--- ray/src/rt/driver.h 1990/02/22 11:46:09 1.6 +++ ray/src/rt/driver.h 2003/08/20 10:00:09 2.8 @@ -1,30 +1,28 @@ -/* Copyright (c) 1987 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: driver.h,v 2.8 2003/08/20 10:00:09 schorsch Exp $ */ /* * driver.h - header file for interactive device drivers. - * - * 2/2/87 */ +#ifndef _RAD_DRIVER_H_ +#define _RAD_DRIVER_H_ +#include "color.h" + +#ifdef __cplusplus +extern "C" { +#endif + struct driver { /* driver functions */ - int (*close)(); /* close device */ - int (*clear)(); /* clear device */ - int (*paintr)(); /* paint rectangle */ - int (*getcur)(); /* get cursor position */ - int (*comout)(); /* command line output */ - int (*comin)(); /* command line input */ - int (*flush)(); /* flush output */ + void (*close)(void); /* close device */ + void (*clear)(int, int); /* clear device */ + void (*paintr)(COLOR col, int xmin, int ymin, int xmax, int ymax); /* paint rectangle */ + int (*getcur)(int*,int*); /* get cursor position */ + void (*comout)(char*); /* command line output */ + void (*comin)(); /* command line input */ + void (*flush)(); /* flush output */ double pixaspect; /* pixel aspect ratio */ int xsiz, ysiz; /* device size */ int inpready; /* input ready on device */ }; - -extern int stderr_v(); /* error vectors */ -extern int (*wrnvec)(), (*errvec)(), (*cmdvec)(); - -extern struct driver *comm_init(); /* stream interface */ /* magic numbers for verification */ #define COM_SENDM 0x6f37 #define COM_RECVM 0x51da @@ -43,6 +41,8 @@ extern struct device { /* interactive device */ struct driver *(*init)(); /* initialize device */ } devtable[]; /* supported devices */ +extern char dev_default[]; /* default device name */ + #define MB1 ('\n') /* mouse button 1 */ #define MB2 ('\r') /* mouse button 2 */ #define MB3 (' ') /* mouse button 3 */ @@ -58,9 +58,8 @@ extern struct device { /* interactive device */ * The name string identifies the driver, * and the id string identifies the client. * A device can be open by at most one client. - * Be verbose in error reports; call stderr_v(). - * If device has its own error output, set errvec, - * cmdvec and wrnvec. + * Be verbose in error reports; call eputs(). + * If device has its own error output, set erract. * } * (*dev->close)() * { @@ -101,7 +100,7 @@ extern struct device { /* interactive device */ * assuming the in buffer is big enough. Unless prompt is NULL, * the driver may substitute its own rview command. This is * the most reliable way to repaint areas of the screen. - * If the user enters an unrecognized control character is entered, + * If the user enters an unrecognized control character, * terminate input and return the string with only that character. * The input string should not contain a newline. The routines in * editline.c may be useful. Comin must work in consort with comout. @@ -121,3 +120,24 @@ extern struct device { /* interactive device */ * when characters are ready on the input. (Often easiest * to check for input during calls to paintr.) */ + + /* defined in editline.c */ +extern void editline(char *buf, int (*c_get)(), void (*s_put)()); +extern void tocombuf(char *b, struct driver *d); +extern int fromcombuf(char *b, struct driver *d); + /* defined in devcomm.c */ +extern struct driver *slave_init(char *dname, char *id); +extern struct driver *comm_init(char *dname, char *id); + /* defined in colortab.c */ +extern int new_ctab(int ncolors); +extern int get_pixel(COLOR col, void (*set_pixel)()); +extern void make_gmap(double gam); +extern void set_cmap(BYTE *rmap, BYTE *gmap, BYTE *bmap); +extern void map_color(BYTE rgb[3], COLOR col); + + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_DRIVER_H_ */ +
