root/radiance/ray/src/rt/driver.h
Revision: 1.6
Committed: Thu Feb 22 11:46:09 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.5: +11 -2 lines
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * driver.h - header file for interactive device drivers.
7 *
8 * 2/2/87
9 */
10
11 struct driver { /* driver functions */
12 int (*close)(); /* close device */
13 int (*clear)(); /* clear device */
14 int (*paintr)(); /* paint rectangle */
15 int (*getcur)(); /* get cursor position */
16 int (*comout)(); /* command line output */
17 int (*comin)(); /* command line input */
18 int (*flush)(); /* flush output */
19 double pixaspect; /* pixel aspect ratio */
20 int xsiz, ysiz; /* device size */
21 int inpready; /* input ready on device */
22 };
23
24 extern int stderr_v(); /* error vectors */
25 extern int (*wrnvec)(), (*errvec)(), (*cmdvec)();
26
27 extern struct driver *comm_init(); /* stream interface */
28 /* magic numbers for verification */
29 #define COM_SENDM 0x6f37
30 #define COM_RECVM 0x51da
31 /* stream commands */
32 #define COM_CLEAR 0
33 #define COM_PAINTR 1
34 #define COM_GETCUR 2
35 #define COM_COMOUT 3
36 #define COM_COMIN 4
37 #define COM_FLUSH 5
38 #define NREQUESTS 6 /* number of valid requests */
39
40 extern struct device { /* interactive device */
41 char *name; /* device name */
42 char *descrip; /* description */
43 struct driver *(*init)(); /* initialize device */
44 } devtable[]; /* supported devices */
45
46 #define MB1 ('\n') /* mouse button 1 */
47 #define MB2 ('\r') /* mouse button 2 */
48 #define MB3 (' ') /* mouse button 3 */
49 #define ABORT ('C'-'@') /* abort key */
50
51 /*
52 * struct driver *
53 * dname_init(name, id)
54 * char *name, *id;
55 * {
56 * Initialize device and return pointer to driver
57 * functions. Returns NULL if an error occurred.
58 * The name string identifies the driver,
59 * and the id string identifies the client.
60 * A device can be open by at most one client.
61 * Be verbose in error reports; call stderr_v().
62 * If device has its own error output, set errvec,
63 * cmdvec and wrnvec.
64 * }
65 * (*dev->close)()
66 * {
67 * Close the device. Reset error vectors.
68 * }
69 * (*dev->clear)(xres, yres)
70 * int xres, yres;
71 * {
72 * Clear the device for xres by yres output. This call will
73 * be made prior to any output.
74 * }
75 * (*dev->paintr)(col, xmin, ymin, xmax, ymax)
76 * COLOR col;
77 * int xmin, ymin, xmax, ymax;
78 * {
79 * Paint a half-open rectangle from (xmin,ymin) to (xmax,ymax)
80 * with the color col.
81 * }
82 * (*dev->getcur)(xp, yp)
83 * int *xp, *yp;
84 * {
85 * Get the cursor position entered by the user via mouse,
86 * joystick, etc. Return the key hit by the user (usually
87 * MB1 or MB2). Return ABORT to cancel.
88 * Can be NULL for devices without this capability.
89 * }
90 * (*dev->comout)(out)
91 * char *out;
92 * {
93 * Print the string out on the device command line. If the
94 * string ends with '\n', the message is considered complete,
95 * and the next call can erase it.
96 * }
97 * (*dev->comin)(in, prompt)
98 * char *in, *prompt;
99 * {
100 * Print a prompt then read an edited input command line
101 * assuming the in buffer is big enough. Unless prompt is NULL,
102 * the driver may substitute its own rview command. This is
103 * the most reliable way to repaint areas of the screen.
104 * If the user enters an unrecognized control character is entered,
105 * terminate input and return the string with only that character.
106 * The input string should not contain a newline. The routines in
107 * editline.c may be useful. Comin must work in consort with comout.
108 * }
109 * (*dev->flush)()
110 * {
111 * Flush output to the display. This is guaranteed to be called
112 * frequently enough to keep the display up to date.
113 * This is an ideal time to check for device input.
114 * This function can be NULL for devices that don't need it.
115 * }
116 * xsiz, ysiz
117 * The maximum allowable x and y dimensions. If any
118 * size is allowable, these should be set to MAXRES.
119 * inpready
120 * This variable should be made positive asynchronously
121 * when characters are ready on the input. (Often easiest
122 * to check for input during calls to paintr.)
123 */
