1 |
greg |
2.10 |
/* RCSid $Id: driver.h,v 2.9 2004/03/30 16:13:01 schorsch Exp $ */ |
2 |
greg |
1.1 |
3 |
* driver.h - header file for interactive device drivers. |
4 |
greg |
2.4 |
5 |
schorsch |
2.6 |
#ifndef _RAD_DRIVER_H_ |
6 |
#define _RAD_DRIVER_H_ |
7 |
schorsch |
2.8 |
8 |
#include "color.h" |
9 |
10 |
schorsch |
2.6 |
#ifdef __cplusplus |
11 |
extern "C" { |
12 |
#endif |
13 |
greg |
1.1 |
14 |
schorsch |
2.9 |
typedef struct driver *dr_initf_t(char *dname, char *id); |
15 |
typedef int dr_getchf_t(void); |
16 |
typedef void dr_newcolrf_t(int ndx, int r, int g, int b); |
17 |
18 |
typedef void dr_closef_t(void); |
19 |
typedef void dr_clearf_t(int, int); |
20 |
typedef void dr_paintrf_t(COLOR col, int xmin, int ymin, int xmax, int ymax); |
21 |
typedef int dr_getcurf_t(int*,int*); |
22 |
typedef void dr_comoutf_t(char*); |
23 |
typedef void dr_cominf_t(char*,char*); |
24 |
typedef void dr_flushf_t(void); |
25 |
26 |
greg |
1.1 |
struct driver { /* driver functions */ |
27 |
schorsch |
2.9 |
dr_closef_t *close; /* close device */ |
28 |
dr_clearf_t *clear; /* clear device */ |
29 |
dr_paintrf_t *paintr; /* paint rectangle */ |
30 |
dr_getcurf_t *getcur; /* get cursor position */ |
31 |
dr_comoutf_t *comout; /* command line output */ |
32 |
dr_cominf_t *comin; /* command line input */ |
33 |
dr_flushf_t *flush; /* flush output */ |
34 |
greg |
1.4 |
double pixaspect; /* pixel aspect ratio */ |
35 |
greg |
1.1 |
int xsiz, ysiz; /* device size */ |
36 |
int inpready; /* input ready on device */ |
37 |
38 |
greg |
1.3 |
/* magic numbers for verification */ |
39 |
#define COM_SENDM 0x6f37 |
40 |
#define COM_RECVM 0x51da |
41 |
greg |
1.1 |
/* stream commands */ |
42 |
#define COM_CLEAR 0 |
43 |
#define COM_PAINTR 1 |
44 |
#define COM_GETCUR 2 |
45 |
#define COM_COMOUT 3 |
46 |
#define COM_COMIN 4 |
47 |
greg |
1.6 |
#define COM_FLUSH 5 |
48 |
#define NREQUESTS 6 /* number of valid requests */ |
49 |
greg |
1.1 |
50 |
greg |
1.4 |
extern struct device { /* interactive device */ |
51 |
greg |
1.1 |
char *name; /* device name */ |
52 |
char *descrip; /* description */ |
53 |
schorsch |
2.9 |
dr_initf_t *init; /* initialize device */ |
54 |
} devtable[]; /* supported devices */ |
55 |
greg |
1.1 |
56 |
greg |
1.8 |
extern char dev_default[]; /* default device name */ |
57 |
58 |
greg |
1.1 |
#define MB1 ('\n') /* mouse button 1 */ |
59 |
#define MB2 ('\r') /* mouse button 2 */ |
60 |
#define MB3 (' ') /* mouse button 3 */ |
61 |
#define ABORT ('C'-'@') /* abort key */ |
62 |
63 |
64 |
schorsch |
2.9 |
* How to write an interactive display driver for rview. |
65 |
66 |
67 |
* static struct driver dname_driver; |
68 |
69 |
* extern dr_initf_t dname_init; |
70 |
71 |
* extern struct driver * |
72 |
* dname_init( |
73 |
* char *name, |
74 |
* char *id |
75 |
76 |
greg |
1.1 |
77 |
* Initialize device and return pointer to driver |
78 |
schorsch |
2.9 |
* dname_driver. Return NULL if an error occurred. |
79 |
greg |
1.3 |
* The name string identifies the driver, |
80 |
* and the id string identifies the client. |
81 |
greg |
1.1 |
* A device can be open by at most one client. |
82 |
gregl |
2.3 |
* Be verbose in error reports; call eputs(). |
83 |
* If device has its own error output, set erract. |
84 |
schorsch |
2.9 |
* This function then needs to be inserted into the |
85 |
* device table in devtable.c. |
86 |
greg |
1.1 |
87 |
schorsch |
2.9 |
88 |
89 |
* static dr_closef_t dname_close; |
90 |
91 |
* dname_driver.close = dname_close; |
92 |
93 |
* static void |
94 |
* dname_close(void) |
95 |
greg |
1.1 |
96 |
greg |
1.2 |
* Close the device. Reset error vectors. |
97 |
greg |
1.1 |
98 |
schorsch |
2.9 |
99 |
100 |
* static dr_clearf_t dname_clear; |
101 |
102 |
* dname_driver.clear = dname_clear; |
103 |
104 |
* static void |
105 |
* dname_clear( |
106 |
* int xres, |
107 |
* int yres; |
108 |
109 |
greg |
1.1 |
110 |
greg |
1.2 |
* Clear the device for xres by yres output. This call will |
111 |
greg |
1.1 |
* be made prior to any output. |
112 |
113 |
schorsch |
2.9 |
114 |
115 |
* static dr_paintrf_t dname_paintr; |
116 |
117 |
