root/radiance/ray/src/rt/dielectric.c
Revision: 2.11
Committed: Wed Apr 17 14:01:52 1996 UTC (29 years, 1 month ago) by greg
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * dielectric.c - shading function for transparent materials.
9 *
10 * 9/6/85
11 */
12
13 #include "ray.h"
14
15 #include "otypes.h"
16
17 #ifdef DISPERSE
18 #include "source.h"
19 static disperse();
20 static int lambda();
21 #endif
22
23 /*
24 * Explicit calculations for Fresnel's equation are performed,
25 * but only one square root computation is necessary.
26 * The index of refraction is given as a Hartmann equation
27 * with lambda0 equal to zero. If the slope of Hartmann's
28 * equation is non-zero, the material disperses light upon
29 * refraction. This condition is examined on rays traced to
30 * light sources. If a ray is exiting a dielectric material, we
31 * check the sources to see if any would cause bright color to be
32 * directed to the viewer due to dispersion. This gives colorful
33 * sparkle to crystals, etc. (Only if DISPERSE is defined!)
34 *
35 * Arguments for MAT_DIELECTRIC are:
36 * red grn blu rndx Hartmann
37 *
38 * Arguments for MAT_INTERFACE are:
39 * red1 grn1 blu1 rndx1 red2 grn2 blu2 rndx2
40 *
41 * The primaries are material transmission per unit length.
42 * MAT_INTERFACE uses dielectric1 for inside and dielectric2 for
43 * outside.
44 */
45
46
47 #define MLAMBDA 500 /* mean lambda */
48 #define MAXLAMBDA 779 /* maximum lambda */
49 #define MINLAMBDA 380 /* minimum lambda */
50
51 #define MINCOS 0.997 /* minimum dot product for dispersion */
52
53 extern COLOR cextinction; /* global coefficient of extinction */
54 extern COLOR salbedo; /* global scattering albedo */
55
56
57 static double
58 mylog(x) /* special log for extinction coefficients */
59 double x;
60 {
61 if (x < 1e-40)
62 return(-100.);
63 if (x >= 1.)
64 return(0.);
65 return(log(x));
66 }
67
68
69 m_dielectric(m, r) /* color a ray which hit a dielectric interface */
70 OBJREC *m;
71 register RAY *r;
72 {
73 double cos1, cos2, nratio;
74 COLOR ctrans;
75 COLOR talb;
76 double mabsorp;
77 double refl, trans;
78 FVECT dnorm;
79 double d1, d2;
80 RAY p;
81 register int i;
82
83 if (m->oargs.nfargs != (m->otype==MAT_DIELECTRIC ? 5 : 8))
84 objerror(m, USER, "bad arguments");
85
86 raytexture(r, m->omod); /* get modifiers */
87
88 cos1 = raynormal(dnorm, r); /* cosine of theta1 */
89 /* index of refraction */
90 if (m->otype == MAT_DIELECTRIC)
91 nratio = m->oargs.farg[3] + m->oargs.farg[4]/MLAMBDA;
92 else
93 nratio = m->oargs.farg[3] / m->oargs.farg[7];
94
95 if (cos1 < 0.0) { /* inside */
96 cos1 = -cos1;
97 dnorm[0] = -dnorm[0];
98 dnorm[1] = -dnorm[1];
99 dnorm[2] = -dnorm[2];
100 setcolor(r->cext, -mylog(m->oargs.farg[0]*colval(r->pcol,RED)),
101 -mylog(m->oargs.farg[1]*colval(r->pcol,GRN)),
102 -mylog(m->oargs.farg[2]*colval(r->pcol,BLU)));
103 setcolor(r->albedo, 0., 0., 0.);
104 r->gecc = 0.;
105 if (m->otype == MAT_INTERFACE) {
106 setcolor(ctrans,
107 -mylog(m->oargs.farg[4]*colval(r->pcol,RED)),
108 -mylog(m->oargs.farg[5]*colval(r->pcol,GRN)),
109 -mylog(m->oargs.farg[6]*colval(r->pcol,BLU)));
110 setcolor(talb, 0., 0., 0.);
111 } else {
112 copycolor(ctrans, cextinction);
113 copycolor(talb, salbedo);
114 }
115 } else { /* outside */
116 nratio = 1.0 / nratio;
117
118 setcolor(ctrans, -mylog(m->oargs.farg[0]*colval(r->pcol,RED)),
119 -mylog(m->oargs.farg[1]*colval(r->pcol,GRN)),
120 -mylog(m->oargs.farg[2]*colval(r->pcol,BLU)));
