root/radiance/ray/src/rt/devmain.c
Revision: 2.2
Committed: Tue Nov 11 20:02:59 1997 UTC (26 years, 6 months ago) by gregl
Changes since 2.1: +5 -7 lines
1 /* Copyright (c) 1989 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * devmain.c - main for independent drivers.
9 *
10 * Redefine your initialization routine to dinit.
11 *
12 * 10/25/89
13 */
14
15 #include "standard.h"
16
17 #include "color.h"
18
19 #include "driver.h"
20
21 struct driver *dev = NULL; /* output device */
22
23 FILE *devin, *devout; /* communications channels */
24
25 char *progname; /* driver name */
26
27 int r_clear(), r_paintr(), r_getcur(), r_comout(), r_comin(), r_flush();
28
29 int (*dev_func[NREQUESTS])() = { /* request handlers */
30 r_clear, r_paintr,
31 r_getcur, r_comout,
32 r_comin, r_flush
33 };
34
35
36 main(argc, argv) /* set up communications and main loop */
37 int argc;
38 char *argv[];
39 {
40 extern struct driver *dinit();
41 int com;
42 /* set up I/O */
43 progname = argv[0];
44 if (argc < 3) {
45 eputs("arg count\n");
46 quit(1);
47 }
48 devin = fdopen(atoi(argv[1]), "r");
49 devout = fdopen(atoi(argv[2]), "w");
50 if (devin == NULL || devout == NULL || getw(devin) != COM_SENDM) {
51 eputs("connection failure\n");
52 quit(1);
53 }
54 /* open device */
55 if ((dev = dinit(argv[0], argv[3])) == NULL)
56 quit(1);
57 putw(COM_RECVM, devout); /* verify initialization */
58 sendstate();
59 fflush(devout);
60 /* loop on requests */
61 while ((com = getc(devin)) != EOF) {
62 if (com >= NREQUESTS || dev_func[com] == NULL) {
63 eputs("invalid request\n");
64 quit(1);
65 }
66 (*dev_func[com])(); /* process request */
67 }
68 quit(0); /* all done, clean up and exit */
69 }
70
71
72 quit(code) /* close device and exit */
73 int code;
74 {
75 if (dev != NULL)
76 (*dev->close)();
77 exit(code);
78 }
79
80
81 r_clear() /* clear screen */
82 {
83 int xres, yres;
84
85 xres = getw(devin);
86 yres = getw(devin);
87 (*dev->clear)(xres, yres);
88 }
89
90
91 r_paintr() /* paint a rectangle */
92 {
93 COLOR col;
94 int xmin, ymin, xmax, ymax;
95
96 fread((char *)col, sizeof(COLOR), 1, devin);
97 xmin = getw(devin); ymin = getw(devin);
98 xmax = getw(devin); ymax = getw(devin);
99 (*dev->paintr)(col, xmin, ymin, xmax, ymax);
100 }
101
102
103 r_flush() /* flush output */
104 {
105 if (dev->flush != NULL)
106 (*dev->flush)();
107 putc(COM_FLUSH, devout);
108 sendstate();
109 fflush(devout);
110 }
111
112
113 r_getcur() /* get and return cursor position */
114 {
115 int c;
116 int x, y;
117 /* get it if we can */
118 if (dev->getcur == NULL) {
119 c = ABORT;
120 x = y = 0;
121 } else
122 c = (*dev->getcur)(&x, &y);
123 /* reply */
124 putc(COM_GETCUR, devout);
125 putc(c, devout);
126 putw(x, devout);
127 putw(y, devout);
128 fflush(devout);
129 }
130
131
132 r_comout() /* print string to command line */
133 {
134 char str[256];
135
136 mygets(str, devin);
137 (*dev->comout)(str);
138 }
139
140
141 r_comin() /* read string from command line */
142 {
143 char buf[256], *prompt;
144 /* get prompt */
145 if (getc(devin)) {
146 mygets(buf, devin);
147 prompt = buf;
148 } else
149 prompt = NULL;
150 /* get string */
151 (*dev->comin)(buf, prompt);
152 /* reply */
153 putc(COM_COMIN, devout);
154 myputs(buf, devout);
155 sendstate();
156 fflush(devout);
157 }
158
159
160 mygets(s, fp) /* get string from file (with nul) */
161 register char *s;
162 register FILE *fp;
163 {
164 register int c;
165
166 while ((c = getc(fp)) != EOF)
167 if ((*s++ = c) == '\0')
168 return;
169 *s = '\0';
170 }
171
172
173 myputs(s, fp) /* put string to file (with nul) */
174 register char *s;
175 register FILE *fp;
176 {
177 do
178 putc(*s, fp);
179 while (*s++);
180 }
181
182
183 eputs(s) /* put string to stderr */
184 register char *s;
185 {
186 static int midline = 0;
187
188 if (!*s)
189 return;
190 if (!midline++) {
191 fputs(progname, stderr);
192 fputs(": ", stderr);
193 }
194 fputs(s, stderr);
195 if (s[strlen(s)-1] == '\n') {
196 fflush(stderr);
197 midline = 0;
198 }
199 }
200
201
202 sendstate() /* send driver state variables */
203 {
204 fwrite((char *)&dev->pixaspect, sizeof(dev->pixaspect), 1, devout);
205 putw(dev->xsiz, devout);
206 putw(dev->ysiz, devout);
207 putw(dev->inpready, devout);
208 }
