root/radiance/ray/src/rt/dielectric.c
Revision: 2.14
Committed: Fri Jun 19 12:01:15 1998 UTC (26 years ago) by gwlarson
Changes since 2.13: +21 -2 lines
added tests for accidental reflection/penetration
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * dielectric.c - shading function for transparent materials.
9 *
10 * 9/6/85
11 */
12
13 #include "ray.h"
14
15 #include "otypes.h"
16
17 #ifdef DISPERSE
18 #include "source.h"
19 static disperse();
20 static int lambda();
21 #endif
22
23 /*
24 * Explicit calculations for Fresnel's equation are performed,
25 * but only one square root computation is necessary.
26 * The index of refraction is given as a Hartmann equation
27 * with lambda0 equal to zero. If the slope of Hartmann's
28 * equation is non-zero, the material disperses light upon
29 * refraction. This condition is examined on rays traced to
30 * light sources. If a ray is exiting a dielectric material, we
31 * check the sources to see if any would cause bright color to be
32 * directed to the viewer due to dispersion. This gives colorful
33 * sparkle to crystals, etc. (Only if DISPERSE is defined!)
34 *
35 * Arguments for MAT_DIELECTRIC are:
36 * red grn blu rndx Hartmann
37 *
38 * Arguments for MAT_INTERFACE are:
39 * red1 grn1 blu1 rndx1 red2 grn2 blu2 rndx2
40 *
41 * The primaries are material transmission per unit length.
42 * MAT_INTERFACE uses dielectric1 for inside and dielectric2 for
43 * outside.
44 */
45
46
47 #define MLAMBDA 500 /* mean lambda */
48 #define MAXLAMBDA 779 /* maximum lambda */
49 #define MINLAMBDA 380 /* minimum lambda */
50
51 #define MINCOS 0.997 /* minimum dot product for dispersion */
52
53 extern COLOR cextinction; /* global coefficient of extinction */
54 extern COLOR salbedo; /* global scattering albedo */
55
56
57 static double
58 mylog(x) /* special log for extinction coefficients */
59 double x;
60 {
61 if (x < 1e-40)
62 return(-100.);
63 if (x >= 1.)
64 return(0.);
65 return(log(x));
66 }
67
68
69 m_dielectric(m, r) /* color a ray which hit a dielectric interface */
70 OBJREC *m;
71 register RAY *r;
72 {
73 double cos1, cos2, nratio;
74 COLOR ctrans;
75 COLOR talb;
76 int hastexture;
77 double refl, trans;
78 FVECT dnorm;
79 double d1, d2;
80 RAY p;
81 register int i;
82
83 if (m->oargs.nfargs != (m->otype==MAT_DIELECTRIC ? 5 : 8))
84 objerror(m, USER, "bad arguments");
85
86 raytexture(r, m->omod); /* get modifiers */
87
88 if (hastexture = DOT(r->pert,r->pert) > FTINY*FTINY)
89 cos1 = raynormal(dnorm, r); /* perturb normal */
90 else {
91 VCOPY(dnorm, r->ron);
92 cos1 = r->rod;
93 }
94 /* index of refraction */
95 if (m->otype == MAT_DIELECTRIC)
96 nratio = m->oargs.farg[3] + m->oargs.farg[4]/MLAMBDA;
97 else
98 nratio = m->oargs.farg[3] / m->oargs.farg[7];
99
100 if (cos1 < 0.0) { /* inside */
101 hastexture = -hastexture;
102 cos1 = -cos1;
103 dnorm[0] = -dnorm[0];
104 dnorm[1] = -dnorm[1];
105 dnorm[2] = -dnorm[2];
106 setcolor(r->cext, -mylog(m->oargs.farg[0]*colval(r->pcol,RED)),
107 -mylog(m->oargs.farg[1]*colval(r->pcol,GRN)),
108 -mylog(m->oargs.farg[2]*colval(r->pcol,BLU)));
109 setcolor(r->albedo, 0., 0., 0.);
110 r->gecc = 0.;
111 if (m->otype == MAT_INTERFACE) {
112 setcolor(ctrans,
113 -mylog(m->oargs.farg[4]*colval(r->pcol,RED)),
114 -mylog(m->oargs.farg[5]*colval(r->pcol,GRN)),
115 -mylog(m->oargs.farg[6]*colval(r->pcol,BLU)));
116 setcolor(talb, 0., 0., 0.);
117 } else {
118 copycolor(ctrans, cextinction);
119 copycolor(talb, salbedo);
120 }
121 } else { /* outside */
122 nratio = 1.0 / nratio;
123
124 setcolor(ctrans, -mylog(m->oargs.farg[0]*colval(r->pcol,RED)),
125 -mylog(m->oargs.farg[1]*colval(r->pcol,GRN)),
126 -mylog(m->oargs.farg[2]*colval(r->pcol,BLU)));
