--- ray/src/rt/driver.h 1989/02/02 10:41:13 1.1 +++ ray/src/rt/driver.h 1990/02/22 11:46:09 1.6 @@ -15,6 +15,8 @@ struct driver { /* driver functions */ int (*getcur)(); /* get cursor position */ int (*comout)(); /* command line output */ int (*comin)(); /* command line input */ + int (*flush)(); /* flush output */ + double pixaspect; /* pixel aspect ratio */ int xsiz, ysiz; /* device size */ int inpready; /* input ready on device */ }; @@ -23,49 +25,51 @@ extern int stderr_v(); /* error vectors */ extern int (*wrnvec)(), (*errvec)(), (*cmdvec)(); extern struct driver *comm_init(); /* stream interface */ + /* magic numbers for verification */ +#define COM_SENDM 0x6f37 +#define COM_RECVM 0x51da /* stream commands */ #define COM_CLEAR 0 #define COM_PAINTR 1 #define COM_GETCUR 2 #define COM_COMOUT 3 #define COM_COMIN 4 -#define NREQUESTS 5 /* number of valid requests */ +#define COM_FLUSH 5 +#define NREQUESTS 6 /* number of valid requests */ -struct device { /* interactive device */ +extern struct device { /* interactive device */ char *name; /* device name */ char *descrip; /* description */ struct driver *(*init)(); /* initialize device */ -}; +} devtable[]; /* supported devices */ -extern struct device devtable[]; /* supported devices */ - #define MB1 ('\n') /* mouse button 1 */ #define MB2 ('\r') /* mouse button 2 */ #define MB3 (' ') /* mouse button 3 */ #define ABORT ('C'-'@') /* abort key */ -#define MAXRES 4000 /* preposterous display resolution */ - /* * struct driver * - * dname_init(name) - * char *name; + * dname_init(name, id) + * char *name, *id; * { * Initialize device and return pointer to driver * functions. Returns NULL if an error occurred. - * The name string is used to identify the client. + * The name string identifies the driver, + * and the id string identifies the client. * A device can be open by at most one client. * Be verbose in error reports; call stderr_v(). - * If device has its own error output, set errvec. + * If device has its own error output, set errvec, + * cmdvec and wrnvec. * } * (*dev->close)() * { - * Close the device. Reset errvec to stderr_v. + * Close the device. Reset error vectors. * } * (*dev->clear)(xres, yres) * int xres, yres; * { - * Clear the device for xres by yres output. This call must + * Clear the device for xres by yres output. This call will * be made prior to any output. * } * (*dev->paintr)(col, xmin, ymin, xmax, ymax) @@ -73,7 +77,7 @@ extern struct device devtable[]; /* supported devices * int xmin, ymin, xmax, ymax; * { * Paint a half-open rectangle from (xmin,ymin) to (xmax,ymax) - * with the color col. Can call repaint() if necessary. + * with the color col. * } * (*dev->getcur)(xp, yp) * int *xp, *yp; @@ -90,19 +94,30 @@ extern struct device devtable[]; /* supported devices * string ends with '\n', the message is considered complete, * and the next call can erase it. * } - * (*dev->comin)(in) - * char *in; + * (*dev->comin)(in, prompt) + * char *in, *prompt; * { - * Read an edited input string from the command line. If - * an unrecognized control character is entered, terminate - * input and return the string with only that character. - * The input string should not contain a newline ('\n'). - * Must work in consort with comout. + * Print a prompt then read an edited input command line + * assuming the in buffer is big enough. Unless prompt is NULL, + * the driver may substitute its own rview command. This is + * the most reliable way to repaint areas of the screen. + * If the user enters an unrecognized control character is entered, + * terminate input and return the string with only that character. + * The input string should not contain a newline. The routines in + * editline.c may be useful. Comin must work in consort with comout. * } + * (*dev->flush)() + * { + * Flush output to the display. This is guaranteed to be called + * frequently enough to keep the display up to date. + * This is an ideal time to check for device input. + * This function can be NULL for devices that don't need it. + * } * xsiz, ysiz * The maximum allowable x and y dimensions. If any * size is allowable, these should be set to MAXRES. * inpready - * This variable should be positive - * when characters are ready on the input. + * This variable should be made positive asynchronously + * when characters are ready on the input. (Often easiest + * to check for input during calls to paintr.) */
