| 1 |
/* Copyright (c) 1987 Regents of the University of California */
| 2 |
| 3 |
/* SCCSid "$SunId$ LBL" */
| 4 |
| 5 |
| 6 |
* driver.h - header file for interactive device drivers.
| 7 |
| 8 |
* 2/2/87
| 9 |
| 10 |
| 11 |
struct driver { /* driver functions */
| 12 |
int (*close)(); /* close device */
| 13 |
int (*clear)(); /* clear device */
| 14 |
int (*paintr)(); /* paint rectangle */
| 15 |
int (*getcur)(); /* get cursor position */
| 16 |
int (*comout)(); /* command line output */
| 17 |
int (*comin)(); /* command line input */
| 18 |
double pixaspect; /* pixel aspect ratio */
| 19 |
int xsiz, ysiz; /* device size */
| 20 |
int inpready; /* input ready on device */
| 21 |
| 22 |
| 23 |
extern int stderr_v(); /* error vectors */
| 24 |
extern int (*wrnvec)(), (*errvec)(), (*cmdvec)();
| 25 |
| 26 |
extern struct driver *comm_init(); /* stream interface */
| 27 |
/* magic numbers for verification */
| 28 |
#define COM_SENDM 0x6f37
| 29 |
#define COM_RECVM 0x51da
| 30 |
/* stream commands */
| 31 |
#define COM_CLEAR 0
| 32 |
#define COM_PAINTR 1
| 33 |
#define COM_GETCUR 2
| 34 |
#define COM_COMOUT 3
| 35 |
#define COM_COMIN 4
| 36 |
#define NREQUESTS 5 /* number of valid requests */
| 37 |
| 38 |
extern struct device { /* interactive device */
| 39 |
char *name; /* device name */
| 40 |
char *descrip; /* description */
| 41 |
struct driver *(*init)(); /* initialize device */
| 42 |
} devtable[]; /* supported devices */
| 43 |
| 44 |
#define MB1 ('\n') /* mouse button 1 */
| 45 |
#define MB2 ('\r') /* mouse button 2 */
| 46 |
#define MB3 (' ') /* mouse button 3 */
| 47 |
#define ABORT ('C'-'@') /* abort key */
| 48 |
| 49 |
| 50 |
* struct driver *
| 51 |
* dname_init(name, id)
| 52 |
* char *name, *id;
| 53 |
| 54 |
* Initialize device and return pointer to driver
| 55 |
* functions. Returns NULL if an error occurred.
| 56 |
* The name string identifies the driver,
| 57 |
* and the id string identifies the client.
| 58 |
* A device can be open by at most one client.
| 59 |
* Be verbose in error reports; call stderr_v().
| 60 |
* If device has its own error output, set errvec,
| 61 |
* cmdvec and wrnvec.
| 62 |
| 63 |
* (*dev->close)()
| 64 |
| 65 |
* Close the device. Reset error vectors.
| 66 |
| 67 |
* (*dev->clear)(xres, yres)
| 68 |
* int xres, yres;
| 69 |
| 70 |
* Clear the device for xres by yres output. This call will
| 71 |
* be made prior to any output.
| 72 |
| 73 |
* (*dev->paintr)(col, xmin, ymin, xmax, ymax)
| 74 |
* COLOR col;
| 75 |
* int xmin, ymin, xmax, ymax;
| 76 |
| 77 |
* Paint a half-open rectangle from (xmin,ymin) to (xmax,ymax)
| 78 |
* with the color col. Can call repaint() if necessary.
| 79 |
| 80 |
* (*dev->getcur)(xp, yp)
| 81 |
* int *xp, *yp;
| 82 |
| 83 |
* Get the cursor position entered by the user via mouse,
| 84 |
* joystick, etc. Return the key hit by the user (usually
| 85 |
* MB1 or MB2). Return ABORT to cancel.
| 86 |
* Can be NULL for devices without this capability.
| 87 |
| 88 |
* (*dev->comout)(out)
| 89 |
* char *out;
| 90 |
| 91 |
* Print the string out on the device command line. If the
| 92 |
* string ends with '\n', the message is considered complete,
| 93 |
* and the next call can erase it.
| 94 |
| 95 |
* (*dev->comin)(in, prompt)
| 96 |
* char *in, *prompt;
| 97 |
| 98 |
* Print a prompt then read an edited input command line
| 99 |
* assuming the in buffer is big enough. Unless prompt is NULL,
| 100 |
* the driver may substitute its own rview command. This is
| 101 |
* the most reliable way to repaint areas of the screen.
| 102 |
* If the user enters an unrecognized control character is entered,
| 103 |
* terminate input and return the string with only that character.
| 104 |
* The input string should not contain a newline. The routines in
| 105 |
* editline.c may be useful. Comin must work in consort with comout.
| 106 |
| 107 |
* xsiz, ysiz
| 108 |
* The maximum allowable x and y dimensions. If any
| 109 |
* size is allowable, these should be set to MAXRES.
| 110 |
* inpready
| 111 |
* This variable should be made positive asynchronously
| 112 |
* when characters are ready on the input. (Often easiest
| 113 |
* to check for input during calls to paintr.)
| 114 |
