root/radiance/ray/src/rt/driver.h
Revision: 2.10
Committed: Fri May 20 02:06:39 2011 UTC (13 years ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R2P1, rad5R3, HEAD
Changes since 2.9: +3 -3 lines
# User Rev Content
1 greg 2.10 /* RCSid $Id: driver.h,v 2.9 2004/03/30 16:13:01 schorsch Exp $ */
2 greg 1.1 /*
3     * driver.h - header file for interactive device drivers.
4 greg 2.4 */
5 schorsch 2.6 #ifndef _RAD_DRIVER_H_
6     #define _RAD_DRIVER_H_
7 schorsch 2.8
8     #include "color.h"
9
10 schorsch 2.6 #ifdef __cplusplus
11     extern "C" {
12     #endif
13 greg 1.1
14 schorsch 2.9 typedef struct driver *dr_initf_t(char *dname, char *id);
15     typedef int dr_getchf_t(void);
16     typedef void dr_newcolrf_t(int ndx, int r, int g, int b);
17
18     typedef void dr_closef_t(void);
19     typedef void dr_clearf_t(int, int);
20     typedef void dr_paintrf_t(COLOR col, int xmin, int ymin, int xmax, int ymax);
21     typedef int dr_getcurf_t(int*,int*);
22     typedef void dr_comoutf_t(char*);
23     typedef void dr_cominf_t(char*,char*);
24     typedef void dr_flushf_t(void);
25
26 greg 1.1 struct driver { /* driver functions */
27 schorsch 2.9 dr_closef_t *close; /* close device */
28     dr_clearf_t *clear; /* clear device */
29     dr_paintrf_t *paintr; /* paint rectangle */
30     dr_getcurf_t *getcur; /* get cursor position */
31     dr_comoutf_t *comout; /* command line output */
32     dr_cominf_t *comin; /* command line input */
33     dr_flushf_t *flush; /* flush output */
34 greg 1.4 double pixaspect; /* pixel aspect ratio */
35 greg 1.1 int xsiz, ysiz; /* device size */
36     int inpready; /* input ready on device */
37     };
38 greg 1.3 /* magic numbers for verification */
39     #define COM_SENDM 0x6f37
40     #define COM_RECVM 0x51da
41 greg 1.1 /* stream commands */
42     #define COM_CLEAR 0
43     #define COM_PAINTR 1
44     #define COM_GETCUR 2
45     #define COM_COMOUT 3
46     #define COM_COMIN 4
47 greg 1.6 #define COM_FLUSH 5
48     #define NREQUESTS 6 /* number of valid requests */
49 greg 1.1
50 greg 1.4 extern struct device { /* interactive device */
51 greg 1.1 char *name; /* device name */
52     char *descrip; /* description */
53 schorsch 2.9 dr_initf_t *init; /* initialize device */
54     } devtable[]; /* supported devices */
55 greg 1.1
56 greg 1.8 extern char dev_default[]; /* default device name */
57
58 greg 1.1 #define MB1 ('\n') /* mouse button 1 */
59     #define MB2 ('\r') /* mouse button 2 */
60     #define MB3 (' ') /* mouse button 3 */
61     #define ABORT ('C'-'@') /* abort key */
62
63     /*
64 schorsch 2.9 * How to write an interactive display driver for rview.
65     * ----------------------------------------------------
66     *
67     * static struct driver dname_driver;
68     *
69     * extern dr_initf_t dname_init;
70     *
71     * extern struct driver *
72     * dname_init(
73     * char *name,
74     * char *id
75     * )
76 greg 1.1 * {
77     * Initialize device and return pointer to driver
78 schorsch 2.9 * dname_driver. Return NULL if an error occurred.
79 greg 1.3 * The name string identifies the driver,
80     * and the id string identifies the client.
81 greg 1.1 * A device can be open by at most one client.
82 gregl 2.3 * Be verbose in error reports; call eputs().
83     * If device has its own error output, set erract.
84 schorsch 2.9 * This function then needs to be inserted into the
85     * device table in devtable.c.
86 greg 1.1 * }
87 schorsch 2.9 *
88     *
89     * static dr_closef_t dname_close;
90     *
91     * dname_driver.close = dname_close;
92     *
93     * static void
94     * dname_close(void)
95 greg 1.1 * {
96 greg 1.2 * Close the device. Reset error vectors.
97 greg 1.1 * }
98 schorsch 2.9 *
99     *
100     * static dr_clearf_t dname_clear;
101     *
102     * dname_driver.clear = dname_clear;
103     *
104     * static void
105     * dname_clear(
106     * int xres,
107     * int yres;
108     * )
109 greg 1.1 * {
110 greg 1.2 * Clear the device for xres by yres output. This call will
111 greg 1.1 * be made prior to any output.
