root/radiance/ray/src/rt/dielectric.c
Revision: 2.18
Committed: Tue Mar 30 16:13:01 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.17: +30 -19 lines
2 static const char RCSid[] = "$Id: dielectric.c,v 2.17 2003/07/27 22:12:03 schorsch Exp $";
5 * dielectric.c - shading function for transparent materials.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "otypes.h"
12 #include "rtotypes.h"
13
14 #ifdef DISPERSE
15 #include "source.h"
16 static int disperse(OBJREC *m,RAY *r,FVECT vt,double tr,COLOR cet,COLOR abt);
17 static int lambda(OBJREC *m, FVECT v2, FVECT dv, FVECT lr);
18 #endif
19
20 static double mylog(double x);
21
22
23 /*
24 * Explicit calculations for Fresnel's equation are performed,
25 * but only one square root computation is necessary.
26 * The index of refraction is given as a Hartmann equation
27 * with lambda0 equal to zero. If the slope of Hartmann's
28 * equation is non-zero, the material disperses light upon
29 * refraction. This condition is examined on rays traced to
30 * light sources. If a ray is exiting a dielectric material, we
31 * check the sources to see if any would cause bright color to be
32 * directed to the viewer due to dispersion. This gives colorful
33 * sparkle to crystals, etc. (Only if DISPERSE is defined!)
34 *
35 * Arguments for MAT_DIELECTRIC are:
36 * red grn blu rndx Hartmann
37 *
38 * Arguments for MAT_INTERFACE are:
39 * red1 grn1 blu1 rndx1 red2 grn2 blu2 rndx2
40 *
41 * The primaries are material transmission per unit length.
42 * MAT_INTERFACE uses dielectric1 for inside and dielectric2 for
43 * outside.
44 */
45
46
47 #define MLAMBDA 500 /* mean lambda */
48 #define MAXLAMBDA 779 /* maximum lambda */
49 #define MINLAMBDA 380 /* minimum lambda */
50
51 #define MINCOS 0.997 /* minimum dot product for dispersion */
52
53
54 static double
55 mylog( /* special log for extinction coefficients */
56 double x
57 )
58 {
59 if (x < 1e-40)
60 return(-100.);
61 if (x >= 1.)
62 return(0.);
63 return(log(x));
64 }
65
66
67 extern int
68 m_dielectric( /* color a ray which hit a dielectric interface */
69 OBJREC *m,
70 register RAY *r
71 )
72 {
73 double cos1, cos2, nratio;
74 COLOR ctrans;
75 COLOR talb;
76 int hastexture;
77 double refl, trans;
78 FVECT dnorm;
79 double d1, d2;
80 RAY p;
81 register int i;
82
83 if (m->oargs.nfargs != (m->otype==MAT_DIELECTRIC ? 5 : 8))
84 objerror(m, USER, "bad arguments");
85
86 raytexture(r, m->omod); /* get modifiers */
87
88 if ( (hastexture = DOT(r->pert,r->pert) > FTINY*FTINY) )
89 cos1 = raynormal(dnorm, r); /* perturb normal */
90 else {
91 VCOPY(dnorm, r->ron);
92 cos1 = r->rod;
93 }
94 /* index of refraction */
95 if (m->otype == MAT_DIELECTRIC)
96 nratio = m->oargs.farg[3] + m->oargs.farg[4]/MLAMBDA;
97 else
98 nratio = m->oargs.farg[3] / m->oargs.farg[7];
99
100 if (cos1 < 0.0) { /* inside */
101 hastexture = -hastexture;
102 cos1 = -cos1;
103 dnorm[0] = -dnorm[0];
104 dnorm[1] = -dnorm[1];
105 dnorm[2] = -dnorm[2];
106 setcolor(r->cext, -mylog(m->oargs.farg[0]*colval(r->pcol,RED)),
107 -mylog(m->oargs.farg[1]*colval(r->pcol,GRN)),
108 -mylog(m->oargs.farg[2]*colval(r->pcol,BLU)));
109 setcolor(r->albedo, 0., 0., 0.);
110 r->gecc = 0.;
111 if (m->otype == MAT_INTERFACE) {
112 setcolor(ctrans,
113 -mylog(m->oargs.farg[4]*colval(r->pcol,RED)),
114 -mylog(m->oargs.farg[5]*colval(r->pcol,GRN)),
115 -mylog(m->oargs.farg[6]*colval(r->pcol,BLU)));
116 setcolor(talb, 0., 0., 0.);
117 } else {
118 copycolor(ctrans, cextinction);
119 copycolor(talb, salbedo);
120 }
121 } else { /* outside */
122 nratio = 1.0 / nratio;
123
124 setcolor(ctrans, -mylog(m->oargs.farg[0]*colval(r->pcol,RED)),
125 -mylog(m->oargs.farg[1]*colval(r->pcol,GRN)),
126 -mylog(m->oargs.farg[2]*colval(r->pcol,BLU)));
