--- ray/src/rt/fprism.c 1994/12/12 12:22:48 2.2 +++ ray/src/rt/fprism.c 2003/08/04 22:37:53 2.6 @@ -1,9 +1,6 @@ -/* Copyright (c) 1993 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: fprism.c,v 2.6 2003/08/04 22:37:53 greg Exp $"; #endif - /* Ce programme calcule les directions et les energies des rayons lumineux resultant du passage d'un rayon au travers d'un vitrage prismatique @@ -24,7 +21,6 @@ double x; return(0.); return(sqrt(x)); } -#define sqrt(x) Sqrt(x) /* definitions de macros utiles */ @@ -103,7 +99,7 @@ extern long eclock; /* Definition des routines */ -#define term(a,b) a/sqrt(a*a+b*b) +#define term(a,b) a/Sqrt(a*a+b*b) static prepare_matrices() { @@ -209,7 +205,7 @@ FVECT v,v_out; FVECT v_temp; double det; - det = sqrt( (YY(v)*YY(v)+ZZ(v)*ZZ(v))*(YY(v)*YY(v)+ZZ(v)*ZZ(v))+ + det = Sqrt( (YY(v)*YY(v)+ZZ(v)*ZZ(v))*(YY(v)*YY(v)+ZZ(v)*ZZ(v))+ (XX(v)*XX(v)*YY(v)*YY(v))+(XX(v)*XX(v)*ZZ(v)*ZZ(v)) ); XX(v_temp) = (YY(v)*YY(v)+ZZ(v)*ZZ(v))/det; YY(v_temp) = -( XX(v)*YY(v) )/det; @@ -227,7 +223,7 @@ FVECT v,v_out; FVECT v_temp; double det; - det = sqrt( (ZZ(v)*ZZ(v)+YY(v)*YY(v)) ); + det = Sqrt( (ZZ(v)*ZZ(v)+YY(v)*YY(v)) ); XX(v_temp) = 0.; YY(v_temp) = -ZZ(v)/det; ZZ(v_temp) = YY(v)/det; @@ -404,7 +400,7 @@ if(r.e > seuil) if (egalite == 0) { if (nbrayons == 0) ray = (TRAYON *)calloc(1,sizeof(TRAYON)); - else ray = (TRAYON *)realloc(ray, (nbrayons+1)*(sizeof(TRAYON))); + else ray = (TRAYON *)realloc((void *)ray, (nbrayons+1)*(sizeof(TRAYON))); if (ray == NULL) error(SYSTEM, "out of memory in sortie\n"); raytemp = &ray[nbrayons]; @@ -427,9 +423,9 @@ TRAYON r; { double det; - det = sqrt(X(r)*X(r)+Y(r)*Y(r)+Z(r)*Z(r)); - sinus = sqrt(Y(r)*Y(r)+Z(r)*Z(r))/det; - cosinus = sqrt(X(r)*X(r))/det; + det = Sqrt(X(r)*X(r)+Y(r)*Y(r)+Z(r)*Z(r)); + sinus = Sqrt(Y(r)*Y(r)+Z(r)*Z(r))/det; + cosinus = Sqrt(X(r)*X(r))/det; if (r.n == 1.) rapport = prism.np * prism.np; else rapport = 1./(prism.np * prism.np); return; @@ -448,7 +444,7 @@ TRAYON r_incident; X(r_reflechi) = -X(r_incident); Y(r_reflechi) = Y(r_incident); Z(r_reflechi) = Z(r_incident); - if(sinus > sqrt(rapport) || r_incident.dest == tot_ref) + if(sinus > Sqrt(rapport) || r_incident.dest == tot_ref) { r_reflechi.ppar1 = r_incident.ppar1; r_reflechi.pper1 = r_incident.pper1; @@ -458,14 +454,14 @@ TRAYON r_incident; } else { - r_reflechi.ppar1 = r_incident.ppar1*(rapport*cosinus-sqrt(rapport- - (sinus*sinus)))/(rapport*cosinus+sqrt(rapport-(sinus*sinus))); - r_reflechi.pper1 = r_incident.pper1*(cosinus-sqrt - (rapport-(sinus*sinus)))/(cosinus+sqrt(rapport-(sinus*sinus))); - r_reflechi.ppar2 = r_incident.ppar2*(rapport*cosinus-sqrt(rapport- - (sinus*sinus)))/(rapport*cosinus+sqrt(rapport-(sinus*sinus))); - r_reflechi.pper2 = r_incident.pper2*(cosinus-sqrt - (rapport-(sinus*sinus)))/(cosinus+sqrt(rapport-(sinus*sinus))); + r_reflechi.ppar1 = r_incident.ppar1*(rapport*cosinus-Sqrt(rapport- + (sinus*sinus)))/(rapport*cosinus+Sqrt(rapport-(sinus*sinus))); + r_reflechi.pper1 = r_incident.pper1*(cosinus-Sqrt + (rapport-(sinus*sinus)))/(cosinus+Sqrt(rapport-(sinus*sinus))); + r_reflechi.ppar2 = r_incident.ppar2*(rapport*cosinus-Sqrt(rapport- + (sinus*sinus)))/(rapport*cosinus+Sqrt(rapport-(sinus*sinus))); + r_reflechi.pper2 = r_incident.pper2*(cosinus-Sqrt + (rapport-(sinus*sinus)))/(cosinus+Sqrt(rapport-(sinus*sinus))); r_reflechi.e = r_incident.e *(((r_reflechi.ppar1*r_reflechi.ppar1+ r_reflechi.pper1*r_reflechi.pper1)/(r_incident.ppar1*r_incident.ppar1+ r_incident.pper1*r_incident.pper1))+((r_reflechi.ppar2*r_reflechi.ppar2 @@ -487,22 +483,22 @@ TRAYON r_incident; r_transmis = r_incident; trigo(r_incident); - if (sinus <= sqrt(rapport) && r_incident.dest != tot_ref) + if (sinus <= Sqrt(rapport) && r_incident.dest != tot_ref) { X(r_transmis) = (X(r_incident)/(fabs(X(r_incident))))* - (sqrt(1.-(Y(r_incident)*Y(r_incident)+Z(r_incident)* + (Sqrt(1.-(Y(r_incident)*Y(r_incident)+Z(r_incident)* Z(r_incident))/rapport)); - Y(r_transmis) = Y(r_incident)/sqrt(rapport); - Z(r_transmis) = Z(r_incident)/sqrt(rapport); - r_transmis.ppar1 = r_incident.ppar1*2.*sqrt(rapport)*cosinus/ - (sqrt(rapport-sinus*sinus)+rapport*cosinus); - r_transmis.pper1 = r_incident.pper1*2.*cosinus/(cosinus+sqrt(rapport + Y(r_transmis) = Y(r_incident)/Sqrt(rapport); + Z(r_transmis) = Z(r_incident)/Sqrt(rapport); + r_transmis.ppar1 = r_incident.ppar1*2.*Sqrt(rapport)*cosinus/ + (Sqrt(rapport-sinus*sinus)+rapport*cosinus); + r_transmis.pper1 = r_incident.pper1*2.*cosinus/(cosinus+Sqrt(rapport - sinus*sinus)); - r_transmis.ppar2 = r_incident.ppar2*2.*sqrt(rapport)*cosinus/ - (sqrt(rapport-sinus*sinus)+rapport*cosinus); - r_transmis.pper2 = r_incident.pper2*2.*cosinus/(cosinus+sqrt(rapport + r_transmis.ppar2 = r_incident.ppar2*2.*Sqrt(rapport)*cosinus/ + (Sqrt(rapport-sinus*sinus)+rapport*cosinus); + r_transmis.pper2 = r_incident.pper2*2.*cosinus/(cosinus+Sqrt(rapport - sinus*sinus)); - r_transmis.e = (r_incident.e/2)*(sqrt(rapport-sinus*sinus)/cosinus) + r_transmis.e = (r_incident.e/2)*(Sqrt(rapport-sinus*sinus)/cosinus) *(((r_transmis.ppar1*r_transmis.ppar1+r_transmis.pper1* r_transmis.pper1) /(r_incident.ppar1*r_incident.ppar1+r_incident.pper1* @@ -732,7 +728,7 @@ if ( X(r_initial) != 0.) static double -l_get_val() +l_get_val(char *nm) { int val, dir, i, trouve, curseur;