112     * }
113 schorsch 2.9 *
114     *
115     * static dr_paintrf_t dname_paintr;
116     *
117     * dname_driver.paintr = dname_paintr;
118     *
119     * static void
120     * dname_paintr(
121     * COLOR col,
122     * int xmin,
123     * int ymin,
124     * int xmax,
125     * int ymax
126     * )
127 greg 1.1 * {
128     * Paint a half-open rectangle from (xmin,ymin) to (xmax,ymax)
129 greg 1.6 * with the color col.
130 greg 1.1 * }
131 schorsch 2.9 *
132     *
133     * static dr_getcurf_t dname_getcur;
134     *
135     * dname_driver.getcur = dname_getcur;
136     *
137     * static int
138     * dname_getcur(
139     * int *xp,
140     * int *yp
141     * )
142 greg 1.1 * {
143     * Get the cursor position entered by the user via mouse,
144     * joystick, etc. Return the key hit by the user (usually
145     * MB1 or MB2). Return ABORT to cancel.
146     * Can be NULL for devices without this capability.
147     * }
148 schorsch 2.9 *
149     *
150     * static dr_comoutf_t dname_comout;
151     *
152     * dname_driver.comout = dname_comout;
153     *
154     * static void
155     * dname_comout(
156     * char *out
157     * )
158 greg 1.1 * {
159     * Print the string out on the device command line. If the
160     * string ends with '\n', the message is considered complete,
161     * and the next call can erase it.
162     * }
163 schorsch 2.9 *
164     *
165     * static dr_cominf_t dname_comin;
166     *
167     * dname_driver.comin = dname_comin;
168     *
169     * static void
170     * dname_comin(
171     * char *in,
172     * char *prompt
173     * )
174 greg 1.1 * {
175 greg 1.5 * Print a prompt then read an edited input command line
176     * assuming the in buffer is big enough. Unless prompt is NULL,
177     * the driver may substitute its own rview command. This is
178     * the most reliable way to repaint areas of the screen.
179 greg 1.7 * If the user enters an unrecognized control character,
180 greg 1.5 * terminate input and return the string with only that character.
181     * The input string should not contain a newline. The routines in
182     * editline.c may be useful. Comin must work in consort with comout.
183 greg 1.6 * }
184 schorsch 2.9 *
185     *
186     * static dr_flushf_t dname_flush;
187     *
188     * dname_driver.flush = dname_flush;
189     *
190     * static void
191     * dname_flush(void)
192 greg 1.6 * {
193     * Flush output to the display. This is guaranteed to be called
194     * frequently enough to keep the display up to date.
195     * This is an ideal time to check for device input.
196     * This function can be NULL for devices that don't need it.
197 greg 1.1 * }
198 schorsch 2.9 *
199     *
200     * dname_driver.xsiz
201     * dname_driver.ysiz
202     *
203 greg 1.1 * The maximum allowable x and y dimensions. If any
204     * size is allowable, these should be set to MAXRES.
205 schorsch 2.9 *
206     *
207     * dname_driver.inpready
208     *
209 greg 1.2 * This variable should be made positive asynchronously
210     * when characters are ready on the input. (Often easiest
211     * to check for input during calls to paintr.)
212 greg 1.1 */
213 greg 2.4
214     /* defined in editline.c */
215 schorsch 2.9 extern void editline(char *buf, dr_getchf_t *c_get, dr_comoutf_t *s_put);
216 greg 2.4 extern void tocombuf(char *b, struct driver *d);
217     extern int fromcombuf(char *b, struct driver *d);
218 schorsch 2.9
219 greg 2.4 /* defined in devcomm.c */
220 schorsch 2.9 extern dr_initf_t slave_init; /* XXX should probably be in a seperate file */
221 greg 2.4 extern struct driver *comm_init(char *dname, char *id);
222 schorsch 2.9
223 greg 2.4 /* defined in colortab.c */
224     extern int new_ctab(int ncolors);
225 schorsch 2.9 extern int get_pixel(COLOR col, dr_newcolrf_t *newcolr);
226 greg 2.4 extern void make_gmap(double gam);
227 greg 2.10 extern void set_cmap(uby8 *rmap, uby8 *gmap, uby8 *bmap);
228     extern void map_color(uby8 rgb[3], COLOR col);
229 greg 2.4
230 schorsch 2.6
231     #ifdef __cplusplus
232     }
233 greg 2.4 #endif
234 schorsch 2.6 #endif /* _RAD_DRIVER_H_ */
235
