1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* dielectric.c - shading function for transparent materials. |
6 |
7 |
8 |
9 |
* The Radiance Software License, Version 1.0 |
10 |
11 |
* Copyright (c) 1990 - 2002 The Regents of the University of California, |
12 |
* through Lawrence Berkeley National Laboratory. All rights reserved. |
13 |
14 |
* Redistribution and use in source and binary forms, with or without |
15 |
* modification, are permitted provided that the following conditions |
16 |
* are met: |
17 |
18 |
* 1. Redistributions of source code must retain the above copyright |
19 |
* notice, this list of conditions and the following disclaimer. |
20 |
21 |
* 2. Redistributions in binary form must reproduce the above copyright |
22 |
* notice, this list of conditions and the following disclaimer in |
23 |
* the documentation and/or other materials provided with the |
24 |
* distribution. |
25 |
26 |
* 3. The end-user documentation included with the redistribution, |
27 |
* if any, must include the following acknowledgment: |
28 |
* "This product includes Radiance software |
29 |
* (http://radsite.lbl.gov/) |
30 |
* developed by the Lawrence Berkeley National Laboratory |
31 |
* (http://www.lbl.gov/)." |
32 |
* Alternately, this acknowledgment may appear in the software itself, |
33 |
* if and wherever such third-party acknowledgments normally appear. |
34 |
35 |
* 4. The names "Radiance," "Lawrence Berkeley National Laboratory" |
36 |
* and "The Regents of the University of California" must |
37 |
* not be used to endorse or promote products derived from this |
38 |
* software without prior written permission. For written |
39 |
* permission, please contact [email protected]. |
40 |
41 |
* 5. Products derived from this software may not be called "Radiance", |
42 |
* nor may "Radiance" appear in their name, without prior written |
43 |
* permission of Lawrence Berkeley National Laboratory. |
44 |
45 |
* THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED |
46 |
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES |
47 |
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE |
48 |
* DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR |
49 |
* ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, |
50 |
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT |
51 |
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF |
52 |
* USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND |
53 |
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, |
54 |
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT |
55 |
* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF |
56 |
* SUCH DAMAGE. |
57 |
58 |
59 |
* This software consists of voluntary contributions made by many |
60 |
* individuals on behalf of Lawrence Berkeley National Laboratory. For more |
61 |
* information on Lawrence Berkeley National Laboratory, please see |
62 |
* <http://www.lbl.gov/>. |
63 |
64 |
65 |
#include "ray.h" |
66 |
67 |
#include "otypes.h" |
68 |
69 |
#ifdef DISPERSE |
70 |
#include "source.h" |
71 |
static disperse(); |
72 |
static int lambda(); |
73 |
#endif |
74 |
75 |
76 |
* Explicit calculations for Fresnel's equation are performed, |
77 |
* but only one square root computation is necessary. |
78 |
* The index of refraction is given as a Hartmann equation |
79 |
* with lambda0 equal to zero. If the slope of Hartmann's |
80 |
* equation is non-zero, the material disperses light upon |
81 |
