| 1 |
greg |
2.11 |
/* RCSid $Id: driver.h,v 2.10 2011/05/20 02:06:39 greg Exp $ */
| 2 |
greg |
1.1 |
| 3 |
* driver.h - header file for interactive device drivers.
| 4 |
greg |
2.4 |
| 5 |
schorsch |
2.6 |
#ifndef _RAD_DRIVER_H_
| 6 |
#define _RAD_DRIVER_H_
| 7 |
schorsch |
2.8 |
| 8 |
#include "color.h"
| 9 |
| 10 |
schorsch |
2.6 |
#ifdef __cplusplus
| 11 |
extern "C" {
| 12 |
#endif
| 13 |
greg |
1.1 |
| 14 |
schorsch |
2.9 |
typedef struct driver *dr_initf_t(char *dname, char *id);
| 15 |
typedef int dr_getchf_t(void);
| 16 |
typedef void dr_newcolrf_t(int ndx, int r, int g, int b);
| 17 |
| 18 |
typedef void dr_closef_t(void);
| 19 |
typedef void dr_clearf_t(int, int);
| 20 |
typedef void dr_paintrf_t(COLOR col, int xmin, int ymin, int xmax, int ymax);
| 21 |
typedef int dr_getcurf_t(int*,int*);
| 22 |
greg |
2.11 |
typedef void dr_comoutf_t(const char*);
| 23 |
schorsch |
2.9 |
typedef void dr_cominf_t(char*,char*);
| 24 |
typedef void dr_flushf_t(void);
| 25 |
| 26 |
greg |
1.1 |
struct driver { /* driver functions */
| 27 |
schorsch |
2.9 |
dr_closef_t *close; /* close device */
| 28 |
dr_clearf_t *clear; /* clear device */
| 29 |
dr_paintrf_t *paintr; /* paint rectangle */
| 30 |
dr_getcurf_t *getcur; /* get cursor position */
| 31 |
dr_comoutf_t *comout; /* command line output */
| 32 |
dr_cominf_t *comin; /* command line input */
| 33 |
dr_flushf_t *flush; /* flush output */
| 34 |
greg |
1.4 |
double pixaspect; /* pixel aspect ratio */
| 35 |
greg |
1.1 |
int xsiz, ysiz; /* device size */
| 36 |
int inpready; /* input ready on device */
| 37 |
| 38 |
greg |
1.3 |
/* magic numbers for verification */
| 39 |
#define COM_SENDM 0x6f37
| 40 |
#define COM_RECVM 0x51da
| 41 |
greg |
1.1 |
/* stream commands */
| 42 |
#define COM_CLEAR 0
| 43 |
#define COM_PAINTR 1
| 44 |
#define COM_GETCUR 2
| 45 |
#define COM_COMOUT 3
| 46 |
#define COM_COMIN 4
| 47 |
greg |
1.6 |
#define COM_FLUSH 5
| 48 |
#define NREQUESTS 6 /* number of valid requests */
| 49 |
greg |
1.1 |
| 50 |
greg |
1.4 |
extern struct device { /* interactive device */
| 51 |
greg |
1.1 |
char *name; /* device name */
| 52 |
char *descrip; /* description */
| 53 |
schorsch |
2.9 |
dr_initf_t *init; /* initialize device */
| 54 |
} devtable[]; /* supported devices */
| 55 |
greg |
1.1 |
| 56 |
greg |
1.8 |
extern char dev_default[]; /* default device name */
| 57 |
| 58 |
greg |
1.1 |
#define MB1 ('\n') /* mouse button 1 */
| 59 |
#define MB2 ('\r') /* mouse button 2 */
| 60 |
#define MB3 (' ') /* mouse button 3 */
| 61 |
#define ABORT ('C'-'@') /* abort key */
| 62 |
| 63 |
| 64 |
schorsch |
2.9 |
* How to write an interactive display driver for rview.
| 65 |
| 66 |
| 67 |
* static struct driver dname_driver;
| 68 |
| 69 |
* extern dr_initf_t dname_init;
| 70 |
| 71 |
* extern struct driver *
| 72 |
* dname_init(
| 73 |
* char *name,
| 74 |
* char *id
| 75 |
| 76 |
greg |
1.1 |
| 77 |
* Initialize device and return pointer to driver
| 78 |
schorsch |
2.9 |
* dname_driver. Return NULL if an error occurred.
| 79 |
greg |
1.3 |
* The name string identifies the driver,
| 80 |
* and the id string identifies the client.
| 81 |
greg |
1.1 |
* A device can be open by at most one client.
| 82 |
gregl |
2.3 |
* Be verbose in error reports; call eputs().
| 83 |
* If device has its own error output, set erract.
| 84 |
schorsch |
2.9 |
* This function then needs to be inserted into the
| 85 |
* device table in devtable.c.
| 86 |
greg |
1.1 |
| 87 |
schorsch |
2.9 |
| 88 |
| 89 |
* static dr_closef_t dname_close;
| 90 |
| 91 |
* dname_driver.close = dname_close;
| 92 |
| 93 |
* static void
| 94 |
* dname_close(void)
| 95 |
greg |
1.1 |
| 96 |
greg |
1.2 |
* Close the device. Reset error vectors.
| 97 |
greg |
1.1 |
| 98 |
schorsch |
2.9 |
| 99 |
| 100 |
* static dr_clearf_t dname_clear;
| 101 |
| 102 |
* dname_driver.clear = dname_clear;
| 103 |
| 104 |
* static void
| 105 |
* dname_clear(
| 106 |
* int xres,
| 107 |
* int yres;
| 108 |
| 109 |
greg |
1.1 |
| 110 |
greg |
1.2 |
* Clear the device for xres by yres output. This call will
| 111 |
greg |
1.1 |
* be made prior to any output.
