| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: dielectric.c,v 2.19 2004/09/09 06:46:07 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* dielectric.c - shading function for transparent materials.
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include "ray.h"
| 11 |
#include "otypes.h"
| 12 |
#include "rtotypes.h"
| 13 |
| 14 |
#ifdef DISPERSE
| 15 |
#include "source.h"
| 16 |
static int disperse(OBJREC *m,RAY *r,FVECT vt,double tr,COLOR cet,COLOR abt);
| 17 |
static int lambda(OBJREC *m, FVECT v2, FVECT dv, FVECT lr);
| 18 |
#endif
| 19 |
| 20 |
static double mylog(double x);
| 21 |
| 22 |
| 23 |
| 24 |
* Explicit calculations for Fresnel's equation are performed,
| 25 |
* but only one square root computation is necessary.
| 26 |
* The index of refraction is given as a Hartmann equation
| 27 |
* with lambda0 equal to zero. If the slope of Hartmann's
| 28 |
* equation is non-zero, the material disperses light upon
| 29 |
* refraction. This condition is examined on rays traced to
| 30 |
* light sources. If a ray is exiting a dielectric material, we
| 31 |
* check the sources to see if any would cause bright color to be
| 32 |
* directed to the viewer due to dispersion. This gives colorful
| 33 |
* sparkle to crystals, etc. (Only if DISPERSE is defined!)
| 34 |
| 35 |
* Arguments for MAT_DIELECTRIC are:
| 36 |
* red grn blu rndx Hartmann
| 37 |
| 38 |
* Arguments for MAT_INTERFACE are:
| 39 |
* red1 grn1 blu1 rndx1 red2 grn2 blu2 rndx2
| 40 |
| 41 |
* The primaries are material transmission per unit length.
| 42 |
* MAT_INTERFACE uses dielectric1 for inside and dielectric2 for
| 43 |
* outside.
| 44 |
| 45 |
| 46 |
| 47 |
#define MLAMBDA 500 /* mean lambda */
| 48 |
#define MAXLAMBDA 779 /* maximum lambda */
| 49 |
#define MINLAMBDA 380 /* minimum lambda */
| 50 |
| 51 |
#define MINCOS 0.997 /* minimum dot product for dispersion */
| 52 |
| 53 |
| 54 |
static double
| 55 |
mylog( /* special log for extinction coefficients */
| 56 |
double x
| 57 |
| 58 |
| 59 |
if (x < 1e-40)
| 60 |
return(-100.);
| 61 |
if (x >= 1.)
| 62 |
return(0.);
| 63 |
return(log(x));
| 64 |
| 65 |
| 66 |
| 67 |
extern int
| 68 |
m_dielectric( /* color a ray which hit a dielectric interface */
| 69 |
OBJREC *m,
| 70 |
register RAY *r
| 71 |
| 72 |
| 73 |
double cos1, cos2, nratio;
| 74 |
COLOR ctrans;
| 75 |
COLOR talb;
| 76 |
int hastexture;
| 77 |
double transdist, transtest=0;
| 78 |
double mirdist, mirtest=0;
| 79 |
int flatsurface;
| 80 |
double refl, trans;
| 81 |
FVECT dnorm;
| 82 |
double d1, d2;
| 83 |
RAY p;
| 84 |
register int i;
| 85 |
| 86 |
if (m->oargs.nfargs != (m->otype==MAT_DIELECTRIC ? 5 : 8))
| 87 |
objerror(m, USER, "bad arguments");
| 88 |
| 89 |
raytexture(r, m->omod); /* get modifiers */
| 90 |
| 91 |
if ( (hastexture = DOT(r->pert,r->pert) > FTINY*FTINY) )
| 92 |
cos1 = raynormal(dnorm, r); /* perturb normal */
| 93 |
else {
| 94 |
VCOPY(dnorm, r->ron);
| 95 |
cos1 = r->rod;
