--- ray/src/rt/driver.h 2003/06/07 00:54:58 2.6 +++ ray/src/rt/driver.h 2011/05/20 02:06:39 2.10 @@ -1,24 +1,36 @@ -/* RCSid $Id: driver.h,v 2.6 2003/06/07 00:54:58 schorsch Exp $ */ +/* RCSid $Id: driver.h,v 2.10 2011/05/20 02:06:39 greg Exp $ */ /* * driver.h - header file for interactive device drivers. */ #ifndef _RAD_DRIVER_H_ #define _RAD_DRIVER_H_ + +#include "color.h" + #ifdef __cplusplus extern "C" { #endif +typedef struct driver *dr_initf_t(char *dname, char *id); +typedef int dr_getchf_t(void); +typedef void dr_newcolrf_t(int ndx, int r, int g, int b); -#include "copyright.h" +typedef void dr_closef_t(void); +typedef void dr_clearf_t(int, int); +typedef void dr_paintrf_t(COLOR col, int xmin, int ymin, int xmax, int ymax); +typedef int dr_getcurf_t(int*,int*); +typedef void dr_comoutf_t(char*); +typedef void dr_cominf_t(char*,char*); +typedef void dr_flushf_t(void); struct driver { /* driver functions */ - void (*close)(); /* close device */ - void (*clear)(); /* clear device */ - void (*paintr)(); /* paint rectangle */ - int (*getcur)(); /* get cursor position */ - void (*comout)(); /* command line output */ - void (*comin)(); /* command line input */ - void (*flush)(); /* flush output */ + dr_closef_t *close; /* close device */ + dr_clearf_t *clear; /* clear device */ + dr_paintrf_t *paintr; /* paint rectangle */ + dr_getcurf_t *getcur; /* get cursor position */ + dr_comoutf_t *comout; /* command line output */ + dr_cominf_t *comin; /* command line input */ + dr_flushf_t *flush; /* flush output */ double pixaspect; /* pixel aspect ratio */ int xsiz, ysiz; /* device size */ int inpready; /* input ready on device */ @@ -38,8 +50,8 @@ struct driver { /* driver functions */ extern struct device { /* interactive device */ char *name; /* device name */ char *descrip; /* description */ - struct driver *(*init)(); /* initialize device */ -} devtable[]; /* supported devices */ + dr_initf_t *init; /* initialize device */ +} devtable[]; /* supported devices */ extern char dev_default[]; /* default device name */ @@ -49,52 +61,116 @@ extern char dev_default[]; /* default device name */ #define ABORT ('C'-'@') /* abort key */ /* - * struct driver * - * dname_init(name, id) - * char *name, *id; + * How to write an interactive display driver for rview. + * ---------------------------------------------------- + * + * static struct driver dname_driver; + * + * extern dr_initf_t dname_init; + * + * extern struct driver * + * dname_init( + * char *name, + * char *id + * ) * { * Initialize device and return pointer to driver - * functions. Returns NULL if an error occurred. + * dname_driver. Return NULL if an error occurred. * The name string identifies the driver, * and the id string identifies the client. * A device can be open by at most one client. * Be verbose in error reports; call eputs(). * If device has its own error output, set erract. + * This function then needs to be inserted into the + * device table in devtable.c. * } - * (*dev->close)() + * + * + * static dr_closef_t dname_close; + * + * dname_driver.close = dname_close; + * + * static void + * dname_close(void) * { * Close the device. Reset error vectors. * } - * (*dev->clear)(xres, yres) - * int xres, yres; + * + * + * static dr_clearf_t dname_clear; + * + * dname_driver.clear = dname_clear; + * + * static void + * dname_clear( + * int xres, + * int yres; + * ) * { * Clear the device for xres by yres output. This call will * be made prior to any output. * } - * (*dev->paintr)(col, xmin, ymin, xmax, ymax) - * COLOR col; - * int xmin, ymin, xmax, ymax; + * + * + * static dr_paintrf_t dname_paintr; + * + * dname_driver.paintr = dname_paintr; + * + * static void + * dname_paintr( + * COLOR col, + * int xmin, + * int ymin, + * int xmax, + * int ymax + * ) * { * Paint a half-open rectangle from (xmin,ymin) to (xmax,ymax) * with the color col. * } - * (*dev->getcur)(xp, yp) - * int *xp, *yp; + * + * + * static dr_getcurf_t dname_getcur; + * + * dname_driver.getcur = dname_getcur; + * + * static int + * dname_getcur( + * int *xp, + * int *yp + * ) * { * Get the cursor position entered by the user via mouse, * joystick, etc. Return the key hit by the user (usually * MB1 or MB2). Return ABORT to cancel. * Can be NULL for devices without this capability. * } - * (*dev->comout)(out) - * char *out; + * + * + * static dr_comoutf_t dname_comout; + * + * dname_driver.comout = dname_comout; + * + * static void + * dname_comout( + * char *out + * ) * { * Print the string out on the device command line. If the * string ends with '\n', the message is considered complete, * and the next call can erase it. * } - * (*dev->comin)(in, prompt) - * char *in, *prompt; + * + * + * static dr_cominf_t dname_comin; + * + * dname_driver.comin = dname_comin; + * + * static void + * dname_comin( + * char *in, + * char *prompt + * ) * { * Print a prompt then read an edited input command line * assuming the in buffer is big enough. Unless prompt is NULL, @@ -105,35 +181,51 @@ extern char dev_default[]; /* default device name */ * The input string should not contain a newline. The routines in * editline.c may be useful. Comin must work in consort with comout. * } - * (*dev->flush)() + * + * + * static dr_flushf_t dname_flush; + * + * dname_driver.flush = dname_flush; + * + * static void + * dname_flush(void) * { * Flush output to the display. This is guaranteed to be called * frequently enough to keep the display up to date. * This is an ideal time to check for device input. * This function can be NULL for devices that don't need it. * } - * xsiz, ysiz + * + * + * dname_driver.xsiz + * dname_driver.ysiz + * * The maximum allowable x and y dimensions. If any * size is allowable, these should be set to MAXRES. - * inpready + * + * + * dname_driver.inpready + * * This variable should be made positive asynchronously * when characters are ready on the input. (Often easiest * to check for input during calls to paintr.) */ /* defined in editline.c */ -extern void editline(char *buf, int (*c_get)(), void (*s_put)()); +extern void editline(char *buf, dr_getchf_t *c_get, dr_comoutf_t *s_put); extern void tocombuf(char *b, struct driver *d); extern int fromcombuf(char *b, struct driver *d); + /* defined in devcomm.c */ -extern struct driver *slave_init(char *dname, char *id); +extern dr_initf_t slave_init; /* XXX should probably be in a seperate file */ extern struct driver *comm_init(char *dname, char *id); + /* defined in colortab.c */ extern int new_ctab(int ncolors); -extern int get_pixel(COLOR col, void (*set_pixel)()); +extern int get_pixel(COLOR col, dr_newcolrf_t *newcolr); extern void make_gmap(double gam); -extern void set_cmap(BYTE *rmap, BYTE *gmap, BYTE *bmap); -extern void map_color(BYTE rgb[3], COLOR col); +extern void set_cmap(uby8 *rmap, uby8 *gmap, uby8 *bmap); +extern void map_color(uby8 rgb[3], COLOR col); #ifdef __cplusplus