* dname_driver.paintr = dname_paintr; |
118 |
119 |
* static void |
120 |
* dname_paintr( |
121 |
* COLOR col, |
122 |
* int xmin, |
123 |
* int ymin, |
124 |
* int xmax, |
125 |
* int ymax |
126 |
127 |
greg |
1.1 |
128 |
* Paint a half-open rectangle from (xmin,ymin) to (xmax,ymax) |
129 |
greg |
1.6 |
* with the color col. |
130 |
greg |
1.1 |
131 |
schorsch |
2.9 |
132 |
133 |
* static dr_getcurf_t dname_getcur; |
134 |
135 |
* dname_driver.getcur = dname_getcur; |
136 |
137 |
* static int |
138 |
* dname_getcur( |
139 |
* int *xp, |
140 |
* int *yp |
141 |
142 |
greg |
1.1 |
143 |
* Get the cursor position entered by the user via mouse, |
144 |
* joystick, etc. Return the key hit by the user (usually |
145 |
* MB1 or MB2). Return ABORT to cancel. |
146 |
* Can be NULL for devices without this capability. |
147 |
148 |
schorsch |
2.9 |
149 |
150 |
* static dr_comoutf_t dname_comout; |
151 |
152 |
* dname_driver.comout = dname_comout; |
153 |
154 |
* static void |
155 |
* dname_comout( |
156 |
* char *out |
157 |
158 |
greg |
1.1 |
159 |
* Print the string out on the device command line. If the |
160 |
* string ends with '\n', the message is considered complete, |
161 |
* and the next call can erase it. |
162 |
163 |
schorsch |
2.9 |
164 |
165 |
* static dr_cominf_t dname_comin; |
166 |
167 |
* dname_driver.comin = dname_comin; |
168 |
169 |
* static void |
170 |
* dname_comin( |
171 |
* char *in, |
172 |
* char *prompt |
173 |
174 |
greg |
1.1 |
175 |
greg |
1.5 |
* Print a prompt then read an edited input command line |
176 |
* assuming the in buffer is big enough. Unless prompt is NULL, |
177 |
* the driver may substitute its own rview command. This is |
178 |
* the most reliable way to repaint areas of the screen. |
179 |
greg |
1.7 |
* If the user enters an unrecognized control character, |
180 |
greg |
1.5 |
* terminate input and return the string with only that character. |
181 |
* The input string should not contain a newline. The routines in |
182 |
* editline.c may be useful. Comin must work in consort with comout. |
183 |
greg |
1.6 |
184 |
schorsch |
2.9 |
185 |
186 |
* static dr_flushf_t dname_flush; |
187 |
188 |
* dname_driver.flush = dname_flush; |
189 |
190 |
* static void |
191 |
* dname_flush(void) |
192 |
greg |
1.6 |
193 |
* Flush output to the display. This is guaranteed to be called |
194 |
* frequently enough to keep the display up to date. |
195 |
* This is an ideal time to check for device input. |
196 |
* This function can be NULL for devices that don't need it. |
197 |
greg |
1.1 |
198 |
schorsch |
2.9 |
199 |
200 |
* dname_driver.xsiz |
201 |
* dname_driver.ysiz |
202 |
203 |
greg |
1.1 |
* The maximum allowable x and y dimensions. If any |
204 |
* size is allowable, these should be set to MAXRES. |
205 |
schorsch |
2.9 |
206 |
207 |
* dname_driver.inpready |
208 |
209 |
greg |
1.2 |
* This variable should be made positive asynchronously |
210 |
* when characters are ready on the input. (Often easiest |
211 |
* to check for input during calls to paintr.) |
212 |
greg |
1.1 |
213 |
greg |
2.4 |
214 |
/* defined in editline.c */ |
215 |
schorsch |
2.9 |
extern void editline(char *buf, dr_getchf_t *c_get, dr_comoutf_t *s_put); |
216 |
greg |
2.4 |
extern void tocombuf(char *b, struct driver *d); |
217 |
extern int fromcombuf(char *b, struct driver *d); |
218 |
schorsch |
2.9 |
219 |
greg |
2.4 |
/* defined in devcomm.c */ |
220 |
schorsch |
2.9 |
extern dr_initf_t slave_init; /* XXX should probably be in a seperate file */ |
221 |
greg |
2.4 |
extern struct driver *comm_init(char *dname, char *id); |
222 |
schorsch |
2.9 |
223 |
greg |
2.4 |
/* defined in colortab.c */ |
224 |
extern int new_ctab(int ncolors); |
225 |
schorsch |
2.9 |
extern int get_pixel(COLOR col, dr_newcolrf_t *newcolr); |
226 |
greg |
2.4 |
extern void make_gmap(double gam); |
227 |
greg |
2.10 |
extern void set_cmap(uby8 *rmap, uby8 *gmap, uby8 *bmap); |
228 |
extern void map_color(uby8 rgb[3], COLOR col); |
229 |
greg |
2.4 |
230 |
schorsch |
2.6 |
231 |
232 |
233 |
greg |
2.4 |
#endif |
234 |
schorsch |
2.6 |
#endif /* _RAD_DRIVER_H_ */ |
235 |
