root/radiance/ray/src/rt/dielectric.c
Fri Apr 19 19:01:32 2019 UTC (5 years, 1 month ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.29: +3 -2 lines
Diff to previous 2.29 , to selected 2.17
Make sure reflected ray distance is not infinite if there's a reflection
Tue Nov 13 19:58:33 2018 UTC (5 years, 6 months ago) by greg
Changes since 2.28: +6 -17 lines
Diff to previous 2.28 , to selected 2.17
Wed Oct 28 15:45:58 2015 UTC (8 years, 6 months ago) by greg
CVS Tags: rad5R1, rad5R2
Diff to previous 2.27 , to selected 2.17
Added back ambient ray testing for photon map, which is needed by rcontrib
Thu May 21 13:54:59 2015 UTC (9 years ago) by greg
Changes since 2.26: +3 -4 lines
Diff to previous 2.26 , to selected 2.17
Added calls to findmaterial() and simplified photon map shadow check
Wed May 20 13:12:06 2015 UTC (9 years ago) by rschregle
Diff to previous 2.25 , to selected 2.17
Fixed photon map double counting bug with ambient rays
Tue Feb 24 19:39:26 2015 UTC (9 years, 2 months ago) by greg
Changes since 2.24: +8 -3 lines
Diff to previous 2.24 , to selected 2.17
Sat May 10 17:43:01 2014 UTC (10 years ago) by greg
Changes since 2.23: +9 -8 lines
Diff to previous 2.23 , to selected 2.17
Fixed virtual distance so as not to undermine ambient calculation
Wed Aug 7 05:10:09 2013 UTC (10 years, 9 months ago) by greg
Diff to previous 2.22 , to selected 2.17
Mon Oct 25 22:57:45 2010 UTC (13 years, 7 months ago) by greg
Changes since 2.21: +9 -13 lines
Diff to previous 2.21 , to selected 2.17
Sun Sep 26 15:51:15 2010 UTC (13 years, 7 months ago) by greg
Changes since 2.20: +4 -3 lines
Diff to previous 2.20 , to selected 2.17
Changes since 2.19: +11 -7 lines
Diff to previous 2.19 , to selected 2.17
Thu Sep 9 06:46:07 2004 UTC (19 years, 8 months ago) by greg
Changes since 2.18: +24 -3 lines
Diff to previous 2.18 , to selected 2.17
Corrected effective ray length calculation
Changes since 2.17: +30 -19 lines
Diff to previous 2.17
Revision 2.17 - (view) (download) (annotate) - [selected]
Diff to previous 2.16
Changes since 2.15: +1 -56 lines
Diff to previous 2.15 , to selected 2.17
Changes since 2.14: +59 -8 lines
Diff to previous 2.14 , to selected 2.17
Fri Jun 19 12:01:15 1998 UTC (25 years, 11 months ago) by gwlarson
Changes since 2.13: +21 -2 lines
Diff to previous 2.13 , to selected 2.17
added tests for accidental reflection/penetration
Wed Jun 17 12:53:07 1998 UTC (25 years, 11 months ago) by gwlarson
Changes since 2.12: +4 -13 lines
Diff to previous 2.12 , to selected 2.17
improved the way ray weights are computed for participating media
Thu Jul 11 15:14:05 1996 UTC (27 years, 10 months ago) by greg
Changes since 2.11: +14 -3 lines
Diff to previous 2.11 , to selected 2.17
fixed bug in computation of absorption and dispersion routines
Wed Apr 17 14:01:52 1996 UTC (28 years, 1 month ago) by greg
Diff to previous 2.10 , to selected 2.17
Thu Feb 22 16:56:39 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.9: +24 -12 lines
Diff to previous 2.9 , to selected 2.17
fixed bug associated with taking log(0)
Fri Dec 8 18:22:07 1995 UTC (28 years, 5 months ago) by greg
Changes since 2.8: +39 -17 lines
Diff to previous 2.8 , to selected 2.17
Tue Dec 5 11:46:00 1995 UTC (28 years, 5 months ago) by greg
Diff to previous 2.7 , to selected 2.17
changed position of color modifier
Thu Jan 13 09:45:08 1994 UTC (30 years, 4 months ago) by greg
Diff to previous 2.6 , to selected 2.17
added missing material function return values
Thu Nov 18 09:43:00 1993 UTC (30 years, 6 months ago) by greg
Diff to previous 2.5 , to selected 2.17
minor compiler warning fixes
Mon Mar 8 12:37:15 1993 UTC (31 years, 2 months ago) by greg
Diff to previous 2.4 , to selected 2.17
Thu Feb 25 10:04:22 1993 UTC (31 years, 3 months ago) by greg
Diff to previous 2.3 , to selected 2.17
set effective length to transmitted length for n=1.0
Thu Nov 19 20:30:02 1992 UTC (31 years, 6 months ago) by greg
Diff to previous 2.2 , to selected 2.17
changed directinvis to !directvis
Fri Oct 2 16:17:04 1992 UTC (31 years, 7 months ago) by greg
Diff to previous 2.1 , to selected 2.17
Tue Nov 12 17:09:55 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.7 , to selected 2.17
Mon Oct 21 12:58:12 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.6: +6 -7 lines
Diff to previous 1.6 , to selected 2.17
Mon Aug 5 13:52:20 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.5: +1 -0 lines
Diff to previous 1.5 , to selected 2.17
added test for direct invisibility before dispersion test
Mon Oct 15 20:39:30 1990 UTC (33 years, 7 months ago) by greg
Changes since 1.4: +3 -6 lines
Diff to previous 1.4 , to selected 2.17
improved setting of rt RAY parameter
Wed May 30 19:56:58 1990 UTC (34 years ago) by greg
Changes since 1.3: +4 -2 lines
Diff to previous 1.3 , to selected 2.17
improved computation of r->rt using brightness comparison
Tue Mar 27 11:39:58 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.2: +3 -0 lines
Diff to previous 1.2 , to selected 2.17
Wed Jun 7 08:38:31 1989 UTC (34 years, 11 months ago) by greg
Diff to previous 1.1 , to selected 2.17
Thu Feb 2 10:41:21 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.17