* refraction. This condition is examined on rays traced to |
82 |
* light sources. If a ray is exiting a dielectric material, we |
83 |
* check the sources to see if any would cause bright color to be |
84 |
* directed to the viewer due to dispersion. This gives colorful |
85 |
* sparkle to crystals, etc. (Only if DISPERSE is defined!) |
86 |
87 |
* Arguments for MAT_DIELECTRIC are: |
88 |
* red grn blu rndx Hartmann |
89 |
90 |
* Arguments for MAT_INTERFACE are: |
91 |
* red1 grn1 blu1 rndx1 red2 grn2 blu2 rndx2 |
92 |
93 |
* The primaries are material transmission per unit length. |
94 |
* MAT_INTERFACE uses dielectric1 for inside and dielectric2 for |
95 |
* outside. |
96 |
97 |
98 |
99 |
#define MLAMBDA 500 /* mean lambda */ |
100 |
#define MAXLAMBDA 779 /* maximum lambda */ |
101 |
#define MINLAMBDA 380 /* minimum lambda */ |
102 |
103 |
#define MINCOS 0.997 /* minimum dot product for dispersion */ |
104 |
105 |
106 |
static double |
107 |
mylog(x) /* special log for extinction coefficients */ |
108 |
double x; |
109 |
110 |
if (x < 1e-40) |
111 |
return(-100.); |
112 |
if (x >= 1.) |
113 |
return(0.); |
114 |
return(log(x)); |
115 |
116 |
117 |
118 |
m_dielectric(m, r) /* color a ray which hit a dielectric interface */ |
119 |
OBJREC *m; |
120 |
register RAY *r; |
121 |
122 |
double cos1, cos2, nratio; |
123 |
COLOR ctrans; |
124 |
COLOR talb; |
125 |
int hastexture; |
126 |
double refl, trans; |
127 |
FVECT dnorm; |
128 |
double d1, d2; |
129 |
RAY p; |
130 |
register int i; |
131 |
132 |
if (m->oargs.nfargs != (m->otype==MAT_DIELECTRIC ? 5 : 8)) |
133 |
objerror(m, USER, "bad arguments"); |
134 |
135 |
raytexture(r, m->omod); /* get modifiers */ |
136 |
137 |
if (hastexture = DOT(r->pert,r->pert) > FTINY*FTINY) |
138 |
cos1 = raynormal(dnorm, r); /* perturb normal */ |
139 |
else { |
140 |
VCOPY(dnorm, r->ron); |
141 |
cos1 = r->rod; |
142 |
143 |
/* index of refraction */ |
144 |
if (m->otype == MAT_DIELECTRIC) |
145 |
nratio = m->oargs.farg[3] + m->oargs.farg[4]/MLAMBDA; |
146 |
else |
147 |
nratio = m->oargs.farg[3] / m->oargs.farg[7]; |
148 |
149 |
if (cos1 < 0.0) { /* inside */ |
150 |
hastexture = -hastexture; |
151 |
cos1 = -cos1; |
152 |
dnorm[0] = -dnorm[0]; |
153 |
dnorm[1] = -dnorm[1]; |
154 |
dnorm[2] = -dnorm[2]; |
155 |
setcolor(r->cext, -mylog(m->oargs.farg[0]*colval(r->pcol,RED)), |
156 |
-mylog(m->oargs.farg[1]*colval(r->pcol,GRN)), |
157 |
-mylog(m->oargs.farg[2]*colval(r->pcol,BLU))); |
158 |
setcolor(r->albedo, 0., 0., 0.); |
159 |
r->gecc = 0.; |
160 |
if (m->otype == MAT_INTERFACE) { |
161 |
setcolor(ctrans, |
162 |
-mylog(m->oargs.farg[4]*colval(r->pcol,RED)), |
163 |
-mylog(m->oargs.farg[5]*colval(r->pcol,GRN)), |
164 |
-mylog(m->oargs.farg[6]*colval(r->pcol,BLU))); |
165 |
setcolor(talb, 0., 0., 0.); |
166 |
} else { |
167 |
copycolor(ctrans, cextinction); |
168 |
copycolor(talb, salbedo); |
169 |
170 |
} else { /* outside */ |
171 |
nratio = 1.0 / nratio; |
172 |
173 |
setcolor(ctrans, -mylog(m->oargs.farg[0]*colval(r->pcol,RED)), |
174 |
175 |
176 |
177 |
178 |
setcolor(r->cext, |
179 |
180 |
181 |
182 |
183 |
r->gecc = 0.; |
184 |
185 |
186 |
187 |
d2 = 1.0 - nratio*nratio*(1.0 - cos1*cos1); /* compute cos theta2 */ |
188 |
189 |
if (d2 < FTINY) /* total reflection */ |
190 |
191 |
refl = 1.0; |
192 |
193 |
else { /* refraction occurs */ |
194 |
/* compute Fresnel's equations */ |
195 |
cos2 = sqrt(d2); |
196 |
d1 = cos1; |
197 |
d2 = nratio*cos2; |
198 |
d1 = (d1 - d2) / (d1 + d2); |
199 |
