_ref[r_incident.dest];
491     }
492     else
493     {
494 greg 2.3 r_reflechi.ppar1 = r_incident.ppar1*(rapport*cosinus-Sqrt(rapport-
495     (sinus*sinus)))/(rapport*cosinus+Sqrt(rapport-(sinus*sinus)));
496     r_reflechi.pper1 = r_incident.pper1*(cosinus-Sqrt
497     (rapport-(sinus*sinus)))/(cosinus+Sqrt(rapport-(sinus*sinus)));
498     r_reflechi.ppar2 = r_incident.ppar2*(rapport*cosinus-Sqrt(rapport-
499     (sinus*sinus)))/(rapport*cosinus+Sqrt(rapport-(sinus*sinus)));
500     r_reflechi.pper2 = r_incident.pper2*(cosinus-Sqrt
501     (rapport-(sinus*sinus)))/(cosinus+Sqrt(rapport-(sinus*sinus)));
502 greg 2.1 r_reflechi.e = r_incident.e *(((r_reflechi.ppar1*r_reflechi.ppar1+
503     r_reflechi.pper1*r_reflechi.pper1)/(r_incident.ppar1*r_incident.ppar1+
504     r_incident.pper1*r_incident.pper1))+((r_reflechi.ppar2*r_reflechi.ppar2
505     +r_reflechi.pper2*r_reflechi.pper2)/(r_incident.ppar2*r_incident.ppar2
506     +r_incident.pper2*r_incident.pper2)))/2;
507     }
508
509     /* a la sortie de cette routine r_transmis.orig et .dest ne sont pas definis!*/
510     return r_reflechi;
511     }
512
513
514     static TRAYON
515 schorsch 2.7 transmission(
516     TRAYON r_incident
517     )
518 greg 2.1 {
519     /* calcul du rayon refracte par une face */
520     TRAYON r_transmis;
521
522     r_transmis = r_incident;
523     trigo(r_incident);
524 greg 2.3 if (sinus <= Sqrt(rapport) && r_incident.dest != tot_ref)
525 greg 2.1 {
526     X(r_transmis) = (X(r_incident)/(fabs(X(r_incident))))*
527 greg 2.3 (Sqrt(1.-(Y(r_incident)*Y(r_incident)+Z(r_incident)*
528 greg 2.1 Z(r_incident))/rapport));
529 greg 2.3 Y(r_transmis) = Y(r_incident)/Sqrt(rapport);
530     Z(r_transmis) = Z(r_incident)/Sqrt(rapport);
531     r_transmis.ppar1 = r_incident.ppar1*2.*Sqrt(rapport)*cosinus/
532     (Sqrt(rapport-sinus*sinus)+rapport*cosinus);
533     r_transmis.pper1 = r_incident.pper1*2.*cosinus/(cosinus+Sqrt(rapport
534 greg 2.1 - sinus*sinus));
535 greg 2.3 r_transmis.ppar2 = r_incident.ppar2*2.*Sqrt(rapport)*cosinus/
536     (Sqrt(rapport-sinus*sinus)+rapport*cosinus);
537     r_transmis.pper2 = r_incident.pper2*2.*cosinus/(cosinus+Sqrt(rapport
538 greg 2.1 - sinus*sinus));
539 greg 2.3 r_transmis.e = (r_incident.e/2)*(Sqrt(rapport-sinus*sinus)/cosinus)
540 greg 2.1 *(((r_transmis.ppar1*r_transmis.ppar1+r_transmis.pper1*
541     r_transmis.pper1)
542     /(r_incident.ppar1*r_incident.ppar1+r_incident.pper1*
543     r_incident.pper1))+
544     ((r_transmis.ppar2*r_transmis.ppar2+r_transmis.pper2*r_transmis.pper2)
545     /(r_incident.ppar2*r_incident.ppar2+r_incident.pper2*r_incident.pper2)));
546     if(r_incident.n == 1.) r_transmis.n = prism.np;
547     else r_transmis.n = 1.;
548     }
549     else r_transmis.e = 0.;
550
551     /* a la sortie de cette routine r_transmis.orig et .dest ne sont pas definis!*/
552
553     return r_transmis;
554     }
555
556
557
558
559     #define ensuite(rayon,prob_passage,destination) r_suite = rayon; \
560     r_suite.e = prob_passage(rayon)*rayon.e; \
561     r_suite.dest = destination; \
562     if ( r_suite.e > seuil ) trace_rayon(r_suite)
563
564
565 schorsch 2.7 static void
566     trace_rayon(
567     TRAYON r_incident
568     )
569 greg 2.1 {
570     /* trace le rayon donne */
571     TRAYON r_reflechi,r_transmis,r_suite;
572
573     switch (r_incident.dest)
574     {
575     case ALPHA:
576     if ( r_incident.orig == ALPHA )
577     {
578     r_reflechi = reflexion(r_incident);
579     sortie(r_reflechi);
580
581     r_transmis = transmission(r_incident);
582     r_transmis.orig = ALPHA;
583
584     ensuite(r_transmis,prob_alpha_beta,BETA);
585     ensuite(r_transmis,prob_alpha_gamma,GAMMA);
586     }
587     else
588     {
589     r_reflechi = reflexion(r_incident);
590     r_reflechi.orig = ALPHA;
591     ensuite(r_reflechi,prob_alpha_beta,BETA);
592     ensuite(r_reflechi,prob_alpha_gamma,GAMMA);
593
594     r_transmis = transmission(r_incident);
595     sortie(r_transmis);
596     }
597     break;
598     case BETA:
599     r_reflechi = transbetaalpha(reflexion(transalphabeta(r_incident)));
600     r_reflechi.orig = BETA;
601     r_transmis = transbetaalpha(transmission(transalphabeta
602     (r_incident)));
603     r_transmis.orig = GAMMA;
604     if ( r_incident.n > 1.0 ) /* le rayon vient de l'interieur */
605     {
606     ensuite(r_reflechi,prob_beta_alpha,ALPHA);
607     ensuite(r_reflechi,prob_beta_gamma,GAMMA);
608
609     ensuite(r_transmis,prob_beta_gamma,GAMMA);
610     ensuite(r_transmis,prob_beta_delta,DELTA);
611     }
612     else /* le rayon vient de l'exterieur */
613     {
614     ensuite(r_reflechi,prob_beta_gamma,GAMMA);
615     ensuite(r_reflechi,prob_beta_delta,DELTA);
616
617     ensuite(r_transmis,prob_beta_alpha,ALPHA);
618     ensuite(r_transmis,prob_beta_gamma,GAMMA);
619     }
620     break;
621     case GAMMA:
622     r_reflechi = transgammaalpha(reflexion(transalphagamma(r_incident)));
623     r_reflechi.orig = GAMMA;
624     r_transmis = transgammaalpha(transmission(transalphagamma
625     (r_incident)));
626     r_transmis.orig = GAMMA;
627     if ( r_incident.n > 1.0 ) /* le rayon vient de l'interieur */
628     {
629     ensuite(r_reflechi,prob_gamma_alpha,ALPHA);
630     ensuite(r_reflechi,prob_gamma_beta,BETA);
631
632     ensuite(r_transmis,prob_gamma_beta,BETA);
633     ensuite(r_transmis,prob_gamma_delta,DELTA);
634     }
635     else /* le rayon vient de l'exterieur */
636     {
637     ensuite(r_reflechi,prob_gamma_beta,BETA);
638     ensuite(r_reflechi,prob_gamma_delta,DELTA);
639
640     ensuite(r_transmis,prob_gamma_alpha,ALPHA);
641     ensuite(r_transmis,prob_gamma_beta,BETA);
642     }
643     break;
644     case DELTA:
645     if ( r_incident.orig != DELTA ) sortie(r_incident);
646     else
647     {
648     ensuite(r_incident,prob_delta_beta,BETA);
649     ensuite(r_incident,prob_delta_gamma,GAMMA);
650     }
651     break;
652     }
653     return;
654     }
655
656     #undef ensuite
657
658 schorsch 2.7 static void
659     inverser(
660     TRAYON *r1,
661     TRAYON *r2
662     )
663 greg 2.1 {
664 schorsch 2.7 TRAYON temp;
665     temp = *r1;
666     *r1 = *r2;
667     *r2 = temp;
668 greg 2.1 }
669
670
671
672 schorsch 2.7 static void
673     setprism(void)
674 greg 2.1 {
675     double d;
676     TRAYON r_initial,rsource;
677 schorsch 2.7 int i,j;
678 greg 2.1
679     prismclock = eclock;
680     r_initial.ppar1 = r_initial.pper2 = 1.;
681     r_initial.pper1 = r_initial.ppar2 = 0.;
682
683     d = 1; prism.a = funvalue("arg", 1, &d);
684     if(prism.a < 0.) goto badopt;
685     d = 2; prism.b = funvalue("arg", 1, &d);
686     if(prism.b < 0.) goto badopt;
687     d = 3; prism.c = funvalue("arg", 1, &d);
688     if(prism.c < 0.) goto badopt;
689     d = 4; prism.d = funvalue("arg", 1, &d);
690     if(prism.d < 0.) goto badopt;
691     d = 5; prism.np = funvalue("arg", 1, &d);
692     if(prism.np < 1.) goto badopt;
693     d = 6; seuil = funvalue("arg", 1, &d);
694     if (seuil < 0. || seuil >=1) goto badopt;
695     d = 7; tot_ref = (int)(funvalue("arg", 1, &d) + .5);
696     if (tot_ref != 1 && tot_ref != 2 && tot_ref != 4) goto badopt;
697     if (tot_ref < 4 )
698     {
699     d = 8; fact_ref[tot_ref] = funvalue("arg", 1, &d);
700     if (fact_ref[tot_ref] < 0. || fact_ref[tot_ref] > 1.) goto badopt;
701     }
702     d = 9; tolerance = funvalue("arg", 1, &d);
703     if (tolerance <= 0.) goto badopt;
704     d = 10; tolsource = funvalue("arg", 1, &d);
705     if (tolsource < 0. ) goto badopt;
706     X(r_initial) = varvalue("Dx");
707     Y(r_initial) = varvalue("Dy");
708     Z(r_initial) = varvalue("Dz");
709     #ifdef DEBUG
710     fprintf(stderr,"dx=%lf dy=%lf dz=%lf\n",X(r_initial),Y(r_initial),Z(r_initial));
711     #endif
712
713     /* initialisation */
714     prepare_matrices();
715     r_initial.e = 1.0;
716     r_initial.n = 1.0;
717
718     if(ray!=NULL) free(ray);
719     nbrayons = 0;
720     /* determination de l'origine et de la destination du rayon initial */
721
722     if ( X(r_initial) != 0.)
