1 |
/* Copyright (c) 1987 Regents of the University of California */ |
2 |
3 |
/* SCCSid "$SunId$ LBL" */ |
4 |
5 |
6 |
* driver.h - header file for interactive device drivers. |
7 |
8 |
* 2/2/87 |
9 |
10 |
11 |
struct driver { /* driver functions */ |
12 |
int (*close)(); /* close device */ |
13 |
int (*clear)(); /* clear device */ |
14 |
int (*paintr)(); /* paint rectangle */ |
15 |
int (*getcur)(); /* get cursor position */ |
16 |
int (*comout)(); /* command line output */ |
17 |
int (*comin)(); /* command line input */ |
18 |
int xsiz, ysiz; /* device size */ |
19 |
int inpready; /* input ready on device */ |
20 |
21 |
22 |
extern int stderr_v(); /* error vectors */ |
23 |
extern int (*wrnvec)(), (*errvec)(), (*cmdvec)(); |
24 |
25 |
extern struct driver *comm_init(); /* stream interface */ |
26 |
/* stream commands */ |
27 |
#define COM_CLEAR 0 |
28 |
#define COM_PAINTR 1 |
29 |
#define COM_GETCUR 2 |
30 |
#define COM_COMOUT 3 |
31 |
#define COM_COMIN 4 |
32 |
#define NREQUESTS 5 /* number of valid requests */ |
33 |
34 |
struct device { /* interactive device */ |
35 |
char *name; /* device name */ |
36 |
char *descrip; /* description */ |
37 |
struct driver *(*init)(); /* initialize device */ |
38 |
39 |
40 |
extern struct device devtable[]; /* supported devices */ |
41 |
42 |
#define MB1 ('\n') /* mouse button 1 */ |
43 |
#define MB2 ('\r') /* mouse button 2 */ |
44 |
#define MB3 (' ') /* mouse button 3 */ |
45 |
#define ABORT ('C'-'@') /* abort key */ |
46 |
47 |
#define MAXRES 4000 /* preposterous display resolution */ |
48 |
49 |
50 |
* struct driver * |
51 |
* dname_init(name) |
52 |
* char *name; |
53 |
54 |
* Initialize device and return pointer to driver |
55 |
* functions. Returns NULL if an error occurred. |
56 |
* The name string is used to identify the client. |
57 |
* A device can be open by at most one client. |
58 |
* Be verbose in error reports; call stderr_v(). |
59 |
* If device has its own error output, set errvec. |
60 |
61 |
* (*dev->close)() |
62 |
63 |
* Close the device. Reset errvec to stderr_v. |
64 |
65 |
* (*dev->clear)(xres, yres) |
66 |
* int xres, yres; |
67 |
68 |
* Clear the device for xres by yres output. This call must |
69 |
* be made prior to any output. |
70 |
71 |
* (*dev->paintr)(col, xmin, ymin, xmax, ymax) |
72 |
* COLOR col; |
73 |
* int xmin, ymin, xmax, ymax; |
74 |
75 |
* Paint a half-open rectangle from (xmin,ymin) to (xmax,ymax) |
76 |
* with the color col. Can call repaint() if necessary. |
77 |
78 |
* (*dev->getcur)(xp, yp) |
79 |
* int *xp, *yp; |
80 |
81 |
* Get the cursor position entered by the user via mouse, |
82 |
* joystick, etc. Return the key hit by the user (usually |
83 |
* MB1 or MB2). Return ABORT to cancel. |
84 |
* Can be NULL for devices without this capability. |
85 |
86 |
* (*dev->comout)(out) |
87 |
* char *out; |
88 |
89 |
* Print the string out on the device command line. If the |
90 |
* string ends with '\n', the message is considered complete, |
91 |
* and the next call can erase it. |
92 |
93 |
* (*dev->comin)(in) |
94 |
* char *in; |
95 |
96 |
* Read an edited input string from the command line. If |
97 |
* an unrecognized control character is entered, terminate |
98 |
* input and return the string with only that character. |
99 |
* The input string should not contain a newline ('\n'). |
100 |
* Must work in consort with comout. |
101 |
102 |
* xsiz, ysiz |
103 |
* The maximum allowable x and y dimensions. If any |
104 |
* size is allowable, these should be set to MAXRES. |
105 |
* inpready |
106 |
* This variable should be positive |
107 |
* when characters are ready on the input. |
108 |