127 setcolor(talb, 0., 0., 0.);
128 if (m->otype == MAT_INTERFACE) {
129 setcolor(r->cext,
130 -mylog(m->oargs.farg[4]*colval(r->pcol,RED)),
131 -mylog(m->oargs.farg[5]*colval(r->pcol,GRN)),
132 -mylog(m->oargs.farg[6]*colval(r->pcol,BLU)));
133 setcolor(r->albedo, 0., 0., 0.);
134 r->gecc = 0.;
135 }
136 }
137
138 d2 = 1.0 - nratio*nratio*(1.0 - cos1*cos1); /* compute cos theta2 */
139
140 if (d2 < FTINY) /* total reflection */
141
142 refl = 1.0;
143
144 else { /* refraction occurs */
145 /* compute Fresnel's equations */
146 cos2 = sqrt(d2);
147 d1 = cos1;
148 d2 = nratio*cos2;
149 d1 = (d1 - d2) / (d1 + d2);
150 refl = d1 * d1;
151
152 d1 = 1.0 / cos1;
153 d2 = nratio / cos2;
154 d1 = (d1 - d2) / (d1 + d2);
155 refl += d1 * d1;
156
157 refl *= 0.5;
158 trans = 1.0 - refl;
159
160 if (rayorigin(&p, r, REFRACTED, trans) == 0) {
161
162 /* compute refracted ray */
163 d1 = nratio*cos1 - cos2;
164 for (i = 0; i < 3; i++)
165 p.rdir[i] = nratio*r->rdir[i] + d1*dnorm[i];
166 /* accidental reflection? */
167 if (hastexture &&
168 DOT(p.rdir,r->ron)*hastexture >= -FTINY) {
169 d1 *= (double)hastexture;
170 for (i = 0; i < 3; i++) /* ignore texture */
171 p.rdir[i] = nratio*r->rdir[i] +
172 d1*r->ron[i];
173 normalize(p.rdir); /* not exact */
174 }
175 #ifdef DISPERSE
176 if (m->otype != MAT_DIELECTRIC
177 || r->rod > 0.0
178 || r->crtype & SHADOW
179 || !directvis
180 || m->oargs.farg[4] == 0.0
181 || !disperse(m, r, p.rdir,
182 trans, ctrans, talb))
183 #endif
184 {
185 copycolor(p.cext, ctrans);
186 copycolor(p.albedo, talb);
187 rayvalue(&p);
188 scalecolor(p.rcol, trans);
189 addcolor(r->rcol, p.rcol);
190 if (nratio >= 1.0-FTINY && nratio <= 1.0+FTINY)
191 r->rt = r->rot + p.rt;
192 }
193 }
194 }
195
196 if (!(r->crtype & SHADOW) &&
197 rayorigin(&p, r, REFLECTED, refl) == 0) {
198
199 /* compute reflected ray */
200 for (i = 0; i < 3; i++)
201 p.rdir[i] = r->rdir[i] + 2.0*cos1*dnorm[i];
202 /* accidental penetration? */
203 if (hastexture && DOT(p.rdir,r->ron)*hastexture <= FTINY)
204 for (i = 0; i < 3; i++) /* ignore texture */
205 p.rdir[i] = r->rdir[i] + 2.0*r->rod*r->ron[i];
206
207 rayvalue(&p); /* reflected ray value */
208
209 scalecolor(p.rcol, refl); /* color contribution */
210 addcolor(r->rcol, p.rcol);
211 }
212 /* rayvalue() computes absorption */
213 return(1);
214 }
215
216
217 #ifdef DISPERSE
218
219 static
220 disperse(m, r, vt, tr, cet, abt) /* check light sources for dispersion */
221 OBJREC *m;
222 RAY *r;
223 FVECT vt;
224 double tr;
225 COLOR cet, abt;
226 {
227 RAY sray, *entray;
228 FVECT v1, v2, n1, n2;
229 FVECT dv, v2Xdv;
230 double v2Xdvv2Xdv;
231 int success = 0;
232 SRCINDEX si;
233 FVECT vtmp1, vtmp2;
234 double dtmp1, dtmp2;
235 int l1, l2;
236 COLOR ctmp;
237 int i;
238
239 /*
240 * This routine computes dispersion to the first order using
241 * the following assumptions:
242 *
243 * 1) The dependency of the index of refraction on wavelength
244 * is approximated by Hartmann's equation with lambda0
245 * equal to zero.
246 * 2) The entry and exit locations are constant with respect
247 * to dispersion.
248 *
249 * The second assumption permits us to model dispersion without
250 * having to sample refracted directions. We assume that the
251 * geometry inside the material is constant, and concern ourselves
252 * only with the relationship between the entering and exiting ray.
253 * We compute the first derivatives of the entering and exiting
254 * refraction with respect to the index of refraction. This
255 * is then used in a first order Taylor series to determine the
256 * index of refraction necessary to send the exiting ray to each
257 * light source.
