--- ray/src/rt/driver.h 1990/03/09 14:00:03 1.8 +++ ray/src/rt/driver.h 1997/11/11 20:03:00 2.3 @@ -20,11 +20,8 @@ struct driver { /* driver functions */ int xsiz, ysiz; /* device size */ int inpready; /* input ready on device */ }; - -extern int stderr_v(); /* error vectors */ -extern int (*wrnvec)(), (*errvec)(), (*cmdvec)(); - -extern struct driver *comm_init(); /* stream interface */ + /* stream interface */ +extern struct driver *comm_init(), *slave_init(); /* magic numbers for verification */ #define COM_SENDM 0x6f37 #define COM_RECVM 0x51da @@ -60,9 +57,8 @@ extern char dev_default[]; /* default device name */ * The name string identifies the driver, * and the id string identifies the client. * A device can be open by at most one client. - * Be verbose in error reports; call stderr_v(). - * If device has its own error output, set errvec, - * cmdvec and wrnvec. + * Be verbose in error reports; call eputs(). + * If device has its own error output, set erract. * } * (*dev->close)() * {
