| 1 |
/* RCSid: $Id$ */
| 2 |
| 3 |
* driver.h - header file for interactive device drivers.
| 4 |
| 5 |
| 6 |
| 7 |
* The Radiance Software License, Version 1.0
| 8 |
| 9 |
* Copyright (c) 1990 - 2002 The Regents of the University of California,
| 10 |
* through Lawrence Berkeley National Laboratory. All rights reserved.
| 11 |
| 12 |
* Redistribution and use in source and binary forms, with or without
| 13 |
* modification, are permitted provided that the following conditions
| 14 |
* are met:
| 15 |
| 16 |
* 1. Redistributions of source code must retain the above copyright
| 17 |
* notice, this list of conditions and the following disclaimer.
| 18 |
| 19 |
* 2. Redistributions in binary form must reproduce the above copyright
| 20 |
* notice, this list of conditions and the following disclaimer in
| 21 |
* the documentation and/or other materials provided with the
| 22 |
* distribution.
| 23 |
| 24 |
* 3. The end-user documentation included with the redistribution,
| 25 |
* if any, must include the following acknowledgment:
| 26 |
* "This product includes Radiance software
| 27 |
* (http://radsite.lbl.gov/)
| 28 |
* developed by the Lawrence Berkeley National Laboratory
| 29 |
* (http://www.lbl.gov/)."
| 30 |
* Alternately, this acknowledgment may appear in the software itself,
| 31 |
* if and wherever such third-party acknowledgments normally appear.
| 32 |
| 33 |
* 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
| 34 |
* and "The Regents of the University of California" must
| 35 |
* not be used to endorse or promote products derived from this
| 36 |
* software without prior written permission. For written
| 37 |
* permission, please contact [email protected].
| 38 |
| 39 |
* 5. Products derived from this software may not be called "Radiance",
| 40 |
* nor may "Radiance" appear in their name, without prior written
| 41 |
* permission of Lawrence Berkeley National Laboratory.
| 42 |
| 43 |
* THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
| 44 |
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
| 45 |
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
| 46 |
* DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
| 47 |
* ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
| 48 |
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
| 49 |
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
| 50 |
* USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
| 51 |
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
| 52 |
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
| 53 |
* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
| 54 |
* SUCH DAMAGE.
| 55 |
| 56 |
| 57 |
* This software consists of voluntary contributions made by many
| 58 |
* individuals on behalf of Lawrence Berkeley National Laboratory. For more
| 59 |
* information on Lawrence Berkeley National Laboratory, please see
| 60 |
* <http://www.lbl.gov/>.
| 61 |
| 62 |
| 63 |
struct driver { /* driver functions */
| 64 |
void (*close)(); /* close device */
| 65 |
void (*clear)(); /* clear device */
| 66 |
void (*paintr)(); /* paint rectangle */
| 67 |
int (*getcur)(); /* get cursor position */
| 68 |
void (*comout)(); /* command line output */
| 69 |
void (*comin)(); /* command line input */
| 70 |
void (*flush)(); /* flush output */
| 71 |
double pixaspect; /* pixel aspect ratio */
| 72 |
int xsiz, ysiz; /* device size */
| 73 |
int inpready; /* input ready on device */
| 74 |
| 75 |
/* magic numbers for verification */
| 76 |
#define COM_SENDM 0x6f37
| 77 |
#define COM_RECVM 0x51da
| 78 |
/* stream commands */
| 79 |
#define COM_CLEAR 0
| 80 |
#define COM_PAINTR 1
| 81 |
#define COM_GETCUR 2
| 82 |
#define COM_COMOUT 3
| 83 |
#define COM_COMIN 4
| 84 |
#define COM_FLUSH 5
| 85 |
#define NREQUESTS 6 /* number of valid requests */
| 86 |
| 87 |
extern struct device { /* interactive device */
| 88 |
char *name; /* device name */
| 89 |
char *descrip; /* description */
| 90 |
struct driver *(*init)(); /* initialize device */
| 91 |
} devtable[]; /* supported devices */
| 92 |
| 93 |
extern char dev_default[]; /* default device name */
| 94 |
| 95 |
#define MB1 ('\n') /* mouse button 1 */
| 96 |
#define MB2 ('\r') /* mouse button 2 */
| 97 |
#define MB3 (' ') /* mouse button 3 */
| 98 |
#define ABORT ('C'-'@') /* abort key */
| 99 |
| 100 |
| 101 |
* struct driver *
| 102 |
* dname_init(name, id)
| 103 |
* char *name, *id;
| 104 |
| 105 |
* Initialize device and return pointer to driver
| 106 |
* functions. Returns NULL if an error occurred.