refl = d1 * d1; |
200 |
201 |
d1 = 1.0 / cos1; |
202 |
d2 = nratio / cos2; |
203 |
204 |
refl += d1 * d1; |
205 |
206 |
refl *= 0.5; |
207 |
trans = 1.0 - refl; |
208 |
209 |
trans *= nratio*nratio; /* solid angle ratio */ |
210 |
211 |
if (rayorigin(&p, r, REFRACTED, trans) == 0) { |
212 |
213 |
/* compute refracted ray */ |
214 |
d1 = nratio*cos1 - cos2; |
215 |
for (i = 0; i < 3; i++) |
216 |
p.rdir[i] = nratio*r->rdir[i] + d1*dnorm[i]; |
217 |
/* accidental reflection? */ |
218 |
if (hastexture && |
219 |
DOT(p.rdir,r->ron)*hastexture >= -FTINY) { |
220 |
d1 *= (double)hastexture; |
221 |
for (i = 0; i < 3; i++) /* ignore texture */ |
222 |
p.rdir[i] = nratio*r->rdir[i] + |
223 |
d1*r->ron[i]; |
224 |
normalize(p.rdir); /* not exact */ |
225 |
226 |
#ifdef DISPERSE |
227 |
if (m->otype != MAT_DIELECTRIC |
228 |
|| r->rod > 0.0 |
229 |
|| r->crtype & SHADOW |
230 |
|| !directvis |
231 |
|| m->oargs.farg[4] == 0.0 |
232 |
|| !disperse(m, r, p.rdir, |
233 |
trans, ctrans, talb)) |
234 |
#endif |
235 |
236 |
copycolor(p.cext, ctrans); |
237 |
copycolor(p.albedo, talb); |
238 |
rayvalue(&p); |
239 |
scalecolor(p.rcol, trans); |
240 |
addcolor(r->rcol, p.rcol); |
241 |
if (nratio >= 1.0-FTINY && nratio <= 1.0+FTINY) |
242 |
r->rt = r->rot + p.rt; |
243 |
244 |
245 |
246 |
247 |
if (!(r->crtype & SHADOW) && |
248 |
rayorigin(&p, r, REFLECTED, refl) == 0) { |
249 |
250 |
/* compute reflected ray */ |
251 |
252 |
p.rdir[i] = r->rdir[i] + 2.0*cos1*dnorm[i]; |
253 |
/* accidental penetration? */ |
254 |
if (hastexture && DOT(p.rdir,r->ron)*hastexture <= FTINY) |
255 |
256 |
p.rdir[i] = r->rdir[i] + 2.0*r->rod*r->ron[i]; |
257 |
258 |
rayvalue(&p); /* reflected ray value */ |
259 |
260 |
scalecolor(p.rcol, refl); /* color contribution */ |
261 |
262 |
263 |
/* rayvalue() computes absorption */ |
264 |
return(1); |
265 |
266 |
267 |
268 |
#ifdef DISPERSE |
269 |
270 |
static |
271 |
disperse(m, r, vt, tr, cet, abt) /* check light sources for dispersion */ |
272 |
OBJREC *m; |
273 |
RAY *r; |
274 |
FVECT vt; |
275 |
double tr; |
276 |
COLOR cet, abt; |
277 |
278 |
RAY sray, *entray; |
279 |
FVECT v1, v2, n1, n2; |
280 |
FVECT dv, v2Xdv; |
281 |
double v2Xdvv2Xdv; |
282 |
int success = 0; |
283 |
SRCINDEX si; |
284 |
FVECT vtmp1, vtmp2; |
285 |
double dtmp1, dtmp2; |
286 |
int l1, l2; |
287 |
COLOR ctmp; |
288 |
int i; |
289 |
290 |
291 |
* This routine computes dispersion to the first order using |
292 |
* the following assumptions: |
293 |
294 |
* 1) The dependency of the index of refraction on wavelength |
295 |
* is approximated by Hartmann's equation with lambda0 |
296 |
* equal to zero. |
297 |
* 2) The entry and exit locations are constant with respect |
298 |
* to dispersion. |
299 |
300 |
* The second assumption permits us to model dispersion without |
301 |
* having to sample refracted directions. We assume that the |
302 |
* geometry inside the material is constant, and concern ourselves |
303 |
* only with the relationship between the entering and exiting ray. |
304 |
* We compute the first derivatives of the entering and exiting |
305 |
* refraction with respect to the index of refraction. This |
306 |
* is then used in a first order Taylor series to determine the |
307 |
* index of refraction necessary to send the exiting ray to each |
308 |
* light source. |
309 |
* If an exiting ray hits a light source within the refraction |
310 |
* boundaries, we sum all the frequencies over the disc of the |
311 |