| 96 |
| 97 |
flatsurface = !hastexture && r->ro != NULL && isflat(r->ro->otype);
| 98 |
| 99 |
/* index of refraction */
| 100 |
if (m->otype == MAT_DIELECTRIC)
| 101 |
nratio = m->oargs.farg[3] + m->oargs.farg[4]/MLAMBDA;
| 102 |
else
| 103 |
nratio = m->oargs.farg[3] / m->oargs.farg[7];
| 104 |
| 105 |
if (cos1 < 0.0) { /* inside */
| 106 |
hastexture = -hastexture;
| 107 |
cos1 = -cos1;
| 108 |
dnorm[0] = -dnorm[0];
| 109 |
dnorm[1] = -dnorm[1];
| 110 |
dnorm[2] = -dnorm[2];
| 111 |
setcolor(r->cext, -mylog(m->oargs.farg[0]*colval(r->pcol,RED)),
| 112 |
-mylog(m->oargs.farg[1]*colval(r->pcol,GRN)),
| 113 |
-mylog(m->oargs.farg[2]*colval(r->pcol,BLU)));
| 114 |
setcolor(r->albedo, 0., 0., 0.);
| 115 |
r->gecc = 0.;
| 116 |
if (m->otype == MAT_INTERFACE) {
| 117 |
setcolor(ctrans,
| 118 |
-mylog(m->oargs.farg[4]*colval(r->pcol,RED)),
| 119 |
-mylog(m->oargs.farg[5]*colval(r->pcol,GRN)),
| 120 |
-mylog(m->oargs.farg[6]*colval(r->pcol,BLU)));
| 121 |
setcolor(talb, 0., 0., 0.);
| 122 |
} else {
| 123 |
copycolor(ctrans, cextinction);
| 124 |
copycolor(talb, salbedo);
| 125 |
| 126 |
} else { /* outside */
| 127 |
nratio = 1.0 / nratio;
| 128 |
| 129 |
setcolor(ctrans, -mylog(m->oargs.farg[0]*colval(r->pcol,RED)),
| 130 |
| 131 |
| 132 |
| 133 |
| 134 |
setcolor(r->cext,
| 135 |
| 136 |
| 137 |
| 138 |
| 139 |
r->gecc = 0.;
| 140 |
| 141 |
| 142 |
| 143 |
d2 = 1.0 - nratio*nratio*(1.0 - cos1*cos1); /* compute cos theta2 */
| 144 |
| 145 |
if (d2 < FTINY) /* total reflection */
| 146 |
| 147 |
refl = 1.0;
| 148 |
| 149 |
else { /* refraction occurs */
| 150 |
/* compute Fresnel's equations */
| 151 |
cos2 = sqrt(d2);
| 152 |
d1 = cos1;
| 153 |
d2 = nratio*cos2;
| 154 |
d1 = (d1 - d2) / (d1 + d2);
| 155 |
refl = d1 * d1;
| 156 |
| 157 |
d1 = 1.0 / cos1;
| 158 |
d2 = nratio / cos2;
| 159 |
| 160 |
refl += d1 * d1;
| 161 |
| 162 |
refl *= 0.5;
| 163 |
trans = 1.0 - refl;
| 164 |
| 165 |
trans *= nratio*nratio; /* solid angle ratio */
| 166 |
| 167 |
setcolor(p.rcoef, trans, trans, trans);
| 168 |
| 169 |
if (rayorigin(&p, REFRACTED, r, p.rcoef) == 0) {
| 170 |
| 171 |
/* compute refracted ray */
| 172 |
d1 = nratio*cos1 - cos2;
| 173 |
for (i = 0; i < 3; i++)
| 174 |
p.rdir[i] = nratio*r->rdir[i] + d1*dnorm[i];
| 175 |
/* accidental reflection? */
| 176 |
if (hastexture &&
| 177 |
DOT(p.rdir,r->ron)*hastexture >= -FTINY) {
| 178 |
d1 *= (double)hastexture;
| 179 |
for (i = 0; i < 3; i++) /* ignore texture */
| 180 |
| 181 |
d1*r->ron[i];
| 182 |
normalize(p.rdir); /* not exact */
| 183 |
| 184 |
#ifdef DISPERSE
| 185 |
if (m->otype != MAT_DIELECTRIC
| 186 |
|| r->rod > 0.0
| 187 |
|| r->crtype & SHADOW
| 188 |
|| !directvis
| 189 |
|| m->oargs.farg[4] == 0.0
| 190 |
|| !disperse(m, r, p.rdir,
| 191 |
trans, ctrans, talb))
| 192 |
#endif
| 193 |
| 194 |
copycolor(p.cext, ctrans);
| 195 |
copycolor(p.albedo, talb);
| 196 |
rayvalue(&p);
| 197 |
multcolor(p.rcol, p.rcoef);
| 198 |
addcolor(r->rcol, p.rcol);
