root/radiance/ray/src/rt/devtable.c
Fri Apr 6 17:52:33 2018 UTC (6 years, 1 month ago) by greg
Made excluding X11 a little simpler
Sat Mar 19 12:51:36 2016 UTC (8 years, 2 months ago) by schorsch
Changes since 2.8: +13 -6 lines
prepare for winrview integration
Wed Oct 5 17:20:55 2011 UTC (12 years, 7 months ago) by greg
Changes since 2.7: +18 -2 lines
Windows compatibility changes from Bill Hoffman
Mon Jun 30 19:04:29 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.3: +60 -6 lines
Mon Sep 12 15:47:17 1994 UTC (29 years, 8 months ago) by greg
Changes since 2.2: +2 -3 lines
added "x11d" driver for using stdin & stdout instead of command line
Fri Dec 13 10:42:37 1991 UTC (32 years, 5 months ago) by greg
no one uses x10 anymore (sniff!)
Tue Nov 12 17:09:50 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.11 , to selected 2.7
Thu Nov 7 16:34:55 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.10: +2 -1 lines
Diff to previous 1.10 , to selected 2.7
news driver for SGI
Fri Mar 8 12:55:40 1991 UTC (33 years, 3 months ago) by greg
Changes since 1.9: +1 -0 lines
Diff to previous 1.9 , to selected 2.7
added aed as external driver
Wed Mar 6 17:16:54 1991 UTC (33 years, 3 months ago) by greg
Changes since 1.8: +4 -6 lines
Diff to previous 1.8 , to selected 2.7
Wed Oct 31 14:07:07 1990 UTC (33 years, 7 months ago) by greg
Diff to previous 1.7 , to selected 2.7
changed driver names
Wed Jul 18 21:45:09 1990 UTC (33 years, 10 months ago) by greg
Diff to previous 1.6 , to selected 2.7
added NeWS driver
Fri Mar 9 14:00:05 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.5 , to selected 2.7
moved naming of default device to devtable.c
Wed Mar 7 12:03:24 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.4: +2 -1 lines
Diff to previous 1.4 , to selected 2.7
added x11 driver
Thu Jan 11 11:27:18 1990 UTC (34 years, 4 months ago) by greg
Diff to previous 1.3 , to selected 2.7
Wed Mar 15 14:20:33 1989 UTC (35 years, 2 months ago) by greg
Changes since 1.2: +0 -2 lines
deleted conditional compile for Suns
Wed Mar 15 14:01:55 1989 UTC (35 years, 2 months ago) by greg
added conditional compile for Suns
Thu Feb 2 10:41:20 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.7
