Corrected effective ray length calculation
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added tests for accidental reflection/penetration
improved the way ray weights are computed for participating media
fixed bug in computation of absorption and dispersion routines
fixed bug associated with taking log(0)
changed position of color modifier
added missing material function return values
minor compiler warning fixes
set effective length to transmitted length for n=1.0
changed directinvis to !directvis
added test for direct invisibility before dispersion test
improved setting of rt RAY parameter
improved computation of r->rt using brightness comparison
