--- ray/src/rt/driver.h 1989/04/19 22:01:38 1.2 +++ ray/src/rt/driver.h 2003/06/07 00:54:58 2.6 @@ -1,63 +1,65 @@ -/* Copyright (c) 1987 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: driver.h,v 2.6 2003/06/07 00:54:58 schorsch Exp $ */ /* * driver.h - header file for interactive device drivers. - * - * 2/2/87 */ +#ifndef _RAD_DRIVER_H_ +#define _RAD_DRIVER_H_ +#ifdef __cplusplus +extern "C" { +#endif + +#include "copyright.h" + struct driver { /* driver functions */ - int (*close)(); /* close device */ - int (*clear)(); /* clear device */ - int (*paintr)(); /* paint rectangle */ + void (*close)(); /* close device */ + void (*clear)(); /* clear device */ + void (*paintr)(); /* paint rectangle */ int (*getcur)(); /* get cursor position */ - int (*comout)(); /* command line output */ - int (*comin)(); /* command line input */ + void (*comout)(); /* command line output */ + void (*comin)(); /* command line input */ + void (*flush)(); /* flush output */ + double pixaspect; /* pixel aspect ratio */ int xsiz, ysiz; /* device size */ int inpready; /* input ready on device */ }; - -extern int stderr_v(); /* error vectors */ -extern int (*wrnvec)(), (*errvec)(), (*cmdvec)(); - -extern struct driver *comm_init(); /* stream interface */ + /* magic numbers for verification */ +#define COM_SENDM 0x6f37 +#define COM_RECVM 0x51da /* stream commands */ #define COM_CLEAR 0 #define COM_PAINTR 1 #define COM_GETCUR 2 #define COM_COMOUT 3 #define COM_COMIN 4 -#define NREQUESTS 5 /* number of valid requests */ +#define COM_FLUSH 5 +#define NREQUESTS 6 /* number of valid requests */ -struct device { /* interactive device */ +extern struct device { /* interactive device */ char *name; /* device name */ char *descrip; /* description */ struct driver *(*init)(); /* initialize device */ -}; +} devtable[]; /* supported devices */ -extern struct device devtable[]; /* supported devices */ +extern char dev_default[]; /* default device name */ #define MB1 ('\n') /* mouse button 1 */ #define MB2 ('\r') /* mouse button 2 */ #define MB3 (' ') /* mouse button 3 */ #define ABORT ('C'-'@') /* abort key */ -#define MAXRES 4000 /* preposterous display resolution */ - /* * struct driver * - * dname_init(name) - * char *name; + * dname_init(name, id) + * char *name, *id; * { * Initialize device and return pointer to driver * functions. Returns NULL if an error occurred. - * The name string is used to identify the client. + * The name string identifies the driver, + * and the id string identifies the client. * A device can be open by at most one client. - * Be verbose in error reports; call stderr_v(). - * If device has its own error output, set errvec, - * cmdvec and wrnvec. + * Be verbose in error reports; call eputs(). + * If device has its own error output, set erract. * } * (*dev->close)() * { @@ -74,7 +76,7 @@ extern struct device devtable[]; /* supported devices * int xmin, ymin, xmax, ymax; * { * Paint a half-open rectangle from (xmin,ymin) to (xmax,ymax) - * with the color col. Can call repaint() if necessary. + * with the color col. * } * (*dev->getcur)(xp, yp) * int *xp, *yp; @@ -91,15 +93,25 @@ extern struct device devtable[]; /* supported devices * string ends with '\n', the message is considered complete, * and the next call can erase it. * } - * (*dev->comin)(in) - * char *in; + * (*dev->comin)(in, prompt) + * char *in, *prompt; * { - * Read an edited input string from the command line. If - * an unrecognized control character is entered, terminate - * input and return the string with only that character. - * The input string should not contain a newline. - * Must work in consort with comout. + * Print a prompt then read an edited input command line + * assuming the in buffer is big enough. Unless prompt is NULL, + * the driver may substitute its own rview command. This is + * the most reliable way to repaint areas of the screen. + * If the user enters an unrecognized control character, + * terminate input and return the string with only that character. + * The input string should not contain a newline. The routines in + * editline.c may be useful. Comin must work in consort with comout. * } + * (*dev->flush)() + * { + * Flush output to the display. This is guaranteed to be called + * frequently enough to keep the display up to date. + * This is an ideal time to check for device input. + * This function can be NULL for devices that don't need it. + * } * xsiz, ysiz * The maximum allowable x and y dimensions. If any * size is allowable, these should be set to MAXRES. @@ -108,3 +120,24 @@ extern struct device devtable[]; /* supported devices * when characters are ready on the input. (Often easiest * to check for input during calls to paintr.) */ + + /* defined in editline.c */ +extern void editline(char *buf, int (*c_get)(), void (*s_put)()); +extern void tocombuf(char *b, struct driver *d); +extern int fromcombuf(char *b, struct driver *d); + /* defined in devcomm.c */ +extern struct driver *slave_init(char *dname, char *id); +extern struct driver *comm_init(char *dname, char *id); + /* defined in colortab.c */ +extern int new_ctab(int ncolors); +extern int get_pixel(COLOR col, void (*set_pixel)()); +extern void make_gmap(double gam); +extern void set_cmap(BYTE *rmap, BYTE *gmap, BYTE *bmap); +extern void map_color(BYTE rgb[3], COLOR col); + + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_DRIVER_H_ */ +