| 112 |
| 113 |
schorsch |
2.9 |
| 114 |
| 115 |
* static dr_paintrf_t dname_paintr;
| 116 |
| 117 |
* dname_driver.paintr = dname_paintr;
| 118 |
| 119 |
* static void
| 120 |
* dname_paintr(
| 121 |
* COLOR col,
| 122 |
* int xmin,
| 123 |
* int ymin,
| 124 |
* int xmax,
| 125 |
* int ymax
| 126 |
| 127 |
greg |
1.1 |
| 128 |
* Paint a half-open rectangle from (xmin,ymin) to (xmax,ymax)
| 129 |
greg |
1.6 |
* with the color col.
| 130 |
greg |
1.1 |
| 131 |
schorsch |
2.9 |
| 132 |
| 133 |
* static dr_getcurf_t dname_getcur;
| 134 |
| 135 |
* dname_driver.getcur = dname_getcur;
| 136 |
| 137 |
* static int
| 138 |
* dname_getcur(
| 139 |
* int *xp,
| 140 |
* int *yp
| 141 |
| 142 |
greg |
1.1 |
| 143 |
* Get the cursor position entered by the user via mouse,
| 144 |
* joystick, etc. Return the key hit by the user (usually
| 145 |
* MB1 or MB2). Return ABORT to cancel.
| 146 |
* Can be NULL for devices without this capability.
| 147 |
| 148 |
schorsch |
2.9 |
| 149 |
| 150 |
* static dr_comoutf_t dname_comout;
| 151 |
| 152 |
* dname_driver.comout = dname_comout;
| 153 |
| 154 |
* static void
| 155 |
* dname_comout(
| 156 |
* char *out
| 157 |
| 158 |
greg |
1.1 |
| 159 |
* Print the string out on the device command line. If the
| 160 |
* string ends with '\n', the message is considered complete,
| 161 |
* and the next call can erase it.
| 162 |
| 163 |
schorsch |
2.9 |
| 164 |
| 165 |
* static dr_cominf_t dname_comin;
| 166 |
| 167 |
* dname_driver.comin = dname_comin;
| 168 |
| 169 |
* static void
| 170 |
* dname_comin(
| 171 |
* char *in,
| 172 |
* char *prompt
| 173 |
| 174 |
greg |
1.1 |
| 175 |
greg |
1.5 |
* Print a prompt then read an edited input command line
| 176 |
* assuming the in buffer is big enough. Unless prompt is NULL,
| 177 |
* the driver may substitute its own rview command. This is
| 178 |
* the most reliable way to repaint areas of the screen.
| 179 |
greg |
1.7 |
* If the user enters an unrecognized control character,
| 180 |
greg |
1.5 |
* terminate input and return the string with only that character.
| 181 |
* The input string should not contain a newline. The routines in
| 182 |
* editline.c may be useful. Comin must work in consort with comout.
| 183 |
greg |
1.6 |
| 184 |
schorsch |
2.9 |
| 185 |
| 186 |
* static dr_flushf_t dname_flush;
| 187 |
| 188 |
* dname_driver.flush = dname_flush;
| 189 |
| 190 |
* static void
| 191 |
* dname_flush(void)
| 192 |
greg |
1.6 |
| 193 |
* Flush output to the display. This is guaranteed to be called
| 194 |
* frequently enough to keep the display up to date.
| 195 |
* This is an ideal time to check for device input.
| 196 |
* This function can be NULL for devices that don't need it.
| 197 |
greg |
1.1 |
| 198 |
schorsch |
2.9 |
| 199 |
| 200 |
* dname_driver.xsiz
| 201 |
* dname_driver.ysiz
| 202 |
| 203 |
greg |
1.1 |
* The maximum allowable x and y dimensions. If any
| 204 |
* size is allowable, these should be set to MAXRES.
| 205 |
schorsch |
2.9 |
| 206 |
| 207 |
* dname_driver.inpready
| 208 |
| 209 |
greg |
1.2 |
* This variable should be made positive asynchronously
| 210 |
* when characters are ready on the input. (Often easiest
| 211 |
* to check for input during calls to paintr.)
| 212 |
greg |
1.1 |
| 213 |
greg |
2.4 |
| 214 |
/* defined in editline.c */
| 215 |
schorsch |
2.9 |
extern void editline(char *buf, dr_getchf_t *c_get, dr_comoutf_t *s_put);
| 216 |
greg |
2.4 |
extern void tocombuf(char *b, struct driver *d);
| 217 |
extern int fromcombuf(char *b, struct driver *d);
| 218 |
schorsch |
2.9 |
| 219 |
greg |
2.4 |
/* defined in devcomm.c */
| 220 |
schorsch |
2.9 |
extern dr_initf_t slave_init; /* XXX should probably be in a seperate file */
| 221 |
greg |
2.4 |
extern struct driver *comm_init(char *dname, char *id);
| 222 |
schorsch |
2.9 |
| 223 |
greg |
2.4 |
/* defined in colortab.c */
| 224 |
extern int new_ctab(int ncolors);
| 225 |
schorsch |
2.9 |
extern int get_pixel(COLOR col, dr_newcolrf_t *newcolr);
| 226 |
greg |
2.4 |
extern void make_gmap(double gam);
| 227 |
greg |
2.10 |
extern void set_cmap(uby8 *rmap, uby8 *gmap, uby8 *bmap);
| 228 |
extern void map_color(uby8 rgb[3], COLOR col);
| 229 |
greg |
2.4 |
| 230 |
schorsch |
2.6 |
| 231 |
#ifdef __cplusplus
| 232 |
| 233 |
greg |
2.4 |
#endif
| 234 |
schorsch |
2.6 |
#endif /* _RAD_DRIVER_H_ */
| 235 |