| 199 |
/* virtual distance */
| 200 |
if (flatsurface ||
| 201 |
(1.-FTINY <= nratio &&
| 202 |
nratio <= 1.+FTINY)) {
| 203 |
transtest = 2*bright(p.rcol);
| 204 |
transdist = r->rot + p.rt;
| 205 |
| 206 |
| 207 |
| 208 |
| 209 |
setcolor(p.rcoef, refl, refl, refl);
| 210 |
| 211 |
if (!(r->crtype & SHADOW) &&
| 212 |
rayorigin(&p, REFLECTED, r, p.rcoef) == 0) {
| 213 |
| 214 |
/* compute reflected ray */
| 215 |
| 216 |
p.rdir[i] = r->rdir[i] + 2.0*cos1*dnorm[i];
| 217 |
/* accidental penetration? */
| 218 |
if (hastexture && DOT(p.rdir,r->ron)*hastexture <= FTINY)
| 219 |
| 220 |
p.rdir[i] = r->rdir[i] + 2.0*r->rod*r->ron[i];
| 221 |
| 222 |
rayvalue(&p); /* reflected ray value */
| 223 |
| 224 |
multcolor(p.rcol, p.rcoef); /* color contribution */
| 225 |
| 226 |
| 227 |
if (flatsurface) {
| 228 |
mirtest = 2*bright(p.rcol);
| 229 |
mirdist = r->rot + p.rt;
| 230 |
| 231 |
| 232 |
/* check distance to return */
| 233 |
d1 = bright(r->rcol);
| 234 |
if (transtest > d1)
| 235 |
r->rt = transdist;
| 236 |
else if (mirtest > d1)
| 237 |
r->rt = mirdist;
| 238 |
/* rayvalue() computes absorption */
| 239 |
return(1);
| 240 |
| 241 |
| 242 |
| 243 |
#ifdef DISPERSE
| 244 |
| 245 |
static int
| 246 |
disperse( /* check light sources for dispersion */
| 247 |
OBJREC *m,
| 248 |
RAY *r,
| 249 |
FVECT vt,
| 250 |
double tr,
| 251 |
COLOR cet,
| 252 |
COLOR abt
| 253 |
| 254 |
| 255 |
RAY sray;
| 256 |
const RAY *entray;
| 257 |
FVECT v1, v2, n1, n2;
| 258 |
FVECT dv, v2Xdv;
| 259 |
double v2Xdvv2Xdv;
| 260 |
int success = 0;
| 261 |
SRCINDEX si;
| 262 |
FVECT vtmp1, vtmp2;
| 263 |
double dtmp1, dtmp2;
| 264 |
int l1, l2;
| 265 |
COLOR ctmp;
| 266 |
int i;
| 267 |
| 268 |
| 269 |
* This routine computes dispersion to the first order using
| 270 |
* the following assumptions:
| 271 |
| 272 |
* 1) The dependency of the index of refraction on wavelength
| 273 |
* is approximated by Hartmann's equation with lambda0
| 274 |
* equal to zero.
| 275 |
* 2) The entry and exit locations are constant with respect
| 276 |
* to dispersion.
| 277 |
| 278 |
* The second assumption permits us to model dispersion without
| 279 |
* having to sample refracted directions. We assume that the
| 280 |
* geometry inside the material is constant, and concern ourselves
| 281 |
* only with the relationship between the entering and exiting ray.
| 282 |
* We compute the first derivatives of the entering and exiting
| 283 |
* refraction with respect to the index of refraction. This
| 284 |
* is then used in a first order Taylor series to determine the
| 285 |
* index of refraction necessary to send the exiting ray to each
| 286 |
* light source.
| 287 |
* If an exiting ray hits a light source within the refraction
| 288 |
* boundaries, we sum all the frequencies over the disc of the
| 289 |
* light source to determine the resulting color. A smaller light
| 290 |
* source will therefore exhibit a sharper spectrum.