127 setcolor(talb, 0., 0., 0.);
128 if (m->otype == MAT_INTERFACE) {
129 setcolor(r->cext,
130 -mylog(m->oargs.farg[4]*colval(r->pcol,RED)),
131 -mylog(m->oargs.farg[5]*colval(r->pcol,GRN)),
132 -mylog(m->oargs.farg[6]*colval(r->pcol,BLU)));
133 setcolor(r->albedo, 0., 0., 0.);
134 r->gecc = 0.;
135 }
136 }
137
138 d2 = 1.0 - nratio*nratio*(1.0 - cos1*cos1); /* compute cos theta2 */
139
140 if (d2 < FTINY) /* total reflection */
141
142 refl = 1.0;
143
144 else { /* refraction occurs */
145 /* compute Fresnel's equations */
146 cos2 = sqrt(d2);
147 d1 = cos1;
148 d2 = nratio*cos2;
149 d1 = (d1 - d2) / (d1 + d2);
150 refl = d1 * d1;
151
152 d1 = 1.0 / cos1;
153 d2 = nratio / cos2;
154 d1 = (d1 - d2) / (d1 + d2);
155 refl += d1 * d1;
156
157 refl *= 0.5;
158 trans = 1.0 - refl;
159
160 trans *= nratio*nratio; /* solid angle ratio */
161
162 if (rayorigin(&p, r, REFRACTED, trans) == 0) {
163
164 /* compute refracted ray */
165 d1 = nratio*cos1 - cos2;
166 for (i = 0; i < 3; i++)
167 p.rdir[i] = nratio*r->rdir[i] + d1*dnorm[i];
168 /* accidental reflection? */
169 if (hastexture &&
170 DOT(p.rdir,r->ron)*hastexture >= -FTINY) {
171 d1 *= (double)hastexture;
172 for (i = 0; i < 3; i++) /* ignore texture */
173 p.rdir[i] = nratio*r->rdir[i] +
174 d1*r->ron[i];
175 normalize(p.rdir); /* not exact */
176 }
177 #ifdef DISPERSE
178 if (m->otype != MAT_DIELECTRIC
179 || r->rod > 0.0
180 || r->crtype & SHADOW
181 || !directvis
182 || m->oargs.farg[4] == 0.0
183 || !disperse(m, r, p.rdir,
184 trans, ctrans, talb))
185 #endif
186 {
187 copycolor(p.cext, ctrans);
188 copycolor(p.albedo, talb);
189 rayvalue(&p);
190 scalecolor(p.rcol, trans);
191 addcolor(r->rcol, p.rcol);
192 if (nratio >= 1.0-FTINY && nratio <= 1.0+FTINY)
193 r->rt = r->rot + p.rt;
194 }
195 }
196 }
197
198 if (!(r->crtype & SHADOW) &&
199 rayorigin(&p, r, REFLECTED, refl) == 0) {
200
201 /* compute reflected ray */
202 for (i = 0; i < 3; i++)
203 p.rdir[i] = r->rdir[i] + 2.0*cos1*dnorm[i];
204 /* accidental penetration? */
205 if (hastexture && DOT(p.rdir,r->ron)*hastexture <= FTINY)
206 for (i = 0; i < 3; i++) /* ignore texture */
207 p.rdir[i] = r->rdir[i] + 2.0*r->rod*r->ron[i];
208
209 rayvalue(&p); /* reflected ray value */
210
211 scalecolor(p.rcol, refl); /* color contribution */
212 addcolor(r->rcol, p.rcol);
213 }
214 /* rayvalue() computes absorption */
215 return(1);
216 }
217
218
219 #ifdef DISPERSE
220
221 static int
222 disperse( /* check light sources for dispersion */
223 OBJREC *m,
224 RAY *r,
225 FVECT vt,
226 double tr,
227 COLOR cet,
228 COLOR abt
229 )
230 {
231 RAY sray, *entray;
232 FVECT v1, v2, n1, n2;
233 FVECT dv, v2Xdv;
234 double v2Xdvv2Xdv;
235 int success = 0;
236 SRCINDEX si;
237 FVECT vtmp1, vtmp2;
238 double dtmp1, dtmp2;
239 int l1, l2;
240 COLOR ctmp;
241 int i;
242
243 /*
244 * This routine computes dispersion to the first order using
245 * the following assumptions:
246 *
247 * 1) The dependency of the index of refraction on wavelength
248 * is approximated by Hartmann's equation with lambda0
249 * equal to zero.
250 * 2) The entry and exit locations are constant with respect
251 * to dispersion.
252 *
253 * The second assumption permits us to model dispersion without
254 * having to sample refracted directions. We assume that the
255 * geometry inside the material is constant, and concern ourselves
256 * only with the relationship between the entering and exiting ray.
257 * We compute the first derivatives of the entering and exiting
258 * refraction with respect to the index of refraction. This
259 * is then used in a first order Taylor series to determine the
260 * index of refraction necessary to send the exiting ray to each
261 * light source.
