root/radiance/ray/src/rt/driver.h
Revision: 2.2
Committed: Mon Apr 5 15:16:46 1993 UTC (31 years, 1 month ago) by greg
Changes since 2.1: +2 -1 lines
added slave_init() for slave mode of rview
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * driver.h - header file for interactive device drivers.
7 *
8 * 2/2/87
9 */
10
11 struct driver { /* driver functions */
12 int (*close)(); /* close device */
13 int (*clear)(); /* clear device */
14 int (*paintr)(); /* paint rectangle */
15 int (*getcur)(); /* get cursor position */
16 int (*comout)(); /* command line output */
17 int (*comin)(); /* command line input */
18 int (*flush)(); /* flush output */
19 double pixaspect; /* pixel aspect ratio */
20 int xsiz, ysiz; /* device size */
21 int inpready; /* input ready on device */
22 };
23
24 extern int stderr_v(); /* error vectors */
25 extern int (*wrnvec)(), (*errvec)(), (*cmdvec)();
26
27 /* stream interface */
28 extern struct driver *comm_init(), *slave_init();
29 /* magic numbers for verification */
30 #define COM_SENDM 0x6f37
31 #define COM_RECVM 0x51da
32 /* stream commands */
33 #define COM_CLEAR 0
34 #define COM_PAINTR 1
35 #define COM_GETCUR 2
36 #define COM_COMOUT 3
37 #define COM_COMIN 4
38 #define COM_FLUSH 5
39 #define NREQUESTS 6 /* number of valid requests */
40
41 extern struct device { /* interactive device */
42 char *name; /* device name */
43 char *descrip; /* description */
44 struct driver *(*init)(); /* initialize device */
45 } devtable[]; /* supported devices */
46
47 extern char dev_default[]; /* default device name */
48
49 #define MB1 ('\n') /* mouse button 1 */
50 #define MB2 ('\r') /* mouse button 2 */
51 #define MB3 (' ') /* mouse button 3 */
52 #define ABORT ('C'-'@') /* abort key */
53
54 /*
55 * struct driver *
56 * dname_init(name, id)
57 * char *name, *id;
58 * {
59 * Initialize device and return pointer to driver
60 * functions. Returns NULL if an error occurred.
61 * The name string identifies the driver,
62 * and the id string identifies the client.
63 * A device can be open by at most one client.
64 * Be verbose in error reports; call stderr_v().
65 * If device has its own error output, set errvec,
66 * cmdvec and wrnvec.
67 * }
68 * (*dev->close)()
69 * {
70 * Close the device. Reset error vectors.
71 * }
72 * (*dev->clear)(xres, yres)
73 * int xres, yres;
74 * {
75 * Clear the device for xres by yres output. This call will
76 * be made prior to any output.
77 * }
78 * (*dev->paintr)(col, xmin, ymin, xmax, ymax)
79 * COLOR col;
80 * int xmin, ymin, xmax, ymax;
81 * {
82 * Paint a half-open rectangle from (xmin,ymin) to (xmax,ymax)
83 * with the color col.
84 * }
85 * (*dev->getcur)(xp, yp)
86 * int *xp, *yp;
87 * {
88 * Get the cursor position entered by the user via mouse,
89 * joystick, etc. Return the key hit by the user (usually
90 * MB1 or MB2). Return ABORT to cancel.
91 * Can be NULL for devices without this capability.
92 * }
93 * (*dev->comout)(out)
94 * char *out;
95 * {
96 * Print the string out on the device command line. If the
97 * string ends with '\n', the message is considered complete,
98 * and the next call can erase it.
99 * }
100 * (*dev->comin)(in, prompt)
101 * char *in, *prompt;
102 * {
103 * Print a prompt then read an edited input command line
104 * assuming the in buffer is big enough. Unless prompt is NULL,
105 * the driver may substitute its own rview command. This is
106 * the most reliable way to repaint areas of the screen.
107 * If the user enters an unrecognized control character,
108 * terminate input and return the string with only that character.
109 * The input string should not contain a newline. The routines in
110 * editline.c may be useful. Comin must work in consort with comout.
111 * }
112 * (*dev->flush)()
113 * {
114 * Flush output to the display. This is guaranteed to be called
115 * frequently enough to keep the display up to date.
116 * This is an ideal time to check for device input.
117 * This function can be NULL for devices that don't need it.
118 * }
119 * xsiz, ysiz
120 * The maximum allowable x and y dimensions. If any
121 * size is allowable, these should be set to MAXRES.
122 * inpready
123 * This variable should be made positive asynchronously
124 * when characters are ready on the input. (Often easiest
125 * to check for input during calls to paintr.)
126 */
