root/radiance/ray/src/rt/driver.h
Changes since 2.8: +124 -32 lines
Wed Aug 20 10:00:09 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.7: +9 -6 lines
Continued ansification (though aed.c depends on tty.c, which doesn't work on Linux).
Fri Jun 27 06:53:22 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.6: +1 -4 lines
Sat Jun 7 00:54:58 2003 UTC (21 years ago) by schorsch
Changes since 2.5: +12 -15 lines
Removed NOPROTO sections.
Changes since 2.4: +2 -57 lines
Sat Feb 22 02:07:28 2003 UTC (21 years, 4 months ago) by greg
Changes since 2.3: +93 -13 lines
Tue Nov 11 20:03:00 1997 UTC (26 years, 7 months ago) by gregl
Changes since 2.2: +2 -7 lines
Mon Apr 5 15:16:46 1993 UTC (31 years, 2 months ago) by greg
Changes since 2.1: +2 -1 lines
added slave_init() for slave mode of rview
Tue Nov 12 17:09:21 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.8 , to selected 2.3
Fri Mar 9 14:00:03 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.7: +2 -0 lines
Diff to previous 1.7 , to selected 2.3
moved naming of default device to devtable.c
Thu Mar 8 10:10:44 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.6 , to selected 2.3
minor comment change
Thu Feb 22 11:46:09 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.5: +11 -2 lines
Diff to previous 1.5 , to selected 2.3
Tue Jan 30 11:37:34 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.4: +10 -7 lines
Diff to previous 1.4 , to selected 2.3
Mon Jan 8 13:37:49 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.3: +3 -6 lines
Diff to previous 1.3 , to selected 2.3
Wed Oct 25 15:37:12 1989 UTC (34 years, 8 months ago) by greg
Changes since 1.2: +7 -3 lines
Diff to previous 1.2 , to selected 2.3
Wed Apr 19 22:01:38 1989 UTC (35 years, 2 months ago) by greg
Changes since 1.1: +8 -6 lines
Diff to previous 1.1 , to selected 2.3
changed comments section
Thu Feb 2 10:41:13 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.3