723     {
724     if ( X(r_initial) > 0. )
725     {
726     r_initial.orig = r_initial.dest = ALPHA;
727     sens = 1;
728     }
729     else if ( X(r_initial) < 0. )
730     {
731     r_initial.orig = r_initial.dest = DELTA;
732     sens = -1;
733     }
734
735     normalize(r_initial.v);
736
737     trace_rayon(r_initial);
738
739     X(rsource) = varvalue("DxA");
740     Y(rsource) = varvalue("DyA");
741     Z(rsource) = varvalue("DzA");
742     nosource = ( X(rsource)==0. && Y(rsource)==0. && Z(rsource)==0. );
743     if ( !nosource )
744     {
745     for (j=0; j<nbrayons; j++)
746     {
747     if ( !compare(ray[j],rsource,tolsource) ) ray[j].e =0.;
748     }
749     }
750     for (j = 0; j < nbrayons; j++)
751     {
752     for (i = j+1; i < nbrayons; i++)
753     {
754     if (ray[j].e < ray[i].e) inverser(&ray[j],&ray[i]);
755     }
756     }
757
758     bidon = 1;
759     }
760     else bidon = 0;
761     return;
762
763     /* message puis sortie si erreur dans la ligne de commande */
764     badopt:
765     bidon = BADVAL;
766     return;
767     }
768 greg 2.2
769
770     static double
771 schorsch 2.7 l_get_val(
772     char *nm
773     )
774 greg 2.2 {
775     int val, dir, i, trouve, curseur;
776     int nb;
777     double valeur;
778     TRAYON *rayt, raynull;
779
780     if (prismclock < 0 || prismclock < eclock) setprism();
781     if (bidon == BADVAL) {
782     errno = EDOM;
783     return(0.0);
784     }
785     val = (int)(argument(1) + .5);
786     dir = (int)(argument(2) + .5);
787     nb = (int)(argument(3) + .5);
788     X(raynull) = bidon;
789     Y(raynull) = Z(raynull) = 0.;
790     raynull.e = 0.;
791     trouve = curseur = 0;
792     if ( !nosource && nb==2 ) nb=1; /* on est en train de tracer la source
793     a partir de sa seconde source virtuelle */
794     #ifdef DEBUG
795     fprintf(stderr, " On considere le rayon no: %d\n", nb);
796     #endif
797     for(i=0; i < nbrayons &&!trouve; i++)
798     {
799     if(ray[i].v[0] * dir * sens >= 0.) curseur ++;
800     if(curseur == nb)
801     {
802     rayt = &ray[i];
803     trouve = 1;
804     }
805     }
806     if(!trouve) rayt = &raynull;
807     switch(val) {
808     case 0 : valeur = rayt->v[0];
809     break;
810     case 1 : valeur = rayt->v[1];
811     break;
812     case 2 : valeur = rayt->v[2];
813     break;
814     case 3 : valeur = rayt->e;
815     break;
816     default : errno = EDOM; return(0.0);
817     }
818     #ifdef DEBUG
819     fprintf(stderr, "get_val( %i, %i, %i) = %lf\n",val,dir,nb,valeur);
820     #endif
821     return valeur;
822     }
823
824 greg 2.1
825 schorsch 2.7 extern void
826     setprismfuncs(void) /* declared in func.h */
827 greg 2.1 {
828     funset("fprism_val", 3, '=', l_get_val);
829     }