121 setcolor(talb, 0., 0., 0.);
122 if (m->otype == MAT_INTERFACE) {
123 setcolor(r->cext,
124 -mylog(m->oargs.farg[4]*colval(r->pcol,RED)),
125 -mylog(m->oargs.farg[5]*colval(r->pcol,GRN)),
126 -mylog(m->oargs.farg[6]*colval(r->pcol,BLU)));
127 setcolor(r->albedo, 0., 0., 0.);
128 r->gecc = 0.;
129 }
130 }
131 mabsorp = exp(-bright(r->cext)*r->rot); /* approximate */
132
133 d2 = 1.0 - nratio*nratio*(1.0 - cos1*cos1); /* compute cos theta2 */
134
135 if (d2 < FTINY) /* total reflection */
136
137 refl = 1.0;
138
139 else { /* refraction occurs */
140 /* compute Fresnel's equations */
141 cos2 = sqrt(d2);
142 d1 = cos1;
143 d2 = nratio*cos2;
144 d1 = (d1 - d2) / (d1 + d2);
145 refl = d1 * d1;
146
147 d1 = 1.0 / cos1;
148 d2 = nratio / cos2;
149 d1 = (d1 - d2) / (d1 + d2);
150 refl += d1 * d1;
151
152 refl *= 0.5;
153 trans = 1.0 - refl;
154
155 if (rayorigin(&p, r, REFRACTED, mabsorp*trans) == 0) {
156
157 /* compute refracted ray */
158 d1 = nratio*cos1 - cos2;
159 for (i = 0; i < 3; i++)
160 p.rdir[i] = nratio*r->rdir[i] + d1*dnorm[i];
161
162 #ifdef DISPERSE
163 if (m->otype != MAT_DIELECTRIC
164 || r->rod > 0.0
165 || r->crtype & SHADOW
166 || !directvis
167 || m->oargs.farg[4] == 0.0
168 || !disperse(m, r, p.rdir, trans))
169 #endif
170 {
171 copycolor(p.cext, ctrans);
172 copycolor(p.albedo, talb);
173 rayvalue(&p);
174 scalecolor(p.rcol, trans);
175 addcolor(r->rcol, p.rcol);
176 if (nratio >= 1.0-FTINY && nratio <= 1.0+FTINY)
177 r->rt = r->rot + p.rt;
178 }
179 }
180 }
181
182 if (!(r->crtype & SHADOW) &&
183 rayorigin(&p, r, REFLECTED, mabsorp*refl) == 0) {
184
185 /* compute reflected ray */
186 for (i = 0; i < 3; i++)
187 p.rdir[i] = r->rdir[i] + 2.0*cos1*dnorm[i];
188
189 rayvalue(&p); /* reflected ray value */
190
191 scalecolor(p.rcol, refl); /* color contribution */
192 addcolor(r->rcol, p.rcol);
193 }
194 /* rayvalue() computes absorption */
195 return(1);
196 }
197
198
199 #ifdef DISPERSE
200
201 static
202 disperse(m, r, vt, tr) /* check light sources for dispersion */
203 OBJREC *m;
204 RAY *r;
205 FVECT vt;
206 double tr;
207 {
208 RAY sray, *entray;
209 FVECT v1, v2, n1, n2;
210 FVECT dv, v2Xdv;
211 double v2Xdvv2Xdv;
212 int success = 0;
213 SRCINDEX si;
214 FVECT vtmp1, vtmp2;
215 double dtmp1, dtmp2;
216 int l1, l2;
217 COLOR ctmp;
218 int i;
219
220 /*
221 * This routine computes dispersion to the first order using
222 * the following assumptions:
223 *
224 * 1) The dependency of the index of refraction on wavelength
225 * is approximated by Hartmann's equation with lambda0
226 * equal to zero.
227 * 2) The entry and exit locations are constant with respect
228 * to dispersion.
229 *
230 * The second assumption permits us to model dispersion without
231 * having to sample refracted directions. We assume that the
232 * geometry inside the material is constant, and concern ourselves
233 * only with the relationship between the entering and exiting ray.
234 * We compute the first derivatives of the entering and exiting
235 * refraction with respect to the index of refraction. This
236 * is then used in a first order Taylor series to determine the
237 * index of refraction necessary to send the exiting ray to each
238 * light source.
239 * If an exiting ray hits a light source within the refraction
240 * boundaries, we sum all the frequencies over the disc of the
241 * light source to determine the resulting color. A smaller light
242 * source will therefore exhibit a sharper spectrum.
