--- ray/src/rt/driver.h 1990/01/08 13:37:49 1.4 +++ ray/src/rt/driver.h 1991/11/12 17:09:21 2.1 @@ -15,6 +15,7 @@ struct driver { /* driver functions */ int (*getcur)(); /* get cursor position */ int (*comout)(); /* command line output */ int (*comin)(); /* command line input */ + int (*flush)(); /* flush output */ double pixaspect; /* pixel aspect ratio */ int xsiz, ysiz; /* device size */ int inpready; /* input ready on device */ @@ -33,7 +34,8 @@ extern struct driver *comm_init(); /* stream interfac #define COM_GETCUR 2 #define COM_COMOUT 3 #define COM_COMIN 4 -#define NREQUESTS 5 /* number of valid requests */ +#define COM_FLUSH 5 +#define NREQUESTS 6 /* number of valid requests */ extern struct device { /* interactive device */ char *name; /* device name */ @@ -41,6 +43,8 @@ extern struct device { /* interactive device */ struct driver *(*init)(); /* initialize device */ } devtable[]; /* supported devices */ +extern char dev_default[]; /* default device name */ + #define MB1 ('\n') /* mouse button 1 */ #define MB2 ('\r') /* mouse button 2 */ #define MB3 (' ') /* mouse button 3 */ @@ -75,7 +79,7 @@ extern struct device { /* interactive device */ * int xmin, ymin, xmax, ymax; * { * Paint a half-open rectangle from (xmin,ymin) to (xmax,ymax) - * with the color col. Can call repaint() if necessary. + * with the color col. * } * (*dev->getcur)(xp, yp) * int *xp, *yp; @@ -92,14 +96,24 @@ extern struct device { /* interactive device */ * string ends with '\n', the message is considered complete, * and the next call can erase it. * } - * (*dev->comin)(in) - * char *in; + * (*dev->comin)(in, prompt) + * char *in, *prompt; * { - * Read an edited input string from the command line. If - * an unrecognized control character is entered, terminate - * input and return the string with only that character. - * The input string should not contain a newline. - * Must work in consort with comout. + * Print a prompt then read an edited input command line + * assuming the in buffer is big enough. Unless prompt is NULL, + * the driver may substitute its own rview command. This is + * the most reliable way to repaint areas of the screen. + * If the user enters an unrecognized control character, + * terminate input and return the string with only that character. + * The input string should not contain a newline. The routines in + * editline.c may be useful. Comin must work in consort with comout. + * } + * (*dev->flush)() + * { + * Flush output to the display. This is guaranteed to be called + * frequently enough to keep the display up to date. + * This is an ideal time to check for device input. + * This function can be NULL for devices that don't need it. * } * xsiz, ysiz * The maximum allowable x and y dimensions. If any
