--- ray/src/rt/driver.h 1989/02/02 10:41:13 1.1 +++ ray/src/rt/driver.h 1990/01/08 13:37:49 1.4 @@ -15,6 +15,7 @@ struct driver { /* driver functions */ int (*getcur)(); /* get cursor position */ int (*comout)(); /* command line output */ int (*comin)(); /* command line input */ + double pixaspect; /* pixel aspect ratio */ int xsiz, ysiz; /* device size */ int inpready; /* input ready on device */ }; @@ -23,6 +24,9 @@ extern int stderr_v(); /* error vectors */ extern int (*wrnvec)(), (*errvec)(), (*cmdvec)(); extern struct driver *comm_init(); /* stream interface */ + /* magic numbers for verification */ +#define COM_SENDM 0x6f37 +#define COM_RECVM 0x51da /* stream commands */ #define COM_CLEAR 0 #define COM_PAINTR 1 @@ -31,41 +35,39 @@ extern struct driver *comm_init(); /* stream interfac #define COM_COMIN 4 #define NREQUESTS 5 /* number of valid requests */ -struct device { /* interactive device */ +extern struct device { /* interactive device */ char *name; /* device name */ char *descrip; /* description */ struct driver *(*init)(); /* initialize device */ -}; +} devtable[]; /* supported devices */ -extern struct device devtable[]; /* supported devices */ - #define MB1 ('\n') /* mouse button 1 */ #define MB2 ('\r') /* mouse button 2 */ #define MB3 (' ') /* mouse button 3 */ #define ABORT ('C'-'@') /* abort key */ -#define MAXRES 4000 /* preposterous display resolution */ - /* * struct driver * - * dname_init(name) - * char *name; + * dname_init(name, id) + * char *name, *id; * { * Initialize device and return pointer to driver * functions. Returns NULL if an error occurred. - * The name string is used to identify the client. + * The name string identifies the driver, + * and the id string identifies the client. * A device can be open by at most one client. * Be verbose in error reports; call stderr_v(). - * If device has its own error output, set errvec. + * If device has its own error output, set errvec, + * cmdvec and wrnvec. * } * (*dev->close)() * { - * Close the device. Reset errvec to stderr_v. + * Close the device. Reset error vectors. * } * (*dev->clear)(xres, yres) * int xres, yres; * { - * Clear the device for xres by yres output. This call must + * Clear the device for xres by yres output. This call will * be made prior to any output. * } * (*dev->paintr)(col, xmin, ymin, xmax, ymax) @@ -96,13 +98,14 @@ extern struct device devtable[]; /* supported devices * Read an edited input string from the command line. If * an unrecognized control character is entered, terminate * input and return the string with only that character. - * The input string should not contain a newline ('\n'). + * The input string should not contain a newline. * Must work in consort with comout. * } * xsiz, ysiz * The maximum allowable x and y dimensions. If any * size is allowable, these should be set to MAXRES. * inpready - * This variable should be positive - * when characters are ready on the input. + * This variable should be made positive asynchronously + * when characters are ready on the input. (Often easiest + * to check for input during calls to paintr.) */