258 * If an exiting ray hits a light source within the refraction
259 * boundaries, we sum all the frequencies over the disc of the
260 * light source to determine the resulting color. A smaller light
261 * source will therefore exhibit a sharper spectrum.
262 */
263
264 if (!(r->crtype & REFRACTED)) { /* ray started in material */
265 VCOPY(v1, r->rdir);
266 n1[0] = -r->rdir[0]; n1[1] = -r->rdir[1]; n1[2] = -r->rdir[2];
267 } else {
268 /* find entry point */
269 for (entray = r; entray->rtype != REFRACTED;
270 entray = entray->parent)
271 ;
272 entray = entray->parent;
273 if (entray->crtype & REFRACTED) /* too difficult */
274 return(0);
275 VCOPY(v1, entray->rdir);
276 VCOPY(n1, entray->ron);
277 }
278 VCOPY(v2, vt); /* exiting ray */
279 VCOPY(n2, r->ron);
280
281 /* first order dispersion approx. */
282 dtmp1 = DOT(n1, v1);
283 dtmp2 = DOT(n2, v2);
284 for (i = 0; i < 3; i++)
285 dv[i] = v1[i] + v2[i] - n1[i]/dtmp1 - n2[i]/dtmp2;
286
287 if (DOT(dv, dv) <= FTINY) /* null effect */
288 return(0);
289 /* compute plane normal */
290 fcross(v2Xdv, v2, dv);
291 v2Xdvv2Xdv = DOT(v2Xdv, v2Xdv);
292
293 /* check sources */
294 initsrcindex(&si);
295 while (srcray(&sray, r, &si)) {
296
297 if (DOT(sray.rdir, v2) < MINCOS)
298 continue; /* bad source */
299 /* adjust source ray */
300
301 dtmp1 = DOT(v2Xdv, sray.rdir) / v2Xdvv2Xdv;
302 sray.rdir[0] -= dtmp1 * v2Xdv[0];
303 sray.rdir[1] -= dtmp1 * v2Xdv[1];
304 sray.rdir[2] -= dtmp1 * v2Xdv[2];
305
306 l1 = lambda(m, v2, dv, sray.rdir); /* mean lambda */
307
308 if (l1 > MAXLAMBDA || l1 < MINLAMBDA) /* not visible */
309 continue;
310 /* trace source ray */
311 copycolor(sray.cext, cet);
312 copycolor(sray.albedo, abt);
313 normalize(sray.rdir);
314 rayvalue(&sray);
315 if (bright(sray.rcol) <= FTINY) /* missed it */
316 continue;
317
318 /*
319 * Compute spectral sum over diameter of source.
320 * First find directions for rays going to opposite
321 * sides of source, then compute wavelengths for each.
322 */
323
324 fcross(vtmp1, v2Xdv, sray.rdir);
325 dtmp1 = sqrt(si.dom / v2Xdvv2Xdv / PI);
326
327 /* compute first ray */
328 for (i = 0; i < 3; i++)
329 vtmp2[i] = sray.rdir[i] + dtmp1*vtmp1[i];
330
331 l1 = lambda(m, v2, dv, vtmp2); /* first lambda */
332 if (l1 < 0)
333 continue;
334 /* compute second ray */
335 for (i = 0; i < 3; i++)
336 vtmp2[i] = sray.rdir[i] - dtmp1*vtmp1[i];
337
338 l2 = lambda(m, v2, dv, vtmp2); /* second lambda */
339 if (l2 < 0)
340 continue;
341 /* compute color from spectrum */
342 if (l1 < l2)
343 spec_rgb(ctmp, l1, l2);
344 else
345 spec_rgb(ctmp, l2, l1);
346 multcolor(ctmp, sray.rcol);
347 scalecolor(ctmp, tr);
348 addcolor(r->rcol, ctmp);
349 success++;
350 }
351 return(success);
352 }
353
354
355 static int
356 lambda(m, v2, dv, lr) /* compute lambda for material */
357 register OBJREC *m;
358 FVECT v2, dv, lr;
359 {
360 FVECT lrXdv, v2Xlr;
361 double dtmp, denom;
362 int i;
363
364 fcross(lrXdv, lr, dv);
365 for (i = 0; i < 3; i++)
366 if (lrXdv[i] > FTINY || lrXdv[i] < -FTINY)
367 break;
368 if (i >= 3)
369 return(-1);
370
371 fcross(v2Xlr, v2, lr);
372
373 dtmp = m->oargs.farg[4] / MLAMBDA;
374 denom = dtmp + v2Xlr[i]/lrXdv[i] * (m->oargs.farg[3] + dtmp);
375
376 if (denom < FTINY)
377 return(-1);
378
379 return(m->oargs.farg[4] / denom);
380 }
381
382 #endif /* DISPERSE */
