root/radiance/ray/src/rt/driver.h
Revision: 2.1
Committed: Tue Nov 12 17:09:21 1991 UTC (33 years, 6 months ago) by greg
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * driver.h - header file for interactive device drivers.
7 *
8 * 2/2/87
9 */
10
11 struct driver { /* driver functions */
12 int (*close)(); /* close device */
13 int (*clear)(); /* clear device */
14 int (*paintr)(); /* paint rectangle */
15 int (*getcur)(); /* get cursor position */
16 int (*comout)(); /* command line output */
17 int (*comin)(); /* command line input */
18 int (*flush)(); /* flush output */
19 double pixaspect; /* pixel aspect ratio */
20 int xsiz, ysiz; /* device size */
21 int inpready; /* input ready on device */
22 };
23
24 extern int stderr_v(); /* error vectors */
25 extern int (*wrnvec)(), (*errvec)(), (*cmdvec)();
26
27 extern struct driver *comm_init(); /* stream interface */
28 /* magic numbers for verification */
29 #define COM_SENDM 0x6f37
30 #define COM_RECVM 0x51da
31 /* stream commands */
32 #define COM_CLEAR 0
33 #define COM_PAINTR 1
34 #define COM_GETCUR 2
35 #define COM_COMOUT 3
36 #define COM_COMIN 4
37 #define COM_FLUSH 5
38 #define NREQUESTS 6 /* number of valid requests */
39
40 extern struct device { /* interactive device */
41 char *name; /* device name */
42 char *descrip; /* description */
43 struct driver *(*init)(); /* initialize device */
44 } devtable[]; /* supported devices */
45
46 extern char dev_default[]; /* default device name */
47
48 #define MB1 ('\n') /* mouse button 1 */
49 #define MB2 ('\r') /* mouse button 2 */
50 #define MB3 (' ') /* mouse button 3 */
51 #define ABORT ('C'-'@') /* abort key */
52
53 /*
54 * struct driver *
55 * dname_init(name, id)
56 * char *name, *id;
57 * {
58 * Initialize device and return pointer to driver
59 * functions. Returns NULL if an error occurred.
60 * The name string identifies the driver,
61 * and the id string identifies the client.
62 * A device can be open by at most one client.
63 * Be verbose in error reports; call stderr_v().
64 * If device has its own error output, set errvec,
65 * cmdvec and wrnvec.
66 * }
67 * (*dev->close)()
68 * {
69 * Close the device. Reset error vectors.
70 * }
71 * (*dev->clear)(xres, yres)
72 * int xres, yres;
73 * {
74 * Clear the device for xres by yres output. This call will
75 * be made prior to any output.
76 * }
77 * (*dev->paintr)(col, xmin, ymin, xmax, ymax)
78 * COLOR col;
79 * int xmin, ymin, xmax, ymax;
80 * {
81 * Paint a half-open rectangle from (xmin,ymin) to (xmax,ymax)
82 * with the color col.
83 * }
84 * (*dev->getcur)(xp, yp)
85 * int *xp, *yp;
86 * {
87 * Get the cursor position entered by the user via mouse,
88 * joystick, etc. Return the key hit by the user (usually
89 * MB1 or MB2). Return ABORT to cancel.
90 * Can be NULL for devices without this capability.
91 * }
92 * (*dev->comout)(out)
93 * char *out;
94 * {
95 * Print the string out on the device command line. If the
96 * string ends with '\n', the message is considered complete,
97 * and the next call can erase it.
98 * }
99 * (*dev->comin)(in, prompt)
100 * char *in, *prompt;
101 * {
102 * Print a prompt then read an edited input command line
103 * assuming the in buffer is big enough. Unless prompt is NULL,
104 * the driver may substitute its own rview command. This is
105 * the most reliable way to repaint areas of the screen.
106 * If the user enters an unrecognized control character,
107 * terminate input and return the string with only that character.
108 * The input string should not contain a newline. The routines in
109 * editline.c may be useful. Comin must work in consort with comout.
110 * }
111 * (*dev->flush)()
112 * {
113 * Flush output to the display. This is guaranteed to be called
114 * frequently enough to keep the display up to date.
115 * This is an ideal time to check for device input.
116 * This function can be NULL for devices that don't need it.
117 * }
118 * xsiz, ysiz
119 * The maximum allowable x and y dimensions. If any
120 * size is allowable, these should be set to MAXRES.
121 * inpready
122 * This variable should be made positive asynchronously
123 * when characters are ready on the input. (Often easiest
124 * to check for input during calls to paintr.)
125 */