* light source to determine the resulting color. A smaller light |
312 |
* source will therefore exhibit a sharper spectrum. |
313 |
314 |
315 |
if (!(r->crtype & REFRACTED)) { /* ray started in material */ |
316 |
VCOPY(v1, r->rdir); |
317 |
n1[0] = -r->rdir[0]; n1[1] = -r->rdir[1]; n1[2] = -r->rdir[2]; |
318 |
} else { |
319 |
/* find entry point */ |
320 |
for (entray = r; entray->rtype != REFRACTED; |
321 |
entray = entray->parent) |
322 |
323 |
entray = entray->parent; |
324 |
if (entray->crtype & REFRACTED) /* too difficult */ |
325 |
return(0); |
326 |
VCOPY(v1, entray->rdir); |
327 |
VCOPY(n1, entray->ron); |
328 |
329 |
VCOPY(v2, vt); /* exiting ray */ |
330 |
VCOPY(n2, r->ron); |
331 |
332 |
/* first order dispersion approx. */ |
333 |
dtmp1 = DOT(n1, v1); |
334 |
dtmp2 = DOT(n2, v2); |
335 |
336 |
dv[i] = v1[i] + v2[i] - n1[i]/dtmp1 - n2[i]/dtmp2; |
337 |
338 |
if (DOT(dv, dv) <= FTINY) /* null effect */ |
339 |
return(0); |
340 |
/* compute plane normal */ |
341 |
fcross(v2Xdv, v2, dv); |
342 |
v2Xdvv2Xdv = DOT(v2Xdv, v2Xdv); |
343 |
344 |
/* check sources */ |
345 |
initsrcindex(&si); |
346 |
while (srcray(&sray, r, &si)) { |
347 |
348 |
if (DOT(sray.rdir, v2) < MINCOS) |
349 |
continue; /* bad source */ |
350 |
/* adjust source ray */ |
351 |
352 |
dtmp1 = DOT(v2Xdv, sray.rdir) / v2Xdvv2Xdv; |
353 |
sray.rdir[0] -= dtmp1 * v2Xdv[0]; |
354 |
sray.rdir[1] -= dtmp1 * v2Xdv[1]; |
355 |
sray.rdir[2] -= dtmp1 * v2Xdv[2]; |
356 |
357 |
l1 = lambda(m, v2, dv, sray.rdir); /* mean lambda */ |
358 |
359 |
if (l1 > MAXLAMBDA || l1 < MINLAMBDA) /* not visible */ |
360 |
continue; |
361 |
/* trace source ray */ |
362 |
copycolor(sray.cext, cet); |
363 |
copycolor(sray.albedo, abt); |
364 |
normalize(sray.rdir); |
365 |
rayvalue(&sray); |
366 |
if (bright(sray.rcol) <= FTINY) /* missed it */ |
367 |
continue; |
368 |
369 |
370 |
* Compute spectral sum over diameter of source. |
371 |
* First find directions for rays going to opposite |
372 |
* sides of source, then compute wavelengths for each. |
373 |
374 |
375 |
fcross(vtmp1, v2Xdv, sray.rdir); |
376 |
dtmp1 = sqrt(si.dom / v2Xdvv2Xdv / PI); |
377 |
378 |
/* compute first ray */ |
379 |
380 |
vtmp2[i] = sray.rdir[i] + dtmp1*vtmp1[i]; |
381 |
382 |
l1 = lambda(m, v2, dv, vtmp2); /* first lambda */ |
383 |
if (l1 < 0) |
384 |
continue; |
385 |
/* compute second ray */ |
386 |
387 |
vtmp2[i] = sray.rdir[i] - dtmp1*vtmp1[i]; |
388 |
389 |
l2 = lambda(m, v2, dv, vtmp2); /* second lambda */ |
390 |
if (l2 < 0) |
391 |
continue; |
392 |
/* compute color from spectrum */ |
393 |
if (l1 < l2) |
394 |
spec_rgb(ctmp, l1, l2); |
395 |
else |
396 |
spec_rgb(ctmp, l2, l1); |
397 |
multcolor(ctmp, sray.rcol); |
398 |
scalecolor(ctmp, tr); |
399 |
addcolor(r->rcol, ctmp); |
400 |
success++; |
401 |
402 |
return(success); |
403 |
404 |
405 |
406 |
static int |
407 |
lambda(m, v2, dv, lr) /* compute lambda for material */ |
408 |
register OBJREC *m; |
409 |
FVECT v2, dv, lr; |
410 |
411 |
FVECT lrXdv, v2Xlr; |
412 |
double dtmp, denom; |
413 |
int i; |
414 |
415 |
fcross(lrXdv, lr, dv); |
416 |
417 |
if (lrXdv[i] > FTINY || lrXdv[i] < -FTINY) |
418 |
break; |
419 |
if (i >= 3) |
420 |
return(-1); |
421 |
422 |
fcross(v2Xlr, v2, lr); |
423 |
424 |
dtmp = m->oargs.farg[4] / MLAMBDA; |
425 |
denom = dtmp + v2Xlr[i]/lrXdv[i] * (m->oargs.farg[3] + dtmp); |
426 |
427 |
if (denom < FTINY) |
428 |
return(-1); |
429 |
430 |
return(m->oargs.farg[4] / denom); |
431 |
432 |
433 |
#endif /* DISPERSE */ |