| 107 |
* The name string identifies the driver,
| 108 |
* and the id string identifies the client.
| 109 |
* A device can be open by at most one client.
| 110 |
* Be verbose in error reports; call eputs().
| 111 |
* If device has its own error output, set erract.
| 112 |
| 113 |
* (*dev->close)()
| 114 |
| 115 |
* Close the device. Reset error vectors.
| 116 |
| 117 |
* (*dev->clear)(xres, yres)
| 118 |
* int xres, yres;
| 119 |
| 120 |
* Clear the device for xres by yres output. This call will
| 121 |
* be made prior to any output.
| 122 |
| 123 |
* (*dev->paintr)(col, xmin, ymin, xmax, ymax)
| 124 |
* COLOR col;
| 125 |
* int xmin, ymin, xmax, ymax;
| 126 |
| 127 |
* Paint a half-open rectangle from (xmin,ymin) to (xmax,ymax)
| 128 |
* with the color col.
| 129 |
| 130 |
* (*dev->getcur)(xp, yp)
| 131 |
* int *xp, *yp;
| 132 |
| 133 |
* Get the cursor position entered by the user via mouse,
| 134 |
* joystick, etc. Return the key hit by the user (usually
| 135 |
* MB1 or MB2). Return ABORT to cancel.
| 136 |
* Can be NULL for devices without this capability.
| 137 |
| 138 |
* (*dev->comout)(out)
| 139 |
* char *out;
| 140 |
| 141 |
* Print the string out on the device command line. If the
| 142 |
* string ends with '\n', the message is considered complete,
| 143 |
* and the next call can erase it.
| 144 |
| 145 |
* (*dev->comin)(in, prompt)
| 146 |
* char *in, *prompt;
| 147 |
| 148 |
* Print a prompt then read an edited input command line
| 149 |
* assuming the in buffer is big enough. Unless prompt is NULL,
| 150 |
* the driver may substitute its own rview command. This is
| 151 |
* the most reliable way to repaint areas of the screen.
| 152 |
* If the user enters an unrecognized control character,
| 153 |
* terminate input and return the string with only that character.
| 154 |
* The input string should not contain a newline. The routines in
| 155 |
* editline.c may be useful. Comin must work in consort with comout.
| 156 |
| 157 |
* (*dev->flush)()
| 158 |
| 159 |
* Flush output to the display. This is guaranteed to be called
| 160 |
* frequently enough to keep the display up to date.
| 161 |
* This is an ideal time to check for device input.
| 162 |
* This function can be NULL for devices that don't need it.
| 163 |
| 164 |
* xsiz, ysiz
| 165 |
* The maximum allowable x and y dimensions. If any
| 166 |
* size is allowable, these should be set to MAXRES.
| 167 |
* inpready
| 168 |
* This variable should be made positive asynchronously
| 169 |
* when characters are ready on the input. (Often easiest
| 170 |
* to check for input during calls to paintr.)
| 171 |
| 172 |
| 173 |
#ifdef NOPROTO
| 174 |
| 175 |
extern void editline();
| 176 |
extern void tocombuf();
| 177 |
extern int fromcombuf();
| 178 |
extern struct driver *slave_init();
| 179 |
extern struct driver *comm_init();
| 180 |
extern int new_ctab();
| 181 |
extern int get_pixel();
| 182 |
extern void make_gmap();
| 183 |
extern void set_cmap();
| 184 |
extern void map_color();
| 185 |
| 186 |
#else
| 187 |
/* defined in editline.c */
| 188 |
extern void editline(char *buf, int (*c_get)(), void (*s_put)());
| 189 |
extern void tocombuf(char *b, struct driver *d);
| 190 |
extern int fromcombuf(char *b, struct driver *d);
| 191 |
/* defined in devcomm.c */
| 192 |
extern struct driver *slave_init(char *dname, char *id);
| 193 |
extern struct driver *comm_init(char *dname, char *id);
| 194 |
/* defined in colortab.c */
| 195 |
extern int new_ctab(int ncolors);
| 196 |
extern int get_pixel(COLOR col, void (*set_pixel)());
| 197 |
extern void make_gmap(double gam);
| 198 |
extern void set_cmap(BYTE *rmap, BYTE *gmap, BYTE *bmap);
| 199 |
extern void map_color(BYTE rgb[3], COLOR col);
| 200 |
| 201 |
#endif
