--- ray/src/rt/driver.h 1990/03/09 14:00:03 1.8 +++ ray/src/rt/driver.h 2003/02/25 02:47:22 2.5 @@ -1,30 +1,22 @@ -/* Copyright (c) 1987 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: driver.h,v 2.5 2003/02/25 02:47:22 greg Exp $ */ /* * driver.h - header file for interactive device drivers. - * - * 2/2/87 */ +#include "copyright.h" + struct driver { /* driver functions */ - int (*close)(); /* close device */ - int (*clear)(); /* clear device */ - int (*paintr)(); /* paint rectangle */ + void (*close)(); /* close device */ + void (*clear)(); /* clear device */ + void (*paintr)(); /* paint rectangle */ int (*getcur)(); /* get cursor position */ - int (*comout)(); /* command line output */ - int (*comin)(); /* command line input */ - int (*flush)(); /* flush output */ + void (*comout)(); /* command line output */ + void (*comin)(); /* command line input */ + void (*flush)(); /* flush output */ double pixaspect; /* pixel aspect ratio */ int xsiz, ysiz; /* device size */ int inpready; /* input ready on device */ }; - -extern int stderr_v(); /* error vectors */ -extern int (*wrnvec)(), (*errvec)(), (*cmdvec)(); - -extern struct driver *comm_init(); /* stream interface */ /* magic numbers for verification */ #define COM_SENDM 0x6f37 #define COM_RECVM 0x51da @@ -60,9 +52,8 @@ extern char dev_default[]; /* default device name */ * The name string identifies the driver, * and the id string identifies the client. * A device can be open by at most one client. - * Be verbose in error reports; call stderr_v(). - * If device has its own error output, set errvec, - * cmdvec and wrnvec. + * Be verbose in error reports; call eputs(). + * If device has its own error output, set erract. * } * (*dev->close)() * { @@ -123,3 +114,33 @@ extern char dev_default[]; /* default device name */ * when characters are ready on the input. (Often easiest * to check for input during calls to paintr.) */ + +#ifdef NOPROTO + +extern void editline(); +extern void tocombuf(); +extern int fromcombuf(); +extern struct driver *slave_init(); +extern struct driver *comm_init(); +extern int new_ctab(); +extern int get_pixel(); +extern void make_gmap(); +extern void set_cmap(); +extern void map_color(); + +#else + /* defined in editline.c */ +extern void editline(char *buf, int (*c_get)(), void (*s_put)()); +extern void tocombuf(char *b, struct driver *d); +extern int fromcombuf(char *b, struct driver *d); + /* defined in devcomm.c */ +extern struct driver *slave_init(char *dname, char *id); +extern struct driver *comm_init(char *dname, char *id); + /* defined in colortab.c */ +extern int new_ctab(int ncolors); +extern int get_pixel(COLOR col, void (*set_pixel)()); +extern void make_gmap(double gam); +extern void set_cmap(BYTE *rmap, BYTE *gmap, BYTE *bmap); +extern void map_color(BYTE rgb[3], COLOR col); + +#endif
