root/radiance/ray/src/rt/devmain.c
Revision: 2.4
Committed: Tue Feb 25 02:47:22 2003 UTC (22 years, 1 month ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1
Changes since 2.3: +1 -56 lines
5 * devmain.c - main for independent drivers.
6 *
7 * Redefine your initialization routine to dinit.
8 */
9
10 #include "copyright.h"
11
12 #include "standard.h"
13
14 #include "color.h"
15
16 #include "driver.h"
17
18 struct driver *dev = NULL; /* output device */
19
20 FILE *devin, *devout; /* communications channels */
21
22 char *progname; /* driver name */
23
24 int r_clear(), r_paintr(), r_getcur(), r_comout(), r_comin(), r_flush();
25
26 int (*dev_func[NREQUESTS])() = { /* request handlers */
27 r_clear, r_paintr,
28 r_getcur, r_comout,
29 r_comin, r_flush
30 };
31
32
33 main(argc, argv) /* set up communications and main loop */
34 int argc;
35 char *argv[];
36 {
37 extern struct driver *dinit();
38 int com;
39 /* set up I/O */
40 progname = argv[0];
41 if (argc < 3) {
42 eputs("arg count\n");
43 quit(1);
44 }
45 devin = fdopen(atoi(argv[1]), "r");
46 devout = fdopen(atoi(argv[2]), "w");
47 if (devin == NULL || devout == NULL || getw(devin) != COM_SENDM) {
48 eputs("connection failure\n");
49 quit(1);
50 }
51 /* open device */
52 if ((dev = dinit(argv[0], argv[3])) == NULL)
53 quit(1);
54 putw(COM_RECVM, devout); /* verify initialization */
55 sendstate();
56 fflush(devout);
57 /* loop on requests */
58 while ((com = getc(devin)) != EOF) {
59 if (com >= NREQUESTS || dev_func[com] == NULL) {
60 eputs("invalid request\n");
61 quit(1);
62 }
63 (*dev_func[com])(); /* process request */
64 }
65 quit(0); /* all done, clean up and exit */
66 }
67
68
69 void
70 quit(code) /* close device and exit */
71 int code;
72 {
73 if (dev != NULL)
74 (*dev->close)();
75 exit(code);
76 }
77
78
79 r_clear() /* clear screen */
80 {
81 int xres, yres;
82
83 xres = getw(devin);
84 yres = getw(devin);
85 (*dev->clear)(xres, yres);
86 }
87
88
89 r_paintr() /* paint a rectangle */
90 {
91 COLOR col;
92 int xmin, ymin, xmax, ymax;
93
94 fread((char *)col, sizeof(COLOR), 1, devin);
95 xmin = getw(devin); ymin = getw(devin);
96 xmax = getw(devin); ymax = getw(devin);
97 (*dev->paintr)(col, xmin, ymin, xmax, ymax);
98 }
99
100
101 r_flush() /* flush output */
102 {
103 if (dev->flush != NULL)
104 (*dev->flush)();
105 putc(COM_FLUSH, devout);
106 sendstate();
107 fflush(devout);
108 }
109
110
111 r_getcur() /* get and return cursor position */
112 {
113 int c;
114 int x, y;
115 /* get it if we can */
116 if (dev->getcur == NULL) {
117 c = ABORT;
118 x = y = 0;
119 } else
120 c = (*dev->getcur)(&x, &y);
121 /* reply */
122 putc(COM_GETCUR, devout);
123 putc(c, devout);
124 putw(x, devout);
125 putw(y, devout);
126 fflush(devout);
127 }
128
129
130 r_comout() /* print string to command line */
131 {
132 char str[256];
133
134 mygets(str, devin);
135 (*dev->comout)(str);
136 }
137
138
139 r_comin() /* read string from command line */
140 {
141 char buf[256], *prompt;
142 /* get prompt */
143 if (getc(devin)) {
144 mygets(buf, devin);
145 prompt = buf;
146 } else
147 prompt = NULL;
148 /* get string */
149 (*dev->comin)(buf, prompt);
150 /* reply */
151 putc(COM_COMIN, devout);
152 myputs(buf, devout);
153 sendstate();
154 fflush(devout);
155 }
156
157
158 mygets(s, fp) /* get string from file (with nul) */
159 register char *s;
160 register FILE *fp;
161 {
162 register int c;
163
164 while ((c = getc(fp)) != EOF)
165 if ((*s++ = c) == '\0')
166 return;
167 *s = '\0';
168 }
169
170
171 myputs(s, fp) /* put string to file (with nul) */
172 register char *s;
173 register FILE *fp;
174 {
175 do
176 putc(*s, fp);
177 while (*s++);
178 }
179
180
181 void
182 eputs(s) /* put string to stderr */
183 register char *s;
184 {
185 static int midline = 0;
186
187 if (!*s)
188 return;
189 if (!midline++) {
190 fputs(progname, stderr);
191 fputs(": ", stderr);
192 }
193 fputs(s, stderr);
194 if (s[strlen(s)-1] == '\n') {
195 fflush(stderr);
196 midline = 0;
197 }
198 }
199
200
201 sendstate() /* send driver state variables */
202 {
203 fwrite((char *)&dev->pixaspect, sizeof(dev->pixaspect), 1, devout);
204 putw(dev->xsiz, devout);
205 putw(dev->ysiz, devout);
206 putw(dev->inpready, devout);
207 }