| 291 |
| 292 |
| 293 |
if (!(r->crtype & REFRACTED)) { /* ray started in material */
| 294 |
VCOPY(v1, r->rdir);
| 295 |
n1[0] = -r->rdir[0]; n1[1] = -r->rdir[1]; n1[2] = -r->rdir[2];
| 296 |
} else {
| 297 |
/* find entry point */
| 298 |
for (entray = r; entray->rtype != REFRACTED;
| 299 |
entray = entray->parent)
| 300 |
| 301 |
entray = entray->parent;
| 302 |
if (entray->crtype & REFRACTED) /* too difficult */
| 303 |
return(0);
| 304 |
VCOPY(v1, entray->rdir);
| 305 |
VCOPY(n1, entray->ron);
| 306 |
| 307 |
VCOPY(v2, vt); /* exiting ray */
| 308 |
VCOPY(n2, r->ron);
| 309 |
| 310 |
/* first order dispersion approx. */
| 311 |
dtmp1 = DOT(n1, v1);
| 312 |
dtmp2 = DOT(n2, v2);
| 313 |
| 314 |
dv[i] = v1[i] + v2[i] - n1[i]/dtmp1 - n2[i]/dtmp2;
| 315 |
| 316 |
if (DOT(dv, dv) <= FTINY) /* null effect */
| 317 |
return(0);
| 318 |
/* compute plane normal */
| 319 |
fcross(v2Xdv, v2, dv);
| 320 |
v2Xdvv2Xdv = DOT(v2Xdv, v2Xdv);
| 321 |
| 322 |
/* check sources */
| 323 |
initsrcindex(&si);
| 324 |
while (srcray(&sray, r, &si)) {
| 325 |
| 326 |
if (DOT(sray.rdir, v2) < MINCOS)
| 327 |
continue; /* bad source */
| 328 |
/* adjust source ray */
| 329 |
| 330 |
dtmp1 = DOT(v2Xdv, sray.rdir) / v2Xdvv2Xdv;
| 331 |
sray.rdir[0] -= dtmp1 * v2Xdv[0];
| 332 |
sray.rdir[1] -= dtmp1 * v2Xdv[1];
| 333 |
sray.rdir[2] -= dtmp1 * v2Xdv[2];
| 334 |
| 335 |
l1 = lambda(m, v2, dv, sray.rdir); /* mean lambda */
| 336 |
| 337 |
if (l1 > MAXLAMBDA || l1 < MINLAMBDA) /* not visible */
| 338 |
continue;
| 339 |
/* trace source ray */
| 340 |
copycolor(sray.cext, cet);
| 341 |
copycolor(sray.albedo, abt);
| 342 |
normalize(sray.rdir);
| 343 |
rayvalue(&sray);
| 344 |
if (bright(sray.rcol) <= FTINY) /* missed it */
| 345 |
continue;
| 346 |
| 347 |
| 348 |
* Compute spectral sum over diameter of source.
| 349 |
* First find directions for rays going to opposite
| 350 |
* sides of source, then compute wavelengths for each.
| 351 |
| 352 |
| 353 |
fcross(vtmp1, v2Xdv, sray.rdir);
| 354 |
dtmp1 = sqrt(si.dom / v2Xdvv2Xdv / PI);
| 355 |
| 356 |
/* compute first ray */
| 357 |
| 358 |
vtmp2[i] = sray.rdir[i] + dtmp1*vtmp1[i];
| 359 |
| 360 |
l1 = lambda(m, v2, dv, vtmp2); /* first lambda */
| 361 |
if (l1 < 0)
| 362 |
continue;
| 363 |
/* compute second ray */
| 364 |
| 365 |
vtmp2[i] = sray.rdir[i] - dtmp1*vtmp1[i];
| 366 |
| 367 |
l2 = lambda(m, v2, dv, vtmp2); /* second lambda */
| 368 |
if (l2 < 0)
| 369 |
continue;
| 370 |
/* compute color from spectrum */
| 371 |
if (l1 < l2)
| 372 |
spec_rgb(ctmp, l1, l2);
| 373 |
else
| 374 |
spec_rgb(ctmp, l2, l1);
| 375 |
multcolor(ctmp, sray.rcol);
| 376 |
scalecolor(ctmp, tr);
| 377 |
addcolor(r->rcol, ctmp);
| 378 |
success++;
| 379 |
| 380 |
return(success);
| 381 |
| 382 |
| 383 |
| 384 |
static int
| 385 |
lambda( /* compute lambda for material */
| 386 |
register OBJREC *m,
| 387 |
FVECT v2,
| 388 |
FVECT dv,
| 389 |
FVECT lr
| 390 |
| 391 |
| 392 |
FVECT lrXdv, v2Xlr;
| 393 |
double dtmp, denom;
| 394 |
int i;
| 395 |
| 396 |
fcross(lrXdv, lr, dv);
| 397 |
| 398 |
if (lrXdv[i] > FTINY || lrXdv[i] < -FTINY)
| 399 |
break;
| 400 |
if (i >= 3)
| 401 |
return(-1);
| 402 |
| 403 |
fcross(v2Xlr, v2, lr);
| 404 |
| 405 |
dtmp = m->oargs.farg[4] / MLAMBDA;
| 406 |
denom = dtmp + v2Xlr[i]/lrXdv[i] * (m->oargs.farg[3] + dtmp);
| 407 |
| 408 |
if (denom < FTINY)
| 409 |
return(-1);
| 410 |
| 411 |
return(m->oargs.farg[4] / denom);
| 412 |
| 413 |
| 414 |
#endif /* DISPERSE */