262 * If an exiting ray hits a light source within the refraction
263 * boundaries, we sum all the frequencies over the disc of the
264 * light source to determine the resulting color. A smaller light
265 * source will therefore exhibit a sharper spectrum.
266 */
267
268 if (!(r->crtype & REFRACTED)) { /* ray started in material */
269 VCOPY(v1, r->rdir);
270 n1[0] = -r->rdir[0]; n1[1] = -r->rdir[1]; n1[2] = -r->rdir[2];
271 } else {
272 /* find entry point */
273 for (entray = r; entray->rtype != REFRACTED;
274 entray = entray->parent)
275 ;
276 entray = entray->parent;
277 if (entray->crtype & REFRACTED) /* too difficult */
278 return(0);
279 VCOPY(v1, entray->rdir);
280 VCOPY(n1, entray->ron);
281 }
282 VCOPY(v2, vt); /* exiting ray */
283 VCOPY(n2, r->ron);
284
285 /* first order dispersion approx. */
286 dtmp1 = DOT(n1, v1);
287 dtmp2 = DOT(n2, v2);
288 for (i = 0; i < 3; i++)
289 dv[i] = v1[i] + v2[i] - n1[i]/dtmp1 - n2[i]/dtmp2;
290
291 if (DOT(dv, dv) <= FTINY) /* null effect */
292 return(0);
293 /* compute plane normal */
294 fcross(v2Xdv, v2, dv);
295 v2Xdvv2Xdv = DOT(v2Xdv, v2Xdv);
296
297 /* check sources */
298 initsrcindex(&si);
299 while (srcray(&sray, r, &si)) {
300
301 if (DOT(sray.rdir, v2) < MINCOS)
302 continue; /* bad source */
303 /* adjust source ray */
304
305 dtmp1 = DOT(v2Xdv, sray.rdir) / v2Xdvv2Xdv;
306 sray.rdir[0] -= dtmp1 * v2Xdv[0];
307 sray.rdir[1] -= dtmp1 * v2Xdv[1];
308 sray.rdir[2] -= dtmp1 * v2Xdv[2];
309
310 l1 = lambda(m, v2, dv, sray.rdir); /* mean lambda */
311
312 if (l1 > MAXLAMBDA || l1 < MINLAMBDA) /* not visible */
313 continue;
314 /* trace source ray */
315 copycolor(sray.cext, cet);
316 copycolor(sray.albedo, abt);
317 normalize(sray.rdir);
318 rayvalue(&sray);
319 if (bright(sray.rcol) <= FTINY) /* missed it */
320 continue;
321
322 /*
323 * Compute spectral sum over diameter of source.
324 * First find directions for rays going to opposite
325 * sides of source, then compute wavelengths for each.
326 */
327
328 fcross(vtmp1, v2Xdv, sray.rdir);
329 dtmp1 = sqrt(si.dom / v2Xdvv2Xdv / PI);
330
331 /* compute first ray */
332 for (i = 0; i < 3; i++)
333 vtmp2[i] = sray.rdir[i] + dtmp1*vtmp1[i];
334
335 l1 = lambda(m, v2, dv, vtmp2); /* first lambda */
336 if (l1 < 0)
337 continue;
338 /* compute second ray */
339 for (i = 0; i < 3; i++)
340 vtmp2[i] = sray.rdir[i] - dtmp1*vtmp1[i];
341
342 l2 = lambda(m, v2, dv, vtmp2); /* second lambda */
343 if (l2 < 0)
344 continue;
345 /* compute color from spectrum */
346 if (l1 < l2)
347 spec_rgb(ctmp, l1, l2);
348 else
349 spec_rgb(ctmp, l2, l1);
350 multcolor(ctmp, sray.rcol);
351 scalecolor(ctmp, tr);
352 addcolor(r->rcol, ctmp);
353 success++;
354 }
355 return(success);
356 }
357
358
359 static int
360 lambda( /* compute lambda for material */
361 register OBJREC *m,
362 FVECT v2,
363 FVECT dv,
364 FVECT lr
365 )
366 {
367 FVECT lrXdv, v2Xlr;
368 double dtmp, denom;
369 int i;
370
371 fcross(lrXdv, lr, dv);
372 for (i = 0; i < 3; i++)
373 if (lrXdv[i] > FTINY || lrXdv[i] < -FTINY)
374 break;
375 if (i >= 3)
376 return(-1);
377
378 fcross(v2Xlr, v2, lr);
379
380 dtmp = m->oargs.farg[4] / MLAMBDA;
381 denom = dtmp + v2Xlr[i]/lrXdv[i] * (m->oargs.farg[3] + dtmp);
382
383 if (denom < FTINY)
384 return(-1);
385
386 return(m->oargs.farg[4] / denom);
387 }
388
389 #endif /* DISPERSE */