243 */
244
245 if (!(r->crtype & REFRACTED)) { /* ray started in material */
246 VCOPY(v1, r->rdir);
247 n1[0] = -r->rdir[0]; n1[1] = -r->rdir[1]; n1[2] = -r->rdir[2];
248 } else {
249 /* find entry point */
250 for (entray = r; entray->rtype != REFRACTED;
251 entray = entray->parent)
252 ;
253 entray = entray->parent;
254 if (entray->crtype & REFRACTED) /* too difficult */
255 return(0);
256 VCOPY(v1, entray->rdir);
257 VCOPY(n1, entray->ron);
258 }
259 VCOPY(v2, vt); /* exiting ray */
260 VCOPY(n2, r->ron);
261
262 /* first order dispersion approx. */
263 dtmp1 = DOT(n1, v1);
264 dtmp2 = DOT(n2, v2);
265 for (i = 0; i < 3; i++)
266 dv[i] = v1[i] + v2[i] - n1[i]/dtmp1 - n2[i]/dtmp2;
267
268 if (DOT(dv, dv) <= FTINY) /* null effect */
269 return(0);
270 /* compute plane normal */
271 fcross(v2Xdv, v2, dv);
272 v2Xdvv2Xdv = DOT(v2Xdv, v2Xdv);
273
274 /* check sources */
275 initsrcindex(&si);
276 while (srcray(&sray, r, &si)) {
277
278 if (DOT(sray.rdir, v2) < MINCOS)
279 continue; /* bad source */
280 /* adjust source ray */
281
282 dtmp1 = DOT(v2Xdv, sray.rdir) / v2Xdvv2Xdv;
283 sray.rdir[0] -= dtmp1 * v2Xdv[0];
284 sray.rdir[1] -= dtmp1 * v2Xdv[1];
285 sray.rdir[2] -= dtmp1 * v2Xdv[2];
286
287 l1 = lambda(m, v2, dv, sray.rdir); /* mean lambda */
288
289 if (l1 > MAXLAMBDA || l1 < MINLAMBDA) /* not visible */
290 continue;
291 /* trace source ray */
292 normalize(sray.rdir);
293 rayvalue(&sray);
294 if (bright(sray.rcol) <= FTINY) /* missed it */
295 continue;
296
297 /*
298 * Compute spectral sum over diameter of source.
299 * First find directions for rays going to opposite
300 * sides of source, then compute wavelengths for each.
301 */
302
303 fcross(vtmp1, v2Xdv, sray.rdir);
304 dtmp1 = sqrt(si.dom / v2Xdvv2Xdv / PI);
305
306 /* compute first ray */
307 for (i = 0; i < 3; i++)
308 vtmp2[i] = sray.rdir[i] + dtmp1*vtmp1[i];
309
310 l1 = lambda(m, v2, dv, vtmp2); /* first lambda */
311 if (l1 < 0)
312 continue;
313 /* compute second ray */
314 for (i = 0; i < 3; i++)
315 vtmp2[i] = sray.rdir[i] - dtmp1*vtmp1[i];
316
317 l2 = lambda(m, v2, dv, vtmp2); /* second lambda */
318 if (l2 < 0)
319 continue;
320 /* compute color from spectrum */
321 if (l1 < l2)
322 spec_rgb(ctmp, l1, l2);
323 else
324 spec_rgb(ctmp, l2, l1);
325 multcolor(ctmp, sray.rcol);
326 scalecolor(ctmp, tr);
327 addcolor(r->rcol, ctmp);
328 success++;
329 }
330 return(success);
331 }
332
333
334 static int
335 lambda(m, v2, dv, lr) /* compute lambda for material */
336 register OBJREC *m;
337 FVECT v2, dv, lr;
338 {
339 FVECT lrXdv, v2Xlr;
340 double dtmp, denom;
341 int i;
342
343 fcross(lrXdv, lr, dv);
344 for (i = 0; i < 3; i++)
345 if (lrXdv[i] > FTINY || lrXdv[i] < -FTINY)
346 break;
347 if (i >= 3)
348 return(-1);
349
350 fcross(v2Xlr, v2, lr);
351
352 dtmp = m->oargs.farg[4] / MLAMBDA;
353 denom = dtmp + v2Xlr[i]/lrXdv[i] * (m->oargs.farg[3] + dtmp);
354
355 if (denom < FTINY)
356 return(-1);
357
358 return(m->oargs.farg[4] / denom);
359 }
360
361 #endif /* DISPERSE */
